    MMM-pages - how to know which page index my module has?
    29 Posts 4 Posters 10.5k Views 4 Watching
      @evroom
      from my SampleModule.js
      	// system notification your module is being hidden
      	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
      	suspend: function(){
      	// system notification your module is being unhidden/shown
      	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
      	resume: function(){
      S evroomE 2 Replies Last reply Reply Quote 0
        @evroom my MMM-SleepWake uses an external trigger to cause modules to be shown/hidden (screen saver where the screen won’t turn off)
        I provide a commandline command to interact with the module…
        i use a webcam with the motion project daemon to trigger show/hide
        • evroomE
          evroom @sdetweil
          Yeah, this module is kind of in my foster care.
          I did not come up with the code; only made some tweaks and made it available.
          There is not suspend or resume to been seen in the code.
          But I will study the stuff you mentioned and will try to implement that.
          Thx.
          MagicMirror version: 2.37.0
          • evroomE
            evroom @evroom
            As a workaround, I will make it a requirement to put the MMM-Player on the first page (page index 0).
            When I receive 0, then I will start streaming, otherwise I will stop streaming.
            That seems to work.
            evroomE M 3 Replies Last reply Reply Quote 0
            • evroomE
              evroom @evroom
              Short question:
              There are 2 versions of MMM-pages:
              https://github.com/edward-shen/MMM-pages
              https://github.com/sdetweil/MMM-pages
              They seem in-sync, but which one would be the preferred one to take?
                sdetweil @evroom
                @evroom the core function is the same
                i added the ability to have different page display times
                i wrote the doc on the fixed page name approach
                as you are using a notification now
                just move that to suspend (same as index=0)
                and the resume wakes you back up
                • plainbrokeP
                  plainbroke @sdetweil
                  He has the MMM-MPlayer working in pages and I am now using pages and MPlayer in my main MM.
                  Kinda of cool to be able to show a RSTP camera or 2 again…
                    sdetweil @plainbroke
                    @plainbroke cool
                      mvrlogins @evroom
                      @evroom said in MMM-pages - how to know which page index my module has?:
                      That seems to work.
                      Hi
                      Trying to use the mmm-mplayer module with mmm-pages, and it works fine, as you say, when the page index is 0.
                      However, I’d like to use it to only show video when called via notification
                      I have a single main page (without mplayer) - that shows all the time - and a single hidden page (with mplayer) to be shown when called via notification and then return the the main page with another notification.
                      I can’t currently implement this. Any ideas?
                      Thanks very much
                        sdetweil @mvrlogins
                        @mvrlogins why not? what triggers the notification??
                        button, command , …
                        you could prove this with the MMM-CommandtoNotification module
                          mvrlogins @sdetweil
                          I’m using MMM-Remote Control
                          The issue is that the video is shown all the time on page0.
                          I have 2 pages set up with MMM-Pages
                          • 1 page to be shown all the time
                          • 1 hidden page to be shown only when called.
                          The video needs to be on the hidden page. If I put classes : “hidden_page” under MMM-Player, the video feed shows on the page0 regardless.
                          The hidden page, when called, shows only the header fro MMM-Player and is otherwise blank
                          The page calling works fine with MMM-RemoteControl
                                  module: "MMM-pages",
                                      rotationTime: 1000 * 20, // rotate every 20 seconds
                                          ["page1"],           // class name for page 1
                                      fixed: ["fixed_page"],
                                      hiddenPages: {
                                          "Doorbell": ["doorbell_page"],
                          and
                          	module: 'MMM-MPlayer',
                                  classes: "doorbell_page",
                                  disabled: false,
                                  header: "MPlayer",
                          	  useTwoWindows: true,
                          	  layout: 'column',
                          	  monitorAspect: 0,
                          	  rotate: -1,
                          	  windowSize: { width: 640, height: 480 },
                          	  windowPosition: { x: 5, y: 225 },
                          	  streamInterval: 30000,
                          	  streams: {
                          		window1: [
                          		  'rtsp://10.0.1.1:7447/gv9eHrB9yZyPhgvN',
                          		window2: [
                          		  'rtsp://10.0.1.1:7447/D89zTJyDwN8YtKix',
                            mvrlogins @mvrlogins
                            Only thing I can think of right now is to put the video on page0 and the rest on page1
                            and then use a combination of the PAGE_CHANGED and PAUSE_ROTATION notifications to get what I want
                            Or is there a way to permanently pause rotation?
                            Then I can only use the PAGE_CHANGED call to get to the page I want
                            would the below disable rotation?
                            rotationTime: 1000 * 0,
                              sdetweil @mvrlogins
                              @mvrlogins i believe so. but you should have been able to send the notification for the named hidden page
                              “SHOW_HIDDEN_PAGE”, “Doorbell”
                              right?!
                                mvrlogins @sdetweil
                                @sdetweil said in MMM-pages - how to know which page index my module has?:
                                right?!
                                Yes, the notification works fine.
                                But mplayer does not show up on the hidden page, only on the main page
                                  sdetweil @mvrlogins
                                  @mvrlogins hm, that makes no sense as the MagicMirror operations are the same
                                    sdetweil @mvrlogins
                                    @mvrlogins i opened this issue
                                    https://github.com/evroom/MMM-MPlayer/issues/4
                                    try my fork
                                    cd ~/MagicMirror/modules
                                    rename the existing folder out of the way
                                    git clone https://github.com/sdetweil/MMM-MPlayer
                                    change the page config to have the hidden page and the
                                    remote_control notification
                                    I submitted this change to the module for inclusion, depending on your results.
                                      mvrlogins @sdetweil
                                      Maybe something to do with mplayer itself, not the module MMM-Mplayer?
                                        sdetweil @mvrlogins
                                        @mvrlogins no, i fixed in my fork
                                          mvrlogins @sdetweil
                                          Did as you suggested
                                          The video appears only on page index 0 and not on the hidden page
                                          See the 2 video images on the attached screenshot - both are over the weather module
                                          The header for the MPlayer appears on the hidden page
                                          I can change to the hidden page with Remote Control, no problem
                                                      rotationTime: 1000 * 86400, // rotate every 20 seconds
                                                   //       ["page2"],           // class name for page 2
                                                  //        ["page3"],           // class name for page 3
                                                      hiddenPages: {
                                                  disabled: false,
                                                  header: "MPlayer",
                                          	  layout: 'column',
                                          	  monitorAspect: 0,
                                          	  rotate: -1,
                                          	  windowSize: { width: 640, height: 360 },
                                          	  streams: {
                                          		window1: [
                                          		window2: [
                                            mvrlogins @evroom
                                            That seems to work.
                                            @sdetweil Maybe something to do with this?
