    Made a birthday module
    39 Posts 4 Posters 14.7k Views 5 Watching
    • plainbrokeP Offline
      plainbroke @cgillinger
      @cgillinger
      Well I tried your idea about putting MMM-Birthday in the “fixed” area in Pages.
      I guess I can try your idea of using it without MMM-Pages, but it would be better if you could fix your module per sdetweil’s suggestion.
        plainbroke @plainbroke
        @cgillinger
        I tried your idea, I renamed my config.js to config.js2
        copied the config.js.sample to config.js
        added this to the new config.js
        /* Config Sample
         * see https://docs.magicmirror.builders/configuration/introduction.html
         * and https://docs.magicmirror.builders/modules/configuration.html
         * You can use environment variables using a `config.js.template` file instead of `config.js`
         * which will be converted to `config.js` while starting. For more information
         * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
        let config = {
                address: "192.168.1.222",       // Address to listen on, can be:
                port: 8080,
                basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                ipWhitelist: [],        // Set [] to allow all IP addresses
                useHttps: false,                        // Support HTTPS or not, default "false" will use HTTP
                httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                language: "en",
                locale: "en-US",   // this variable is provided as a consistent location
                timeFormat: 12,
                units: "imperical",
                                module: "MMM-Birthday",
                                position: "middle_center", // Module will be centered d>
                                        birthdays: [
                                                { name: "Test1", date: "1-21" },
                                                { name: "Test2", date: "1-22" },
                                                { name: "Test3", date: "1-23" },
                                                { name: "Test4", date: "1-24" },
                                                { name: "Test5", date: "1-25" }
                                        fireworkDuration: "infinite", // or specific du>
                                        confettiDuration: "infinite"  // or specific du>
        Still does not work.
        I removed and reinstalled
        Still nothing. Maybe it only works on MINT?
          sdetweil @plainbroke
          @plainbroke you can also use the environment variable to set the config file
          export MM_CONFIG_FILE=config/xxxxx.js
          npm start
          or
          npm run server
          Both will use that config
          To reset it
          plainbrokeP 1 Reply Last reply Reply Quote 1
            plainbroke @sdetweil
            I got it to work on another pi4 with only 4 mb ram.
            On the exact same setup
            Bookworm
            MM 2.30
            fully updated.
            It seems it has to be the only module besides some of the default ones.
            Which it covers up completely like the MPlayer does…
            Good thing I have an extra pi, I guess. The wifey likes it alot…
            I thought it would be cool add-on for my main mirror that is in the living room right above the TV. Gives us something to focus on during commercial’s…
            Updated your MMM-Config. LOOKING better every update…
              @plainbroke if you use my fork of mmm-pages it has the ability to show different pages for different amounts of time
              See the pageTimeout property
                I am using your mmm-pages. I just haven’t gotten that involved in it yet…
                I know sooner or later I will definitely take advantage of the different amounts of viewable content.
                  cgillinger @sdetweil
                  @sdetweil said in Made a birthday module:
                  @cgillinger the other thing you can do is add support for the
                  suspend(){}
                  and resume{}
                  methods in your modulename.js
                  suspend means being hidden
                  resume means being shown
                  Done, but haven’t tried it with MMM-Pages yet, a bit to busy at work to install and try it that way. But its in the repo now.
                    @cgillinger
                    Works on the fireworks, but not on the MESSAGE part, It stays on the screen.
                    The fireworks came and went with the page it was supposed to.
                      cgillinger @plainbroke
                      @plainbroke said in Made a birthday module:
                      @cgillinger
                      This annoys the hell out of me, if I get the time, I’ll try to set up a MM with MMM-Pages to test it here.
                      But to be clear:
                      The fireworks (and confetti?) works
                      But the message a) doesn’t show or b) shows, but does not get removed when MMM-Pages initiate page change?
                        sdetweil @cgillinger
                        @cgillinger b
                          @cgillinger b
                          Huh?
                            @cgillinger you said a or b
                            I responded he said b
                              @cgillinger
                              As Sam said b it stays on the screen always. Just the message though.
                              Sorry it annoys you so.
                              Take your time I am not in a hurry, never am.
                              Just thought I would let you know. I am sure others are watching this to add to their pages too…
                              • X Offline
                                xIExodusIx
                                Unfortunately I have a few problems with your MMM-Birthday module. When I start the MM and there is a birthday, it is immediately displayed in the
                                middle (middle_center) on all pages without taking the position from config.js into account. The display is not yet dimmed on all pages.
                                Confetti is displayed in the correct position (lower_third) on the specified page as specified in the config.js, fireworks only sometimes but the
                                icons are missing!
                                On the 2nd and all subsequent runs of the pages, the birthday is also displayed in the correct position (lower_third) but without a name (undefined!)
                                with confetti (always) and fireworks (only sometimes) but still without icons. The display now will be dimmed on all pages.
                                If I start the MM and there is no birthday, everything is fine, nothing is displayed.
                                If a birthday is coming up from 00:00, it will be displayed as described above in the correct position (lower_third) with confetti but without a
                                name (undefiend!), without fireworks and without icons. The display is darkened on all pages so that it is barely legible.
                                See Pictures!
                                Hardware:
                                Raspberry Pi4 4GB RAM RaspiOS: Bookworm
                                Software:
                                MM 2.30 with MMM-Pages
                                MM2.30_Birthday-1_First_Run.jpg MM2.30_Birthday-2_All_other_Runs.jpg MM2.30_Birthday-3.jpg
                                  cgillinger @xIExodusIx
                                  @xIExodusIx Yes, there is an issue with it working alongside MMM-Pages. It seems that the methods I use to make it display interfere with MMM-Pages. MMM-Birthday doesn’t play well with others and tends to do its own thing, which doesn’t work with MMM-Pages. I’m working on a solution, but I haven’t had much time to spare lately.
                                    @cgillinger
                                    see the
                                    suspend() and resume() functions you can add to be notified when being hidden (suspend) and shown (resume)
                                    plainbrokeP 1 Reply Last reply Reply Quote 2
                                      @cgillinger
                                      I was going to ask if you had found a work around for pages and MMM-Birthdays. I also tried it with pages and just one other module. MMM-Birthdays takes over even MMM-MPlayer and it is a bully too.
                                      Always wanting to be on top… You idea is awesome, but the deployment needs a little work…
                                      I am trying a few different setups now that I have a “test setup”.
                                      I really want to make MPLayer and Birthdays to play nice on one of my displays. So far no bueno…
                                      S C 2 Replies Last reply Reply Quote 0
                                        @plainbroke they cannot be on same page
                                          @plainbroke Working on it! The plain and simple truth is I took a few shortcuts with the behaviour of the module, and that came back to bite me. I’m working on it, but its in my spare time and right now I have precious little of it. But as soon as I get it fixed, I’ll post here.
                                            @cgillinger
                                            Sounds good. I will watch this form post for the update.
