Made a birthday module
39 Posts 4 Posters 3.6k Views 5 Watching
    cgillinger
    I got inspired by MMM-Fireworks and decided to make a birthday module with fireworks and confetti. Its not a “birthday reminder” module, rather it sits quietly, and only erupts when someone has a birthday:
    At that time a message is presented in the middle of the screen, fireworks and confetti is displayed.
    Its somewhat multilingual (machine translated) and has a few different messages to pick from.
    Things I haven’t solved: Currently there is a timer, that is per default set to “infinite” - because its of no use if its invisible. It would probably make sense to make some sortof “off button”, but my main display has no touch or input. So as of now it is as default showed until the day ends.
    Here it is: https://github.com/cgillinger/MMM-Birthday
    P 1 Reply Last reply Jan 22, 2025, 2:57 AM Reply Quote 7
      plainbroke @cgillinger
      @cgillinger
      I installed your module, it does nothing when its turn comes up in MMM-pages.
      I am running Bookworm, MM 2.30 on a Pi 4 8gb. How do I pick the messages?
      Not quite enough information to run this module.
      Please help with the setup…
      C 1 Reply Last reply Jan 22, 2025, 11:22 AM Reply Quote 1
        cgillinger @plainbroke
        @plainbroke Im running Linux Mint and this is my config from config.js:
           module: "MMM-Birthday",
              position: "middle_center",
                  birthdays: [
                      { name: "Eric", date: "01-26" },
                      { name: "Lisa", date: "07-01" },
                      { name: "Sigrid", date: "07-15" },
                      { name: "Lars", date: "07-17" },
                      { name: "Firas", date: "11-26" }
                  fireworkDuration: "infinite",
                  confettiDuration: "infinite"
        This works for me. Mind sharing your config.js, to see if something is up there? Have you run npm install?
        And you dont pick messages, the module picks for you (or you can just edit the correct language json and enter the same message. This is for instance the en.json for english:
        “MESSAGES”: [
        “🎉 Happy Birthday, {name}! 🎂”,
        “🎈 Best wishes on your special day, {name}! 🎁”,
        “🌟 Have a fantastic birthday, {name}! 🎊”,
        “✨ Wishing you a wonderful birthday, {name}! 🎈”,
        “🎊 May your day be filled with joy, {name}! 🌟”
        And to be clear: The module only activates on birthdays. Otherwise it just sits invisble.
        P 1 Reply Last reply Jan 23, 2025, 2:56 AM Reply Quote 0
          @cgillinger
          Yes did the npm install
          Here is the section out of my config.js
                                  position: "middle_center", // Module will be centered during celebrations
                                          birthdays: [
                                                  { name: "Test1", date: "1-21" },
                                                  { name: "Test2", date: "1-22" },
                                                  { name: "Test3", date: "1-23" },
                                                  { name: "Test4", date: "1-24" },
                                                  { name: "Test5", date: "1-25" }
                                          fireworkDuration: "infinite", // or specific duration in milliseconds
                                          confettiDuration: "infinite"  // or specific duration in milliseconds
          C 1 Reply Last reply Jan 23, 2025, 11:18 AM Reply Quote 0
            @plainbroke Question: Have you tried running it without MMM-Pages? Im not familiar with the functionality of that module (but I’ll look into it)
            C 1 Reply Last reply Jan 23, 2025, 3:03 PM Reply Quote 0
              cgillinger @cgillinger
              After looking at MMM-pages I think the issue is that MMM-Birthday uses special positioning to ensure its celebrations are always visible (it needs to be on top of everything else to work properly). However, this means it doesn’t play nicely with MMM-Pages’ normal way of showing and hiding modules.
              First suggestion: Add MMM-Birthday to MMM-Pages’ fixed modules:
              fixed: [“MMM-page-indicator”, “MMM-Birthday”]
              This should tell MMM-Pages to leave MMM-Birthday alone and let it handle its own visibility, which should resolve the issue while maintaining all the celebration effects.
              S P 2 Replies Last reply Jan 23, 2025, 3:11 PM Reply Quote 0
              • S Away
                sdetweil @cgillinger
                @cgillinger the other thing you can do is add support for the
                suspend(){}
                and resume{}
                methods in your modulename.js
                suspend means being hidden
                resume means being shown
                C 1 Reply Last reply Jan 24, 2025, 8:53 AM Reply Quote 1
                  @cgillinger
                  Well I tried your idea about putting MMM-Birthday in the “fixed” area in Pages.
                  I guess I can try your idea of using it without MMM-Pages, but it would be better if you could fix your module per sdetweil’s suggestion.
                  P 1 Reply Last reply Jan 24, 2025, 12:40 AM Reply Quote 0
                    plainbroke @plainbroke
                    @cgillinger
                    I tried your idea, I renamed my config.js to config.js2
                    copied the config.js.sample to config.js
                    added this to the new config.js
                    /* Config Sample
                     * see https://docs.magicmirror.builders/configuration/introduction.html
                     * and https://docs.magicmirror.builders/modules/configuration.html
                     * You can use environment variables using a `config.js.template` file instead of `config.js`
                     * which will be converted to `config.js` while starting. For more information
                     * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
                    let config = {
                            address: "192.168.1.222",       // Address to listen on, can be:
                            port: 8080,
                            basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                            ipWhitelist: [],        // Set [] to allow all IP addresses
                            useHttps: false,                        // Support HTTPS or not, default "false" will use HTTP
                            httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                            httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                            language: "en",
                            locale: "en-US",   // this variable is provided as a consistent location
                            timeFormat: 12,
                            units: "imperical",
                                            position: "middle_center", // Module will be centered d>
                                                    birthdays: [
                                                    fireworkDuration: "infinite", // or specific du>
                                                    confettiDuration: "infinite"  // or specific du>
                    Still does not work.
                    I removed and reinstalled
                    Still nothing. Maybe it only works on MINT?
                    S 1 Reply Last reply Jan 24, 2025, 12:47 AM Reply Quote 0
                    • S Away
                      sdetweil @plainbroke
                      @plainbroke you can also use the environment variable to set the config file
                      export MM_CONFIG_FILE=config/xxxxx.js
                      npm start
                      or
                      npm run server
                      Both will use that config
                      To reset it
                      P 1 Reply Last reply Jan 24, 2025, 1:27 AM Reply Quote 1
                      • 1 / 4
                      1 / 4
