Google Photos API changing - MMM-GooglePhotos will stop working soon.
20 Posts 3 Posters 1.2k Views 3 Watching
  • G Offline
    gonzonia
    With the Google API changing , the MMM-GooglePhotos module is going to stop working Unless someone develops a way to utilize the new picker API. It looks like the users will need to select photos to share with the application.
    This would change the workflow and I’m not sure how it would be implemented.
    S 1 Reply Last reply Feb 20, 2025, 2:06 PM Reply Quote 0
    • S Away
      sdetweil @gonzonia
      @gonzonia this is a really sad…
      G 1 Reply Last reply Feb 20, 2025, 2:11 PM Reply Quote 0
      • G Offline
        gonzonia @sdetweil
        @sdetweil I know! This is the highlight of my MM. Without it, I think other members of my family will certainly be less impressed. I understand the logic on google’s part, but I wish there was a way on the photos side to share with the application instead of having to implement the picker in the application.
        S 1 Reply Last reply Feb 20, 2025, 2:12 PM Reply Quote 0
        • S Away
          sdetweil @gonzonia
          @gonzonia yeh… and the way I read the doc says you have to pick the individual media items… not a folder…
          G 1 Reply Last reply Feb 21, 2025, 7:43 PM Reply Quote 0
          • G Offline
            gonzonia @sdetweil
            @sdetweil I have an idea but I’m not sure how to make it happen.
            I’m not a module developer beyond being able to adjust some code here and there.
            Maybe if you have time, you can think about if it’s possible?
            What if there was a config flag for “PickPhotos” that if it was true, it would open a picker interface. Then after it’s been done, the user can re-set it to false and the module can go back to just loading photos.
            I’m sure there are some other tweaks to the API that will impact this but it’s the only thought I’ve had so far to implement something inside the existing framework.
            S 1 Reply Last reply Feb 22, 2025, 2:24 PM Reply Quote 0
            • S Away
              sdetweil @gonzonia
              @gonzonia one could launch a web app maybe via phone to access the picker?
              G 1 Reply Last reply Feb 22, 2025, 3:10 PM Reply Quote 0
              • G Offline
                gonzonia @sdetweil
                @sdetweil Maybe. I don’t know how the picker stores the relationship to the app and the permissions. If it’s in the browser in some way, launching from a phone might not work. It might need to be from the browser on the MM.
                S 1 Reply Last reply Feb 22, 2025, 4:04 PM Reply Quote 0
                • S Away
                  sdetweil @gonzonia
                  @gonzonia it wont be in the browser, they will want to control it at the access level
                  S 1 Reply Last reply Feb 22, 2025, 6:44 PM Reply Quote 0
                  • S Away
                    @gonzonia
                    gp app is the ONLY way to pick images
                    the selected pics access times out after an hour!!!
                    G 1 Reply Last reply Feb 22, 2025, 7:04 PM Reply Quote 0
                    • G Offline
                      gonzonia @sdetweil
                      @sdetweil so the user wouldn’t have to Re-select after an hour? That can’t be right.
                      S 1 Reply Last reply Feb 22, 2025, 7:18 PM Reply Quote 0
