    MMM-Todoist - Your todoist tasks on your mirror
    76 Posts 37 Posters 118.6k Views 39 Watching
    • cowboysdudeC
      cowboysdude Module Developer @JoeSpencer
      @JoeSpencer Yes I did that with a weather module and that fixed that also… sometimes those things just happen :)
        shutterclick
        I had the same problem, I don’t know if you’ve solved it yet but for me it turned out to be some simple mistakes.
        I thought I had followed the instructions to the letter, but actually at first I hadn’t cloned the module into the modules folder, just into the mirror folder. After cursing my own stupidity for that I carried on a while but still couldn’t get it working.
        I tried the tip for generating a new access token but that wasn’t it. I then realised that when I cloned the module (into the correct folder!) I missed the small but vital step of navigating into the new folder before carrying out npm install.
        I don’t know if any of you have made mistakes as daft as mine, but I finally got it working so thought I’d let you know.
        Hope it helps someone!
        • T
          tidus5 @shutterclick
          Yop,
          I’m looking to add the reminder and priority level (with an icon) Has anyone did something like that with this module ?
          in the fetcher i found where to add the var
          	 for (var i = 0; i < JSON.parse(body).items.length; i++) {
          		 if (JSON.parse(body).items[i].project_id == listID) {
          			 items.push(JSON.parse(body).items[i].content);
          			 items.push(JSON.parse(body).items[i].priority);
          			 items.push(JSON.parse(body).items[i].due_date_utc);
          but i dont know how to use the answer
          • T
            tidus5
            Yop,
            i did it :-)
            H D 2 Replies Last reply Reply Quote 3
            • O
              onetwankyfive
              Thanks for this module. Dropped Wunderlist in favor of this via Alexa integration.
              https://blog.todoist.com/2016/10/13/todoist-alexa-integration/
              • H
                hhaiii @tidus5
                @tidus5 This looks awesome - how did you implement? I just got my basic Todoist module running today
                  dinkybluebug245
                  Im having some issues with this module. When I add items to my todoist - it appears in the module, but when I mark them as completed , or they are deleted - the items dont come off the module - unless I add a new item onto the list. At that point, they disappear, and the new item gets added.
                  Very odd.
                  Ive raised it as an issue here: https://github.com/cbrooker/MMM-Todoist/issues/3
                  Any ideas why this might be?
                    shashank @dinkybluebug245
                    @dinkybluebug245 hi i added this module , when i add a item with Alexa voice , it gets added to inbox i could not able to get lists: [ 1234567890 ] number from the url
                    0_1485081729902_upload-88d37e27-8aef-4d99-b321-07b2922e3c9d
                    • O
                      onetwankyfive @shashank
                      @shashank click inbox instead of today
                        dakipro
                        I wanted to try to fix this module, but I have found that using the .ical export from todoist works great with official calendar module, so…
                          psm9
                          Hi, all,
                          Does anybody know how to sort this list? It adds new items at the bottom, so if there is no more room on the mirror, I can’t see them. I can’t figure out how to sort them on Todoist’s site easier, except alphabetically. I am using the “Alexa Shopping List” list in Todoist
                            svonbentzel @psm9
                            @psm9 said in MMM-Todoist - Your todoist tasks on your mirror:
                            Hi, all,
                            Hy, please can you post your working config for the Todoist module?
                            My Module is starting but the Todos are blank ;-)
                            Thank you
                              svonbentzel
                              i have figured out why the list is blank:
                              in MMM-Todoist.js is the default
                              Module.register("MMM-Todoist", {
                               defaults: {
                              	maximumEntries: 10,
                              	lists: ["inbox"],
                              	interval: 60,
                              	fade: true,
                              	fadePoint: 0.25
                              maybe a result of the fork from Wunderlist.
                              you can see that with pm2 logs
                              0|mm       | Create new todo fetcher for list: inbox - Interval: 60000
                              the added value in the config.js doesn’t accept.
                              so I write the correct list in MMM-Todoist.js
                               defaults: {
                              	maximumEntries: 10,
                              	lists: ["198511455"],
                              	interval: 60,
                              	fade: true,
                              	fadePoint: 0.25
                              save and restart MM with pm2 restart mm
                              then look at pm2 logs
                              |mm       | Create new todo fetcher for list: 198511455 - Interval: 60000
                              tadaaaa ;-) the correct fetcher ^^
                              but why the config.js variable not in use — I don’t know ;-)
                              • Y
                                yawns Moderator @svonbentzel
                                @svonbentzel
                                how does your config for this module look like?
                                  svonbentzel
                                  				        module: 'MMM-Todoist',
                                  				        position: 'bottom_center',  // This can be any of the regions. Best results in left or right regions.
                                  				        header: 'Todoist', // This is optional
                                  				        config: { // See 'Configuration options' for more information.
                                  				            accessToken: 'c7xxxxxxxxxxxxxxxxxxxxxxxe3b54',
                                  							//lists: ["edit in MMM-Todoist.js"],
                                  				            maximumEntries: 10,
                                  				            interval: 60,
                                  				            fade: true,
                                  this is my config.js
                                  you must edit the /home/pi/MagicMirror/modules/MMM-Todois/MMM-Todoist.js
                                  edit the list entry from list: [“inbox”] to [“1234567890”]
                                  defaults: {
                                  	maximumEntries: 10,
                                  	interval: 60,
                                  	fade: true,
                                  	fadePoint: 0.25
                                  • T
                                    tkotz8621
                                    Hi psm9… I’m fairly new to MagicMirror but I’ve been digging into the Todoist module to sort the list by due date. Did anyone ever answer your question? I didn’t see any responses to your sort question so I started digging into it and added code to the fetcher.js for MMM-Todoist.
                                    I’ve got it working on my mirror and when I add something that is due today… it will put it in the proper sequence on the next refresh. My JS skills are limited so the code may be made more efficient but it works. I’ll contact the Todoist author to see if I can add it to the module.
                                    P.S. I tried adding the code to this message but it did not take all 50 lines or so.
                                      cbrooker
                                      Hey guys,
                                      Very sorry that I have been MIA. I’ve been really busy with work and haven’t been able to give this any attention. I see a number of bugs and improvements in the thread. If you could submit your improvements and changes as Pull Request to the github repo, I’ll merge them in and everyone can have them. If not, I’ll try to add them in soon.
                                      Thanks,
                                      Chris
                                        Chiumanfu
                                        Is this module working for people? I’ve tried this one, MMM-Wunderlist and MMM-Wunderlist-Enhanced. They all behave similar. Some times they load the list, sometimes they don’t. When I add an item on my PC, it doesn’t show up in MM until reboot. I see reports of issues like this across all three modules. Since they are based on MMM-Wunderlist, maybe there is a problem in the base code?
                                        Here’s the log
                                        Create new todo fetcher for list: 2153843199 - Interval: 60000
                                        0|mm | Whoops! There was an uncaught exception…
                                        0|mm | TypeError: Cannot read property ‘substring’ of null
                                        0|mm | at Request._callback (/home/pi/MagicMirror/modules/MMM-Todoist/fetcher.js:69:35)
                                        0|mm | at Request.self.callback (/home/pi/MagicMirror/modules/MMM-Todoist/node_modules/request/request.js:188:22)
                                        0|mm | at emitTwo (events.js:106:13)
                                        0|mm | at Request.emit (events.js:191:7)
                                        0|mm | at Request. (/home/pi/MagicMirror/modules/MMM-Todoist/node_modules/request/request.js:1171:10)
                                        0|mm | at emitOne (events.js:96:13)
                                        0|mm | at Request.emit (events.js:188:7)
                                        0|mm | at IncomingMessage. (/home/pi/MagicMirror/modules/MMM-Todoist/node_modules/request/request.js:1091:12)
                                        0|mm | at Object.onceWrapper (events.js:290:19)
                                        0|mm | at emitNone (events.js:91:20)
                                        0|mm | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                        0|mm | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          Chiumanfu
                                          Been testing a lot and figured out if you have entries in your list that have no due date assigned, then it crashes the module. If all entries in the list have dates then it behaves well. Gonna dig into the code to see where the bug is.
                                            Sunburned
                                            So I have to be one of those… I am having the same problem guys but you guessed it, my list is showing blank.
                                            I have confirmed the node_modules is in the MMM-todoist folder and I updated the list number in MMM-Todoist.js. i have confirmed my access token is correct and my lists numbers are correct
                                            My MMM-Todoist.js is:
                                             defaults: {
                                                          maximumEntries: 10,
                                                          lists: ["my list number here"],
                                                          interval: 60,
                                                          fade: false,
                                                          fade point: 0.25
                                            My config.js is:
                                                         position: 'bottom_left',
                                                         header: 'Todoist'
                                                         accessToken: 'my access token here',
        // lists: ["edit in MMM-Todoist.js"],
                                                         maximumEntries: 60,
                                                         interval: 60,
                                                         fade: false
                                            If anyone has any thoughts i would be really appreciative. Been tearing out my 4 remaining hairs.
                                            M T joela85J 3 Replies Last reply Reply Quote 0
                                            • 1 / 4
