    Calendar config
    14 Posts 5 Posters 17.0k Views 4 Watching
      A Former User @in_a_days
      So I added the bracket, but still get the ‘please create a config file’, which is what I get when I add something new and inevitably mess something up.
      • mochmanM
        mochman Module Developer
        Try putting your config.js in a website like http://jshint.com/. It should help you find any brackets you might be missing.
        ? 1 Reply Last reply
          A Former User @mochman
          @mochman How do I know what needs to be changed though? It’s finding a lot of issues, even with the default code that I’ve not changed?
          Ater adding that } , it’s complaining about double quotes instead of singular, unexpected label ‘modules’, and expected an identifier and instead saw ‘}’.
          It doesn’t seem to be geared towards the code for Magic Mirror?
          mochmanM 1 Reply Last reply
          • yawnsY
            yawns Moderator
            Please post your entire config
            btw … I don’t know for google calendars, but I replaced https with webcal for my outlook.com calendar.
            • mochmanM
              mochman Module Developer @Guest
              @JbeesonMagic16 No, it’s a general javascript problem finder. If you paste your config.js file in it’s entirety into http://jshint.com/. You should see it say “One undefined variable”. If you see
              Expected '}' to match '{' from line XXX and instead saw ']'
              You are missing a bracket. Look at line XXX and then follow the code down to see where the missing bracket is.
              • in_a_daysI
                in_a_days
                The full config file will definitely help. You also have one more small typo here -
                    url: 'htpps://calendar.google.com/calendar/ical/ME%40gmail.com/public/basic.ics'
                that should probably be ‘https’ rather than ‘htpps’ but I don’t think this should be breaking your config.
                  @in_a_days Nice catch! I fixed it, but yeah, it wasn’t the source.
                    A Former User
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                            port: 8080,
                            language: 'en',
                            timeFormat: 12,
                            units: 'imperial',
                                            module: 'alert',
                                            module: "updatenotification",
                                            position: "top_bar"
                                            module: 'clock',
                                            position: 'top_left'
                                            module: 'calendar',
                                            header: 'Calender',
                                            position: 'top_left',
        symbol: 'calendar-check-o ',
        url: 'https://calendar.google.com/calendar/ical/ME%40gmail.com/public/basic.ics'
        url: 'https://calendar.google.com/calendar/ical/WIFE%40gmail.com/public/basic.ics'
                                            module: 'compliments',
                                            position: 'lower_third'
                                            module: 'MMM-WunderGround',
                                            position: 'top_right',
                                                    apikey: 'MYKEY',
                                                    pws: 'pws:KMOOFALL59',
                                                    hourly: '1',
                                                    fctext: '1',
                                                    fcdaycount: "5",
                                                    fcdaystart: "0",
                                                    hourlyinterval: "3",
                                                    hourlycount: "2",
                                                    alerttime: 10000,
                                                    alerttruncatestring: "english:",
                                            roundTmpDecs: 1,
                                            UseCardinals: 0,
                                            layout: "horizontal",
                                            sysstat: 0
                                            module: 'newsfeed',
                                            position: 'bottom_bar',
                                                    feeds: [
        title: "New York Times",
                                                    showSourceTitle: true,
                                                    showPublishDate: true
                    Also modified the API to hide it in the weather section, but it’s there. JShint gave me 4 errors, but I was going off that link from the other question for syntax, so I’m not 100% what needs to be removed or added.
                    Four warnings
                    46 Expected ‘]’ to match ‘[’ from line 15 and instead saw ‘{’.
                    47 Expected ‘}’ to match ‘{’ from line 7 and instead saw ‘module’.
                    47 Missing semicolon.
                    47 Unrecoverable syntax error. (52% scanned).
                    in_a_daysI 1 Reply Last reply
                    • in_a_daysI
                      in_a_days @Guest
                      @JbeesonMagic16
                      add a comma here:
                      so it looks like this
                      See if that solves it.
                      Reply Quote 2
                      • mochmanM
                        @JbeesonMagic16 Yeah, @in_a_days recommendation fixes the problems in the jshint. Hopefully that works for you.
                        Reply Quote 2
                          Nice, that does get it working again, but no go on the calendars actually showing up. I found a private link to google calendars ical, which makes sense since I’m not sharing my calendar with the public. So I used that link, and they work now. Thanks to all of you for your help!!
                          Mykle1M 1 Reply Last reply
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @Guest
                            @JbeesonMagic16
                            I almost posted the same exact problem but I found this page (thread?) (Whatever), but due to the help you received and your last comment about the private link to google calendars ical, I was able to resolve the issue without asking the question. This place is awesome. :-)
                            Up votes for everyone!
