    Made a birthday module
    39 Posts 4 Posters 16.1k Views 5 Watching
      cgillinger
      I got inspired by MMM-Fireworks and decided to make a birthday module with fireworks and confetti. Its not a “birthday reminder” module, rather it sits quietly, and only erupts when someone has a birthday:
      At that time a message is presented in the middle of the screen, fireworks and confetti is displayed.
      Its somewhat multilingual (machine translated) and has a few different messages to pick from.
      Things I haven’t solved: Currently there is a timer, that is per default set to “infinite” - because its of no use if its invisible. It would probably make sense to make some sortof “off button”, but my main display has no touch or input. So as of now it is as default showed until the day ends.
      Here it is: https://github.com/cgillinger/MMM-Birthday
      plainbrokeP 1 Reply Last reply
      Reply Quote 7
      • plainbrokeP
        plainbroke @cgillinger
        @cgillinger
        I installed your module, it does nothing when its turn comes up in MMM-pages.
        I am running Bookworm, MM 2.30 on a Pi 4 8gb. How do I pick the messages?
        Not quite enough information to run this module.
        Please help with the setup…
        C 1 Reply Last reply
          cgillinger @plainbroke
          @plainbroke Im running Linux Mint and this is my config from config.js:
             module: "MMM-Birthday",
                position: "middle_center",
                    birthdays: [
                        { name: "Eric", date: "01-26" },
                        { name: "Lisa", date: "07-01" },
                        { name: "Sigrid", date: "07-15" },
                        { name: "Lars", date: "07-17" },
                        { name: "Firas", date: "11-26" }
                    fireworkDuration: "infinite",
                    confettiDuration: "infinite"
          This works for me. Mind sharing your config.js, to see if something is up there? Have you run npm install?
          And you dont pick messages, the module picks for you (or you can just edit the correct language json and enter the same message. This is for instance the en.json for english:
          “MESSAGES”: [
          “🎉 Happy Birthday, {name}! 🎂”,
          “🎈 Best wishes on your special day, {name}! 🎁”,
          “🌟 Have a fantastic birthday, {name}! 🎊”,
          “✨ Wishing you a wonderful birthday, {name}! 🎈”,
          “🎊 May your day be filled with joy, {name}! 🌟”
          And to be clear: The module only activates on birthdays. Otherwise it just sits invisble.
          • plainbrokeP
            @cgillinger
            Yes did the npm install
            Here is the section out of my config.js
                                    position: "middle_center", // Module will be centered during celebrations
                                            birthdays: [
                                                    { name: "Test1", date: "1-21" },
                                                    { name: "Test2", date: "1-22" },
                                                    { name: "Test3", date: "1-23" },
                                                    { name: "Test4", date: "1-24" },
                                                    { name: "Test5", date: "1-25" }
                                            fireworkDuration: "infinite", // or specific duration in milliseconds
                                            confettiDuration: "infinite"  // or specific duration in milliseconds
              @plainbroke Question: Have you tried running it without MMM-Pages? Im not familiar with the functionality of that module (but I’ll look into it)
                cgillinger @cgillinger
                After looking at MMM-pages I think the issue is that MMM-Birthday uses special positioning to ensure its celebrations are always visible (it needs to be on top of everything else to work properly). However, this means it doesn’t play nicely with MMM-Pages’ normal way of showing and hiding modules.
                First suggestion: Add MMM-Birthday to MMM-Pages’ fixed modules:
                fixed: [“MMM-page-indicator”, “MMM-Birthday”]
                This should tell MMM-Pages to leave MMM-Birthday alone and let it handle its own visibility, which should resolve the issue while maintaining all the celebration effects.
                S plainbrokeP 2 Replies Last reply
                  sdetweil @cgillinger
                  @cgillinger the other thing you can do is add support for the
                  suspend(){}
                  and resume{}
                  methods in your modulename.js
                  suspend means being hidden
                  resume means being shown
                  • plainbrokeP
                    @cgillinger
                    Well I tried your idea about putting MMM-Birthday in the “fixed” area in Pages.
                    I guess I can try your idea of using it without MMM-Pages, but it would be better if you could fix your module per sdetweil’s suggestion.
                    • plainbrokeP
                      plainbroke @plainbroke
                      @cgillinger
                      I tried your idea, I renamed my config.js to config.js2
                      copied the config.js.sample to config.js
                      added this to the new config.js
                      /* Config Sample
                       * see https://docs.magicmirror.builders/configuration/introduction.html
                       * and https://docs.magicmirror.builders/modules/configuration.html
                       * You can use environment variables using a `config.js.template` file instead of `config.js`
                       * which will be converted to `config.js` while starting. For more information
                       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
                      let config = {
                              address: "192.168.1.222",       // Address to listen on, can be:
                              port: 8080,
                              basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                              ipWhitelist: [],        // Set [] to allow all IP addresses
                              useHttps: false,                        // Support HTTPS or not, default "false" will use HTTP
                              httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                              httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                              language: "en",
                              locale: "en-US",   // this variable is provided as a consistent location
                              timeFormat: 12,
                              units: "imperical",
                                              position: "middle_center", // Module will be centered d>
                                                      birthdays: [
                                                      fireworkDuration: "infinite", // or specific du>
                                                      confettiDuration: "infinite"  // or specific du>
                      Still does not work.
                      I removed and reinstalled
                      Still nothing. Maybe it only works on MINT?
                        sdetweil @plainbroke
                        @plainbroke you can also use the environment variable to set the config file
                        export MM_CONFIG_FILE=config/xxxxx.js
                        npm start
                        or
                        npm run server
                        Both will use that config
                        To reset it
                        • plainbrokeP
                          plainbroke @sdetweil
                          I got it to work on another pi4 with only 4 mb ram.
                          On the exact same setup
                          Bookworm
                          MM 2.30
                          fully updated.
                          It seems it has to be the only module besides some of the default ones.
                          Which it covers up completely like the MPlayer does…
                          Good thing I have an extra pi, I guess. The wifey likes it alot…
                          I thought it would be cool add-on for my main mirror that is in the living room right above the TV. Gives us something to focus on during commercial’s…
                          Updated your MMM-Config. LOOKING better every update…
                            @plainbroke if you use my fork of mmm-pages it has the ability to show different pages for different amounts of time
                            See the pageTimeout property
                            • plainbrokeP
                              I am using your mmm-pages. I just haven’t gotten that involved in it yet…
                              I know sooner or later I will definitely take advantage of the different amounts of viewable content.
                                cgillinger @sdetweil
                                @sdetweil said in Made a birthday module:
                                suspend(){}
                                and resume{}
                                Done, but haven’t tried it with MMM-Pages yet, a bit to busy at work to install and try it that way. But its in the repo now.
                                • plainbrokeP
                                  @cgillinger
                                  Works on the fireworks, but not on the MESSAGE part, It stays on the screen.
                                  The fireworks came and went with the page it was supposed to.
                                    @plainbroke said in Made a birthday module:
                                    @cgillinger
                                    This annoys the hell out of me, if I get the time, I’ll try to set up a MM with MMM-Pages to test it here.
                                    But to be clear:
                                    The fireworks (and confetti?) works
                                    But the message a) doesn’t show or b) shows, but does not get removed when MMM-Pages initiate page change?
                                      @cgillinger b
                                        @cgillinger b
                                        Huh?
                                          @cgillinger you said a or b
                                          I responded he said b
                                          • plainbrokeP
                                            @cgillinger
                                            As Sam said b it stays on the screen always. Just the message though.
                                            Sorry it annoys you so.
                                            Take your time I am not in a hurry, never am.
                                            Just thought I would let you know. I am sure others are watching this to add to their pages too…
