    starter problem # 2
    27 Posts 4 Posters 17.4k Views 4 Watching
    • K Offline
      kurt @tosti007
      @tosti007
      That’s what I got
      pi@raspi:~ $ cd ~/MagicMirror
      pi@raspi:~/MagicMirror $ npm install
      npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
      morozgrafixM 1 Reply Last reply Reply Quote 0
      • morozgrafixM Offline
        morozgrafix Moderator @kurt
        @kurt are you running raspbian jessie or Jessie lite?
        If you are running regular jessie with graphical interface then I believe you need to run npm start in the terminal. DISPLAY=:0 npm start is used when you are connected over SSH from remote system, if I’m not mistaken.
        If you are running jessie lite then make sure you have minimal X window GUI installed. Full guide is here https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
        • K Offline
          kurt @morozgrafix
          @morozgrafix
          Thanks for the help
          The for me funny thing is, if I do it with SSH and the DISPLAY=:0 npm startthe MM starts (exept the rss fees and the amer. calender…both loading), but when I try to start it from the Raspberry with the npm start I get some error messages.
          When I reboot,the MM routine starts but does not finish and i’m back in The PIXEL surface.
          Do you think I should try the Auto Starting Mirror tool?
          https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
          Any ideas?
            @kurt said in starter problem # 2:
            What error messages are you getting when you running npm start from the RasPi terminal? (I’m assuming that you still have PIXEL loaded at that time)
            I would hold off on auto starting for now, until you can start it cleanly from the shell.
            K 2 Replies Last reply Reply Quote 0
            • K Offline
              kurt @morozgrafix
              @morozgrafix
              hey by now the MM startet without error massages! kind of strange, but I get used to it.
              Then I copied the confi.js file to send it to you, maybe you can find a mistake.
              But after that all of my MM folder is gone ! this what happened to me 3 days ago.
              Can#t believe, but that’s how it is . everything gone.
              I can only blame FileZilla for that. Iguess I have to go to the Install routine for the third time. and I’m thru with Filzilla…
              What do you think about it? can I restore something? I searched in all folders but coudn’t find anything.
              Man I expected a hard way to go, but this is boring. What to do?
              Thanks for waiting
              Kurt
              • K Offline
                kurt @morozgrafix
                @morozgrafix
                here that last try
                Last login: Wed Jan 25 19:03:13 on ttys000
                Kurt-Matyuss-iMac:~ kurt$ cd ~/MagicMirror
                -bash: cd: /Users/kurt/MagicMirror: No such file or directory
                Kurt-Matyuss-iMac:~ kurt$ `
                too bad
                  roramirez Core Contributors @kurt
                  Hey @kurt !, the last sentence you are run in your Mac not in your Raspberry
                  • K Offline
                    kurt @roramirez
                    @roramirez
                    yes I did it on my mac via SSH
                      @kurt No, when you run cd command you are still in your Mac
                      • K Offline
                        kurt @roramirez
                        @roramirez
                        sorry you are right, but
                        Last login: Wed Jan 25 19:24:58 2017
                        -bash: cd: /home/pi/MagicMirror: Datei oder Verzeichnis nicht gefunden
                        pi@raspi:~ $
