    MMM-CalendarExt3 not showing events on calendar, but does on list after 2.30 update
    37 Posts 5 Posters 14.9k Views 6 Watching
    • T Offline
      tke499 @sdetweil
      @sdetweil This is everything that is showing up when I run MM
      magicmirror@2.30.0 start
      npm run start:x11
      magicmirror@2.30.0 start:x11
      [2025-01-01 20:24:29.256] [LOG] Starting MagicMirror: v2.30.0
      [2025-01-01 20:24:29.289] [LOG] Loading config …
      [2025-01-01 20:24:29.294] [LOG] config template file not exists, no envsubst
      [2025-01-01 20:24:29.834] [INFO] Checking config file /home/robert/MagicMirror/config/config.js …
      [2025-01-01 20:24:29.926] [INFO] Your configuration file doesn’t contain syntax errors :)
      [2025-01-01 20:24:29.927] [INFO] Checking modules structure configuration …
      [2025-01-01 20:24:30.058] [INFO] Your modules structure configuration doesn’t contain errors :)
      [2025-01-01 20:24:30.061] [LOG] Loading module helpers …
      [2025-01-01 20:24:30.062] [LOG] No helper found for module: alert.
      [2025-01-01 20:24:30.069] [LOG] Initializing new module helper …
      [2025-01-01 20:24:30.070] [LOG] Module helper loaded: updatenotification
      [2025-01-01 20:24:30.071] [LOG] No helper found for module: clock.
      [2025-01-01 20:24:30.214] [LOG] Initializing new module helper …
      [2025-01-01 20:24:30.214] [LOG] Module helper loaded: calendar
      [2025-01-01 20:24:30.216] [LOG] No helper found for module: weather.
      [2025-01-01 20:24:30.216] [LOG] No helper found for module: MMM-Traffic.
      [2025-01-01 20:24:30.252] [LOG] Initializing new module helper …
      [2025-01-01 20:24:30.252] [LOG] Module helper loaded: mmm-nest-status
      [2025-01-01 20:24:30.363] [LOG] Initializing new module helper …
      [2025-01-01 20:24:30.363] [LOG] Module helper loaded: newsfeed
      [2025-01-01 20:24:30.364] [LOG] No helper found for module: MMM-CalendarExt3.
      [2025-01-01 20:24:30.364] [LOG] All module helpers loaded.
      [2025-01-01 20:24:30.389] [LOG] Starting server on port 8080 …
      [2025-01-01 20:24:31.322] [LOG] Server started …
      [2025-01-01 20:24:31.323] [LOG] Connecting socket for: updatenotification
      [2025-01-01 20:24:31.324] [LOG] Starting module helper: updatenotification
      [2025-01-01 20:24:31.325] [LOG] Connecting socket for: calendar
      [2025-01-01 20:24:31.326] [LOG] Starting node helper for: calendar
      [2025-01-01 20:24:31.327] [LOG] Connecting socket for: mmm-nest-status
      [2025-01-01 20:24:31.328] [LOG] Starting node_helper for module [mmm-nest-status]
      [2025-01-01 20:24:31.329] [LOG] Connecting socket for: newsfeed
      [2025-01-01 20:24:31.331] [LOG] Starting node helper for: newsfeed
      [2025-01-01 20:24:31.332] [LOG] Sockets connected & modules started …
      [2025-01-01 20:24:31.694] [LOG] Launching application.
      [2025-01-01 20:24:32.841] [INFO] System information:
      SYSTEM: manufacturer: ; model: ; virtual: false
      OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.62+rpt-rpi-v8
      VERSIONS: electron: 32.2.7; used node: 22.12.0; installed node: 22.12.0; npm: 10.9.0; pm2: 5.4.3
      OTHER: timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
      [4696:0101/202433.175100:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [4696:0101/202433.175511:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4696:0101/202433.175885:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [4696:0101/202433.176005:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4696:0101/202433.176180:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [4696:0101/202433.176283:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4696:0101/202433.176443:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [4696:0101/202433.176539:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4696:0101/202433.176688:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [4696:0101/202433.176787:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4696:0101/202433.176939:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [4696:0101/202433.177033:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4696:0101/202433.177181:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [4696:0101/202433.177270:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4696:0101/202433.178472:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [4696:0101/202433.178599:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4696:0101/202433.178765:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [4696:0101/202433.178886:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4696:0101/202433.179046:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [4696:0101/202433.179135:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4696:0101/202433.179281:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [4696:0101/202433.179369:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4696:0101/202433.179516:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [4696:0101/202433.179604:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4696:0101/202433.179750:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [4696:0101/202433.179876:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [4696:0101/202433.180031:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
      [4696:0101/202433.180119:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
      [2025-01-01 20:24:34.889] [LOG] Create new calendarfetcher for url: http://p159-caldav.icloud.com/published/2/Mjc5OTI2NzkxMjc5OTI2N_OGitwGbVHoaRgKm45s40567NS6ia83VwuU3ZKztGC0 - Interval: 300000
      [2025-01-01 20:24:34.932] [LOG] Create new newsfetcher for url: https://moxie.foxnews.com/google-publisher/latest.xml - Interval: 300000
      [2025-01-01 20:24:35.001] [INFO] updatenotification: Updater Class Loaded!
      [2025-01-01 20:24:35.002] [INFO] updatenotification: Checking PM2 using…
      [2025-01-01 20:24:35.003] [INFO] updatenotification: [PM2] You are not using pm2
      [2025-01-01 20:24:35.004] [INFO] Checking git for module: MMM-Traffic
      [2025-01-01 20:24:35.029] [INFO] Checking git for module: mmm-nest-status
      [2025-01-01 20:24:35.073] [INFO] Checking git for module: MMM-CalendarExt3
      [2025-01-01 20:24:35.203] [INFO] Checking git for module: MagicMirror
      [2025-01-01 20:24:36.256] [INFO] Calendar-Fetcher: Broadcasting 128 events from .
      [2025-01-01 20:24:36.467] [INFO] Newsfeed-Fetcher: Broadcasting 25 items.
      [4587:0101/202451.558237:ERROR:CONSOLE(1)] “Request Autofill.enable failed. {“code”:-32601,“message”:”‘Autofill.enable’ wasn’t found"}“, source: devtools://devtools/bundled/core/protocol_client/protocol_client.js (1)
      [4587:0101/202451.558687:ERROR:CONSOLE(1)] “Request Autofill.setAddresses failed. {“code”:-32601,“message”:”‘Autofill.setAddresses’ wasn’t found”}", source: devtools://devtools/bundled/core/protocol_client/protocol_client.js (1)
      [4587:0101/202533.885618:ERROR:CONSOLE(1)] “Uncaught (in promise) SyntaxError: Unexpected token ‘H’, “HTTP/1.1 4”… is not valid JSON”, source: devtools://devtools/bundled/devtools_app.html?remoteBase=https://chrome-devtools-frontend.appspot.com/serve_file/@6cd35584827031630286f7d1b4c986f9ebd175df/&can_dock=true&toolbarColor=rgba(223,223,223,1)&textColor=rgba(0,0,0,1)&experiments=true (1)
      [2025-01-01 20:29:36.818] [INFO] Calendar-Fetcher: Broadcasting 128 events from http://p159-.
      [2025-01-01 20:29:37.507] [INFO] Newsfeed-Fetcher: Broadcasting 25 items.
      [2025-01-01 20:31:34.526] [LOG] Shutting down server…
      [2025-01-01 20:31:34.528] [LOG] Stopping module helper: updatenotification
      [2025-01-01 20:31:34.529] [LOG] Stopping module helper: calendar
      [2025-01-01 20:31:34.529] [LOG] Stopping module helper: mmm-nest-status
      [2025-01-01 20:31:34.530] [LOG] Stopping module helper: newsfeed
      [2025-01-01 20:31:34.531] [LOG] Node_helpers stopped …
      • T Offline
        tke499 @sdetweil
        @sdetweil This is what I get in the console Screenshot 2025-01-01 at 8.47.02 PM.png
          sdetweil @tke499
          @tke499 calendar is broadcasting, so that’s not it
            MMRIZE @tke499
            @tke499
            Generally,
            This message is just an warning can be ignored.
            However, in practice, stopping at that point usually corresponds to the following cases:
            1. (Most common case): The CX3 module has not been properly installed. In most situations, this happens because the CX3_Shared library is not correctly installed. To resolve this, navigate to the CX3 directory, run git pull, and then execute npm install. This resolves most issues. If it doesn’t, simply delete the entire CX3 directory and reinstall it. It only takes about 15 seconds.
            2. In very rare cases, other modules may cause errors during DOM creation, which can have an impact. However, this is highly uncommon, so the cause is typically case 1.
            T 2 Replies Last reply Reply Quote 0
            • T Offline
              tke499 @MMRIZE
              @MMRIZE I have re-installed CX3 3 times now. Still having the same issue
              • T Offline
                tke499 @MMRIZE
                @MMRIZE I only have 2 other modules installed, one for nest and the other for traffic.
                  MMRIZE @tke499
                  @tke499
                  Send me your ics file or url. (eouia0819@gmail.com)
                    sdetweil @tke499
                    @tke499 what is the settings in the default calendar,
                    xxx out your url
                    set :maximumEvents:100,
                    • T Offline
                      tke499 @sdetweil
                      @sdetweil I set it to 100. The events now show up, but low the list on the side goes to the bottom of the screen. Not the desired effect.
                        sdetweil @tke499
                        @tke499 use limitdays
                        there are 50 knobs to adjust
                          sdetweil @tke499
                          @tke499 you can try maximumEvents:12 or 15
                          there is also a way with css. i will test and document in a little while
                          this should hide more than 10 events in the default calendar
                          in custom.css
                          .calendar table tr:nth-child(n+10) {
                            display: none;
                          S NiggichN 2 Replies Last reply Reply Quote 0
                            @tke499 I have confirmed the css approach works…
                            in ~/MagicMirror/css/.custom.css
                            .calendar table tr:nth-child(n+10) {  /* 10 is the number of rows you want showing */
                                      display: none;
                            I have maximumEvents:200
                            and only 10 lines show with the css posted
                            without it, it goes to the bottom of the screen
                            • NiggichN Offline
                              Niggich @sdetweil
                              @sdetweil thx this is working for me, but now the events doesn’t fade out… any solution?
                              • T Offline
                                tke499 @sdetweil
                                @sdetweil this works, just no fade. Thanks
                                  sdetweil @tke499
                                  @tke499 yeh, fade is calculated based on the size of the list (200 in my case)
                                  and the fade starts at 100, oops… cut off at 10…
                                  fadepoint can get you a different start spot, BUT, its also changes the amount of fade (start at .02 (4 =line 4) BUT there are 196 steps in the fade, so I don’t see much…
                                  looking thru the code, I don’t see any difference in the event broadcast
                                    sdetweil @tke499
                                    @tke499 i’ll give you a hack til next release
                                    in ~/MagicMirror/modules/default/calendar.js
                                    add this line
                                    		fadePoint: 0.25, // Start on 1/4th of the list.  line 25
                                    		fadeSteps:0,  // ------- this one
                                    and
                                    			startFade = events.length * this.config.fadePoint;   // line 255 after above added
                                    			fadeSteps = events.length - startFade;
                                    			if(this.config.fadeSteps)                  /* these two */
                                    				fadeSteps=this.config.fadeSteps
                                    then in your config.js calendar
                                              fade:true,
                                              fadePoint:0.02,   //  use this to get into the top 10 (my 200 list gets to number 4)
                                              fadeSteps:6,         // use this to decide how many steps from full to gone
                                    T C 2 Replies Last reply Reply Quote 0
                                    • T Offline
                                      tke499 @sdetweil
                                      @sdetweil Thanks. Do we know why this is happening with this release? Assuming it had to do with the calendar update.
                                        sdetweil @tke499
                                        @tke499 I do not yet… I checked the code that sends the list to other modules and I don’t SEE anything … ps, I personally did all the calendar updates
                                        both versions clip the list to the config.maxEvents: value. (10 default in both)
                                          @tke499 looking at the code again, there WAS a bug in prior releases, where
                                          you COULD specify to limit the number of entries produced BY calendar
                                                 url: "some cal url",
                                                 maximumEntries:xxx   // default whatever the base config has for this property
                                          so, I added code to fix that bug
                                          SO, if one does NOT specify maximumEntries in the cal url section,
                                          it will clip to the default value,
                                          which it did NOT DO before…
                                          the prior bug was maxEvents said 100 (including old)
                                          1st cal contributed 20
                                          2nd cal contributed 100
                                          3rd cal contributed 5
                                          1st 100 (maxEvents) is returned… so none of cal 3 got processed…
                                          the code and limits were present in prior release, just not the clipping
                                          • T Offline
                                            tke499 @sdetweil
                                            @sdetweil so I am assuming that I should just keep the coding you provided earlier correct?
