    MMM-pages - how to know which page index my module has?
    29 Posts 4 Posters 10.5k Views 4 Watching
      sdetweil @evroom
      @evroom sorry, don’t quite understand
      your module would support the suspend/resume functions and be called at each appropriately
      MMM-pages calls hide and show
      there is also a ‘different’ way to configure pages
      use an arbitrary name for each page
      and then add that to the classes of the modules you want on that page
      see https://github.com/sdetweil/MMM-pages?tab=readme-ov-file#class-based-configuration
        @evroom
        from my SampleModule.js
        	// system notification your module is being hidden
        	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
        	suspend: function(){
        	// system notification your module is being unhidden/shown
        	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
        	resume: function(){
        S evroomE 2 Replies Last reply Reply Quote 0
          @evroom my MMM-SleepWake uses an external trigger to cause modules to be shown/hidden (screen saver where the screen won’t turn off)
          I provide a commandline command to interact with the module…
          i use a webcam with the motion project daemon to trigger show/hide
          • evroomE
            evroom @sdetweil
            Yeah, this module is kind of in my foster care.
            I did not come up with the code; only made some tweaks and made it available.
            There is not suspend or resume to been seen in the code.
            But I will study the stuff you mentioned and will try to implement that.
            Thx.
            MagicMirror version: 2.37.0
            • evroomE
              evroom @evroom
              As a workaround, I will make it a requirement to put the MMM-Player on the first page (page index 0).
              When I receive 0, then I will start streaming, otherwise I will stop streaming.
              That seems to work.
              evroomE M 3 Replies Last reply Reply Quote 0
              • evroomE
                evroom @evroom
                Short question:
                There are 2 versions of MMM-pages:
                https://github.com/edward-shen/MMM-pages
                They seem in-sync, but which one would be the preferred one to take?
                  sdetweil @evroom
                  @evroom the core function is the same
                  i added the ability to have different page display times
                  i wrote the doc on the fixed page name approach
                  as you are using a notification now
                  just move that to suspend (same as index=0)
                  and the resume wakes you back up
                  • plainbrokeP
                    plainbroke @sdetweil
                    He has the MMM-MPlayer working in pages and I am now using pages and MPlayer in my main MM.
                    Kinda of cool to be able to show a RSTP camera or 2 again…
                      sdetweil @plainbroke
                      @plainbroke cool
                        mvrlogins @evroom
                        @evroom said in MMM-pages - how to know which page index my module has?:
                        That seems to work.
                        Hi
                        Trying to use the mmm-mplayer module with mmm-pages, and it works fine, as you say, when the page index is 0.
                        However, I’d like to use it to only show video when called via notification
                        I have a single main page (without mplayer) - that shows all the time - and a single hidden page (with mplayer) to be shown when called via notification and then return the the main page with another notification.
                        I can’t currently implement this. Any ideas?
                        Thanks very much
                          sdetweil @mvrlogins
                          @mvrlogins why not? what triggers the notification??
                          button, command , …
                          you could prove this with the MMM-CommandtoNotification module
                            mvrlogins @sdetweil
                            I’m using MMM-Remote Control
                            The issue is that the video is shown all the time on page0.
                            I have 2 pages set up with MMM-Pages
                            • 1 page to be shown all the time
                            • 1 hidden page to be shown only when called.
                            The video needs to be on the hidden page. If I put classes : “hidden_page” under MMM-Player, the video feed shows on the page0 regardless.
                            The hidden page, when called, shows only the header fro MMM-Player and is otherwise blank
                            The page calling works fine with MMM-RemoteControl
                                    module: "MMM-pages",
                                        rotationTime: 1000 * 20, // rotate every 20 seconds
                                            ["page1"],           // class name for page 1
                                        fixed: ["fixed_page"],
                                        hiddenPages: {
                                            "Doorbell": ["doorbell_page"],
                            and
                            	module: 'MMM-MPlayer',
                                    classes: "doorbell_page",
                                    disabled: false,
                                    header: "MPlayer",
                            	  useTwoWindows: true,
                            	  layout: 'column',
                            	  monitorAspect: 0,
                            	  rotate: -1,
                            	  windowSize: { width: 640, height: 480 },
                            	  windowPosition: { x: 5, y: 225 },
                            	  streamInterval: 30000,
                            	  streams: {
                            		window1: [
                            		  'rtsp://10.0.1.1:7447/gv9eHrB9yZyPhgvN',
                            		window2: [
                            		  'rtsp://10.0.1.1:7447/D89zTJyDwN8YtKix',
                              mvrlogins @mvrlogins
                              Only thing I can think of right now is to put the video on page0 and the rest on page1
                              and then use a combination of the PAGE_CHANGED and PAUSE_ROTATION notifications to get what I want
                              Or is there a way to permanently pause rotation?
                              Then I can only use the PAGE_CHANGED call to get to the page I want
                              would the below disable rotation?
                              rotationTime: 1000 * 0,
                                sdetweil @mvrlogins
                                @mvrlogins i believe so. but you should have been able to send the notification for the named hidden page
                                “SHOW_HIDDEN_PAGE”, “Doorbell”
                                right?!
                                  mvrlogins @sdetweil
                                  @sdetweil said in MMM-pages - how to know which page index my module has?:
                                  right?!
                                  Yes, the notification works fine.
                                  But mplayer does not show up on the hidden page, only on the main page
                                    sdetweil @mvrlogins
                                    @mvrlogins hm, that makes no sense as the MagicMirror operations are the same
                                      sdetweil @mvrlogins
                                      @mvrlogins i opened this issue
                                      https://github.com/evroom/MMM-MPlayer/issues/4
                                      try my fork
                                      cd ~/MagicMirror/modules
                                      rename the existing folder out of the way
                                      git clone https://github.com/sdetweil/MMM-MPlayer
                                      change the page config to have the hidden page and the
                                      remote_control notification
                                      I submitted this change to the module for inclusion, depending on your results.
                                        mvrlogins @sdetweil
                                        Maybe something to do with mplayer itself, not the module MMM-Mplayer?
                                          sdetweil @mvrlogins
                                          @mvrlogins no, i fixed in my fork
                                            mvrlogins @sdetweil
                                            Did as you suggested
                                            The video appears only on page index 0 and not on the hidden page
                                            See the 2 video images on the attached screenshot - both are over the weather module
                                            The header for the MPlayer appears on the hidden page
                                            I can change to the hidden page with Remote Control, no problem
                                                        rotationTime: 1000 * 86400, // rotate every 20 seconds
                                                     //       ["page2"],           // class name for page 2
                                                    //        ["page3"],           // class name for page 3
                                                        hiddenPages: {
                                                    disabled: false,
                                                    header: "MPlayer",
                                            	  layout: 'column',
                                            	  monitorAspect: 0,
                                            	  rotate: -1,
                                            	  windowSize: { width: 640, height: 360 },
                                            	  streams: {
                                            		window1: [
                                            		window2: [
