Netatmo module will not shown
hello everyone, i have a netatmo station with with an out sensor and a windsensor and rain sensor…now i will show it on the MM but it will not show. Can everyone help me…i installed the module from fenner here:
https://github.com/CFenner/MMM-Netatmo
an my Config will show so:
{ module: 'netatmo', position: 'top_right', // the location where the module should be displayed header: 'Netatmo', // a header if you like one config: { clientId: 'xxec', // your app id clientSecret: '123', // your app secret refresh_token: '12345', // your generated refresh token refreshInterval: '3', dataOrder: ["Noise","Pressure","CO2","Humidity","Temperature","Rain"], design: 'bubbles', horizontal: 'true', showBattery: 'true', showWiFi: 'true', showTrend: 'true', showMeasurementIcon: 'true', showStationName: 'true', showModuleNameOnTop: 'false', fontClassModuleName: 'xsmall', fontClassPrimary: 'xsmall', fontClassSecondary: 'xsmall', fontClassMeasurement: 'xsmall', thresholdCO2Average: '1200', thresholdCO2Bad: '1800', } },
It´s only standing “Netatmo load”
about an answer thanks a lot in future
@Lusbueb said in Netatmo module will not shown:
@kusselin
In your configuration, I’m missing the entry modulOrder. This entry was essential for me! I initially used the default name until I realized that it only works if the module name is stored exactly as you configured it in the web-app (https://auth.netatmo.com/de-de/access/login):my config:
{ module: 'netatmo', position: 'middle_center', // the location where the module should be displayed config: { clientId: '*myID*', // your app id clientSecret: '*mysecret*', // your app secret refresh_token: *'mytoken*', // your generated refresh token moduleOrder: ["Outdoor","Regen","Wind","Schlafzimmer","Wohnzimmer"], //take same names from web-app! updateInterval: 6, // every 3 minutes, refresh interval on netatmo is 10 minutes animationSpeed: 1000, design: 'bubbles', // classic or bubbles horizontal: false, lastMessageThreshold: 600, // in seconds (10 minutes) showLastMessage: true, showBattery: true, showRadio: true, showWiFi: true, showTrend: true, showMeasurementIcon: true, showMeasurementLabel: true, showStationName: false, showModuleNameOnTop: true, fontClassModuleName: 'small', // xsmall, small, medium, large, xlarge fontClassPrimary: 'large', fontClassSecondary: 'xsmall', fontClassMeasurement: 'xsmall', thresholdCO2Average: 800, thresholdCO2Bad: 1800, mockData: false, } },
Thanks s lot for your config…i changed it and now ist good and the netatmo Modul is running very well
Is no one here who can help me for the Netatmo module and the Config?Best regsrds all in advance
@kusselin Are there any error messages?
Check log as well as dev-console …
“Netatmo load” could be an indicator that module stucks in the middle of nowhere…Regards,
Ralf -
@kusselin
Also check that your registration is correct. Make sure you have a current “token.js”. -
@rkorell said in Netatmo module will not shown:
RalfHello, thank you for the information.
Here from the console in Mozilla Firefox with the F12 keyInitializing MagicMirror². main.js:582:8 Bootstrapping module: alert loader.js:151:7 Bootstrapping module: updatenotification loader.js:151:7 Bootstrapping module: clock loader.js:151:7 Bootstrapping module: calendar loader.js:151:7 Bootstrapping module: compliments loader.js:151:7 Bootstrapping module: MMM-OpenmapWeather loader.js:151:7 Bootstrapping module: netatmo loader.js:151:7 Bootstrapping module: MMM-Blitzer loader.js:151:7 Bootstrapping module: MMM-F1 loader.js:151:7 Bootstrapping module: MMM-ApothekenNotdienst loader.js:151:7 Bootstrapping module: MMM-ioBroker loader.js:151:7 Bootstrapping module: MMM-Carousel loader.js:151:7 Bootstrapping module: MMM-PublicTransportHafas loader.js:151:7 Bootstrapping module: MMM-RNV loader.js:151:7 Bootstrapping module: MMM-Fuel loader.js:151:7 Bootstrapping module: MMM-Carousel loader.js:151:7 Bootstrapping module: MMM-Remote-Control loader.js:151:7 Bootstrapping module: newsfeed loader.js:151:7 Starting module: alert alert.js:43:7 Starting module: updatenotification updatenotification.js:19:7 Starting module: clock clock.js:43:7 Starting module: calendar calendar.js:96:7 Starting module: compliments compliments.js:40:7 Starting module: MMM-OpenmapWeather MMM-OpenmapWeather.js:127:7 Starting module: netatmo netatmo.js:71:9 Starting module: MMM-F1 MMM-F1.js:24:13 Starting module: MMM-ApothekenNotdienst with identifier: module_10_MMM-ApothekenNotdienst MMM-ApothekenNotdienst.js:13:9 Starting module: MMM-ioBroker MMM-ioBroker.js:52:9 Starting module: MMM-Carousel with identifier: module_12_MMM-Carousel MMM-Carousel.js:99:9 Starting module: MMM-PublicTransportHafas with identifier: module_13_MMM-PublicTransportHafas MMM-PublicTransportHafas.js:61:9 Starting module: MMM-RNV MMM-RNV.js:14:664 Starting module: MMM-Fuel MMM-Fuel.js:180:13 Starting module: MMM-Carousel with identifier: module_16_MMM-Carousel MMM-Carousel.js:99:9 Starting module: MMM-Remote-Control MMM-Remote-Control.js:22:9 Starting module: newsfeed newsfeed.js:67:7 All modules started! main.js:601:8 sorting events count=0 calendar.js:704:7 slicing events total maxcount=10 calendar.js:744:7 sorting events count=63 calendar.js:704:7 sorting events count=10 calendar.js:704:7 slicing events total maxcount=10 calendar.js:744:7 event fullday 10 calendar.js:506:12 sorting events count=63 calendar.js:704:7 sorting events count=10 calendar.js:704:7 slicing events total maxcount=10 calendar.js:744:7 event fullday 10 calendar.js:506:12
Yes, I had them generate a token and ID for me on the developer page like on the Fenner github page.
Do I have to name my devices like this? I have a wind sensor, rain sensor and an outdoor station. Is that correct with humidity etc…in English? -
@det said in Netatmo module will not shown:
@kusselin
Also check that your registration is correct. Make sure you have a current “token.js”.Yes, what should I check there…is clearly described…the ClientSecret, the refresh_token and the ClientID…
the ID and the clientSecret are already there and the token can be generated with the “read station” in the selection.Do you also have netatmo running?
Generally speaking, it’s already running, isn’t it?
Where can i found the logs? under pm2 or npm?? i installed the MM from here in a proxmox container
https://community-scripts.github.io/ProxmoxVE/scripts?id=magicmirror
@kusselin so, where does the ui for this module run?
are you doing npm run server in the container?
this module depends on the ui running to kick off the helper
you should see messages wherever you start MagicMirror
npm start
pm2 launches a script, which does nom start or npm run server
then pm2 captures all the outputin a docker/proxmox container you should see the output in the container logs
Thank you. I installed MM using the proxmox helpers script. When I restart MM, it always starts automaticallylook please…can you see what:
root@magicmirror-live:/opt/magicmirror# npm run server > magicmirror@2.31.0 server > node ./serveronly [2025-04-25 19:25:22.927] [LOG] Starting MagicMirror: v2.31.0 [2025-04-25 19:25:22.939] [LOG] Loading config ... [2025-04-25 19:25:22.940] [LOG] config template file not exists, no envsubst [2025-04-25 19:25:23.250] [INFO] Checking config file /opt/magicmirror/config/config.js ... [2025-04-25 19:25:23.343] [INFO] Your configuration file doesn't contain syntax errors :) [2025-04-25 19:25:23.344] [INFO] Checking modules structure configuration ... [2025-04-25 19:25:23.398] [INFO] Your modules structure configuration doesn't contain errors :) [2025-04-25 19:25:23.787] [LOG] Loading module helpers ... [2025-04-25 19:25:23.797] [LOG] No helper found for module: alert. [2025-04-25 19:25:23.814] [LOG] Initializing new module helper ... [2025-04-25 19:25:23.822] [LOG] Module helper loaded: updatenotification [2025-04-25 19:25:23.822] [LOG] No helper found for module: clock. [2025-04-25 19:25:24.047] [LOG] Initializing new module helper ... [2025-04-25 19:25:24.047] [LOG] Module helper loaded: calendar [2025-04-25 19:25:24.048] [LOG] No helper found for module: compliments. [2025-04-25 19:25:24.048] [LOG] No helper found for module: MMM-OpenmapWeather. [2025-04-25 19:25:24.052] [LOG] Initializing new module helper ... [2025-04-25 19:25:24.052] [LOG] Module helper loaded: netatmo [2025-04-25 19:25:24.053] [WARN] No /opt/magicmirror/modules/MMM-OpenWeatherForecast/MMM-OpenWeatherForecast.js found for module: MMM-OpenWeatherForecast. [2025-04-25 19:25:24.053] [LOG] No helper found for module: MMM-OpenWeatherForecast. [2025-04-25 19:25:24.053] [LOG] No helper found for module: MMM-Blitzer. [2025-04-25 19:25:24.250] [LOG] Initializing new module helper ... [2025-04-25 19:25:24.251] [LOG] Module helper loaded: MMM-F1 [2025-04-25 19:25:24.252] [LOG] Initializing new module helper ... [2025-04-25 19:25:24.252] [LOG] Module helper loaded: MMM-ApothekenNotdienst [2025-04-25 19:25:24.253] [LOG] Initializing new module helper ... [2025-04-25 19:25:24.253] [LOG] Module helper loaded: MMM-ioBroker [2025-04-25 19:25:24.253] [LOG] No helper found for module: MMM-Carousel. [2025-04-25 19:25:24.256] [LOG] Initializing new module helper ... [2025-04-25 19:25:24.263] [LOG] Module helper loaded: MMM-PublicTransportHafas [2025-04-25 19:25:24.464] [LOG] Initializing new module helper ... [2025-04-25 19:25:24.465] [LOG] Module helper loaded: MMM-RNV [2025-04-25 19:25:24.465] [LOG] Initializing new module helper ... [2025-04-25 19:25:24.466] [LOG] Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.31.0 [2025-04-25 19:25:24.466] [LOG] Version is ok! [2025-04-25 19:25:24.466] [LOG] Module helper loaded: MMM-Fuel [2025-04-25 19:25:24.494] [LOG] Initializing new module helper ... [2025-04-25 19:25:24.495] [LOG] Module helper loaded: MMM-Remote-Control [2025-04-25 19:25:24.544] [LOG] Initializing new module helper ... [2025-04-25 19:25:24.545] [LOG] Module helper loaded: newsfeed [2025-04-25 19:25:24.545] [LOG] All module helpers loaded. [2025-04-25 19:25:24.549] [LOG] Starting server on port 8080 ... [2025-04-25 19:25:24.550] [WARN] You're using a full whitelist configuration to allow for all IPs [2025-04-25 19:25:24.561] [ERROR] Whoops! There was an uncaught exception... [2025-04-25 19:25:24.561] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080 at Server.setupListenHandle [as _listen2] (node:net:1939:16) at listenInCluster (node:net:1996:12) at node:net:2205:7 at process.processTicksAndRejections (node:internal/process/task_queues:90:21) { code: 'EADDRINUSE', errno: -98, syscall: 'listen', address: '0.0.0.0', port: 8080 } [2025-04-25 19:25:24.561] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [2025-04-25 19:25:24.561] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues [2025-04-25 19:25:24.648] [INFO] System information: ### SYSTEM: manufacturer: ; model: ; virtual: false ### OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: x64; kernel: 6.8.12-8-pve ### VERSIONS: electron: undefined; used node: 22.15.0; installed node: 22.15.0; npm: 10.9.2; pm2: 5.4.3 ### OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
@kusselin netatmo is not in the module list
also the address already in use means the server is running already from whatever script is launched at container startup
in container you cannot run manual npm run server if the container does that
same as if pm2 autostarted on native os or virtual machine
And what does that tell me now? Does that mean I can’t change anything…netatmo won’t work?
