    starter problem # 2
    27 Posts 4 Posters 19.2k Views 4 Watching
    • K
      kurt @morozgrafix
      @morozgrafix
      Thanks for the help
      The for me funny thing is, if I do it with SSH and the DISPLAY=:0 npm startthe MM starts (exept the rss fees and the amer. calender…both loading), but when I try to start it from the Raspberry with the npm start I get some error messages.
      When I reboot,the MM routine starts but does not finish and i’m back in The PIXEL surface.
      Do you think I should try the Auto Starting Mirror tool?
      https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
      Any ideas?
      morozgrafixM 1 Reply Last reply
      • morozgrafixM
        morozgrafix Moderator @kurt
        @kurt said in starter problem # 2:
        What error messages are you getting when you running npm start from the RasPi terminal? (I’m assuming that you still have PIXEL loaded at that time)
        I would hold off on auto starting for now, until you can start it cleanly from the shell.
        K 2 Replies Last reply
        • K
          kurt @morozgrafix
          @morozgrafix
          hey by now the MM startet without error massages! kind of strange, but I get used to it.
          Then I copied the confi.js file to send it to you, maybe you can find a mistake.
          But after that all of my MM folder is gone ! this what happened to me 3 days ago.
          Can#t believe, but that’s how it is . everything gone.
          I can only blame FileZilla for that. Iguess I have to go to the Install routine for the third time. and I’m thru with Filzilla…
          What do you think about it? can I restore something? I searched in all folders but coudn’t find anything.
          Man I expected a hard way to go, but this is boring. What to do?
          Thanks for waiting
          Kurt
          • K
            kurt @morozgrafix
            @morozgrafix
            here that last try
            Last login: Wed Jan 25 19:03:13 on ttys000
            Kurt-Matyuss-iMac:~ kurt$ cd ~/MagicMirror
            -bash: cd: /Users/kurt/MagicMirror: No such file or directory
            Kurt-Matyuss-iMac:~ kurt$ `
            too bad
            R 1 Reply Last reply
              roramirez Core Contributors @kurt
              Hey @kurt !, the last sentence you are run in your Mac not in your Raspberry
              K 1 Reply Last reply
              • K
                kurt @roramirez
                @roramirez
                yes I did it on my mac via SSH
                  @kurt No, when you run cd command you are still in your Mac
                  • K
                    kurt @roramirez
                    @roramirez
                    sorry you are right, but
                    Last login: Wed Jan 25 19:24:58 2017
                    pi@raspi:~ $ cd ~/MagicMirror
                    -bash: cd: /home/pi/MagicMirror: Datei oder Verzeichnis nicht gefunden
                    pi@raspi:~ $
                      @kurt Ok, is nothing there. Please use the installer script
                      curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                      If you using Jessie Lite will need install some packages as say link of @morozgrafix’s post
                      • K
                        kurt @roramirez
                        @roramirez
                        Thank you, that’s what i’ll do.
                        But do you have any idea, why this happens. Just to avoid to make the same mistake again.
                        I intend to use Cyber Duck for transfering folders or scripts.
                        And I also use the VNC Viewer, just to see what happens next door, while I work on my mac in an other room.
                        And I think I’ll install the full Jessi Version.
                        So Thank’s once again! without you It engineers, students and helpers in this forum, users like me were just lost and couldn’t be part of this great projekt, which has just started…
                        Kurt
                        • morozgrafixM
                          if you are comfortable with using ssh and scp you may not even need any GUI tools to transfer files.
                            @kurt Well Jessie Lite dont have X system. X mean desktop system, GUI.
                            MagicMirror run in Electron and this require a DISPLAY system where show it.
                            We working in this topic to prevent you when is using in a system like that.
                            https://github.com/MichMich/MagicMirror/issues/577
                            • K
                              kurt @morozgrafix
                              @morozgrafix
                              Well I’m absolut not comfortable with transfering files or scripts without the help of an grafical surface.
                              I´m absolute new to work with commands on a terminal.
                              So the all the commands I type into the terminal Ijust learned from guys like you just a couple of days ago.
                              When you change the content, lets say from an config.js via SSH. What kind of tools do you use?
                              Because when I opened the folders of my Raspberry with the help of FileZilla, changed the content and tried to save, the MM system collapsed somehow.
                              So my question how do you that?
                              Thanks a lot for the help
                              • K
                                kurt @roramirez
                                @roramirez
                                Well as I explained in the reply to morozgrafik i’m used to GUI and for me it’s fine doing things by drag and drop…
                                I apreciate your work and input into this projekt a lot!
                                What is your opinion to run the installer by the sudo command like alostvagabond postet it in https://github.com/MichMich/MagicMirror/issues/577
                                I’ll start my atempt #3 in the afternoon :)
                                Thanks a lot for your help
                                • morozgrafixM
                                  @kurt I totally understand your point and reasons for you to use GUI tools for file transfers, editing etc. My personal choice is mostly working in the terminal, but it takes some getting used to. The reason why I mentioned SSH and scp, as alternative to using GUI transfer tools, is because they are very reliable and proven to work well. I just wanted to check your comfort level using them, in case that you are suspecting FileZilla, Cyber Duck or some other GUI tool is messing up your MM installation.
                                  To answer your question about text editors that work in terminal. There are plenty of them and they have existed for a very long time in unix/linux world. Most of the time they are available with any *nix flavor. To name a few: nano (probably easiest to learn), vim and emacs
                                  Hope you get everything sorted with your install and if you need assistance we are here to help.
                                  • K
                                    kurt @morozgrafix
                                    @morozgrafix @roramirez
                                    Well by now I get a little install and setup routine so MM is running with personalized compliments and newsfeed. Everything was done without SSH so direkt on the console.
                                    What I noticed was, and this is one of my questions, when I changed from GUI to terminal by strg alt F4 the layout from my keyboard changed to english, what made it hard for me to enter a ~. can’t find it on a windows keyboard also I googled a lot.
                                    So how do you change from the GUI to Terminal, to make some changes?
                                    After all I’m quite happy to have come so far.
                                    lot of traffic in the forum, often get 503the croud is getting bigger :)
                                    PS: @morozgrafix nice background in your profile, like that
                                    Thank you
                                    Kurt
                                    • K
                                      kurt @kurt
                                      found at least the command strg q makes the change
                                      kurt
                                      • morozgrafixM
                                        @kurt I’m not in front of my RasPi at the moment and can’t give you exact instructions, doing it from memory. Hitting Ctrl Alt F1 will drop you into terminal session, hitting Ctrl Alt F7 (if I’m not mistaken) will take you back to X window session. You can try switching to different sessions by hitting Ctrl Alt F1, Ctrl Alt F2 etc. until you get to the right place.
                                        If you are running full Jessie with PIXEL there is also a terminal app in GUI that you can use. Some more info on PIXEL is here
                                        PIXEL Menu
                                        :point_up: see that Terminal Icon? That way you don’t have to switch back and forth.
                                        If you are running Jessie Lite you can hit Windows Key + R (sorry I’m not really sure what the correct terminology for Windows Key on your keyboard) and type lxterminal
                                        and you will have a terminal session in your GUI! It will look something like this (sorry that’s a huge image):
                                        lxterminal in LXDE
                                        On US English keyboard layout ~ is located to the left of the 1 key and you have to use Shift, but good news is that you can change default RasPi keyboard layout to match your locale by running sudo raspi-config in terminal. Some more information on how to get it done is here: https://www.raspberrypi.org/documentation/configuration/raspi-config.md#change-locale
                                        Good luck and I’m glad you are making progress.
                                        P.S. Thanks about compliments on the profile background. It’s a macro photo of a DVD-R disc that was cooked in the microwave. I have a few more from that series here https://www.flickr.com/photos/morozgrafix/albums/72157626165398064
                                        • K
                                          kurt @morozgrafix
                                          @morozgrafix
                                          Wow Thanks a lot man for the detailed help inkl. the screenshotsand the links, that’s exactly what absolut beginners need! Some more usefull commands for me to collect.
                                          And what a strange idea to put DVD-R into a microwave :) But the result is awsome. I like the one with the waterdrops best.
                                          Kurt
                                          • K
                                            kurt @morozgrafix
                                            @morozgrafix
                                            Here some information about my last progress :)
                                            When I informed you that my MM is running, that was in the evening.
                                            I shutdown and after some while I took the raspberry away from the electricity.
                                            Next morning no reaction, no booting, no green lamp… When I put the SD Card 32 GB into my mac also nothing was shown. No card at all.
                                            Could’t find out whatever the reason was for this mistake and I don’t care.
                                            As I got a second card 16 GB, I did once again all the Installation sucessfully!
                                            System running inkl. some 3rd party modules, which I managed to put in.
                                            Once again Thank you and @roramirez, @In_a_days, @yawns,
                                            @strawberry-3.141 and all the other guys for your help and time
                                            Feels like the way is the goalfor me :)
                                            Kurt
