    starter problem # 2
    27 Posts 4 Posters 18.2k Views 4 Watching
    • K Offline
      kurt
      Hi
      ( I guess I put the Raspberry too quick away from the electricity, which caused a total colapse of the Raspberry- so all you newbies like me, beware of that step!).
      I open this new topic, because after the new installation of the MM I get this message below and this has nothing to do with the problems in my older topic.
      Also tried to google a solution for the npm bugs magicmirror, but couldn’t find a right solution for me.
      I just installed MM and only changed the url in the newsfeed and the weather destination in the config.js
      So I hope someone here can help me to do the next step.
      Thanks a lot
      Kurt
      pi@raspi:~ $ cd ~/MagicMirror
      pi@raspi:~/MagicMirror $ DISPLAY=:O npm start
      > magicmirror@2.1.0 start /home/pi/MagicMirror
      > electron js/electron.js
      npm ERR! Linux 4.4.38-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
      npm ERR! node v6.9.4
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     electron js/electron.js
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
      • tosti007T Offline
        tosti007 Module Developer
        Did you do npm install in your ~/MagicMirror folder?
        If there is anything don't hesitate to contact me!
        ProfileSwitcher, TouchNotifications
        K 2 Replies Last reply Reply Quote 0
        • K Offline
          kurt @tosti007
          @tosti007
          No, I just followed the complete setup tutorial by KirAsh4
          so do I have to install it?
          Thank you
          • K Offline
            kurt @tosti007
            @tosti007
            That’s what I got
            pi@raspi:~/MagicMirror $ npm install
            npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
            morozgrafixM 1 Reply Last reply Reply Quote 0
            • morozgrafixM Offline
              morozgrafix Moderator @kurt
              @kurt are you running raspbian jessie or Jessie lite?
              If you are running regular jessie with graphical interface then I believe you need to run npm start in the terminal. DISPLAY=:0 npm start is used when you are connected over SSH from remote system, if I’m not mistaken.
              If you are running jessie lite then make sure you have minimal X window GUI installed. Full guide is here https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
              • K Offline
                kurt @morozgrafix
                @morozgrafix
                Thanks for the help
                The for me funny thing is, if I do it with SSH and the DISPLAY=:0 npm startthe MM starts (exept the rss fees and the amer. calender…both loading), but when I try to start it from the Raspberry with the npm start I get some error messages.
                When I reboot,the MM routine starts but does not finish and i’m back in The PIXEL surface.
                Do you think I should try the Auto Starting Mirror tool?
                https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                Any ideas?
                  @kurt said in starter problem # 2:
                  What error messages are you getting when you running npm start from the RasPi terminal? (I’m assuming that you still have PIXEL loaded at that time)
                  I would hold off on auto starting for now, until you can start it cleanly from the shell.
                  • K Offline
                    kurt @morozgrafix
                    @morozgrafix
                    hey by now the MM startet without error massages! kind of strange, but I get used to it.
                    Then I copied the confi.js file to send it to you, maybe you can find a mistake.
                    But after that all of my MM folder is gone ! this what happened to me 3 days ago.
                    Can#t believe, but that’s how it is . everything gone.
                    I can only blame FileZilla for that. Iguess I have to go to the Install routine for the third time. and I’m thru with Filzilla…
                    What do you think about it? can I restore something? I searched in all folders but coudn’t find anything.
                    Man I expected a hard way to go, but this is boring. What to do?
                    Thanks for waiting
                    Kurt
                    • K Offline
                      kurt @morozgrafix
                      @morozgrafix
                      here that last try
                      Last login: Wed Jan 25 19:03:13 on ttys000
                      Kurt-Matyuss-iMac:~ kurt$ cd ~/MagicMirror
                      -bash: cd: /Users/kurt/MagicMirror: No such file or directory
                      Kurt-Matyuss-iMac:~ kurt$ `
                      too bad
                        roramirez Core Contributors @kurt
                        Hey @kurt !, the last sentence you are run in your Mac not in your Raspberry
                        • K Offline
                          kurt @roramirez
                          @roramirez
                          yes I did it on my mac via SSH
                            @kurt No, when you run cd command you are still in your Mac
                            • K Offline
                              kurt @roramirez
                              @roramirez
                              sorry you are right, but
                              Last login: Wed Jan 25 19:24:58 2017
                              -bash: cd: /home/pi/MagicMirror: Datei oder Verzeichnis nicht gefunden
                              pi@raspi:~ $
                                @kurt Ok, is nothing there. Please use the installer script
                                curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                                If you using Jessie Lite will need install some packages as say link of @morozgrafix’s post
                                • K Offline
                                  kurt @roramirez
                                  @roramirez
                                  Thank you, that’s what i’ll do.
                                  But do you have any idea, why this happens. Just to avoid to make the same mistake again.
                                  I intend to use Cyber Duck for transfering folders or scripts.
                                  And I also use the VNC Viewer, just to see what happens next door, while I work on my mac in an other room.
                                  And I think I’ll install the full Jessi Version.
                                  So Thank’s once again! without you It engineers, students and helpers in this forum, users like me were just lost and couldn’t be part of this great projekt, which has just started…
                                  Kurt
                                    if you are comfortable with using ssh and scp you may not even need any GUI tools to transfer files.
                                    K 1 Reply Last reply Reply Quote 1
                                      @kurt Well Jessie Lite dont have X system. X mean desktop system, GUI.
                                      MagicMirror run in Electron and this require a DISPLAY system where show it.
                                      We working in this topic to prevent you when is using in a system like that.
                                      https://github.com/MichMich/MagicMirror/issues/577
                                      • K Offline
                                        kurt @morozgrafix
                                        @morozgrafix
                                        Well I’m absolut not comfortable with transfering files or scripts without the help of an grafical surface.
                                        I´m absolute new to work with commands on a terminal.
                                        So the all the commands I type into the terminal Ijust learned from guys like you just a couple of days ago.
                                        When you change the content, lets say from an config.js via SSH. What kind of tools do you use?
                                        Because when I opened the folders of my Raspberry with the help of FileZilla, changed the content and tried to save, the MM system collapsed somehow.
                                        So my question how do you that?
                                        Thanks a lot for the help
                                        • K Offline
                                          kurt @roramirez
                                          @roramirez
                                          Well as I explained in the reply to morozgrafik i’m used to GUI and for me it’s fine doing things by drag and drop…
                                          I apreciate your work and input into this projekt a lot!
                                          What is your opinion to run the installer by the sudo command like alostvagabond postet it in https://github.com/MichMich/MagicMirror/issues/577
                                          I’ll start my atempt #3 in the afternoon :)
                                          Thanks a lot for your help
                                            @kurt I totally understand your point and reasons for you to use GUI tools for file transfers, editing etc. My personal choice is mostly working in the terminal, but it takes some getting used to. The reason why I mentioned SSH and scp, as alternative to using GUI transfer tools, is because they are very reliable and proven to work well. I just wanted to check your comfort level using them, in case that you are suspecting FileZilla, Cyber Duck or some other GUI tool is messing up your MM installation.
                                            To answer your question about text editors that work in terminal. There are plenty of them and they have existed for a very long time in unix/linux world. Most of the time they are available with any *nix flavor. To name a few: nano (probably easiest to learn), vim and emacs
                                            Hope you get everything sorted with your install and if you need assistance we are here to help.
