    MMM-Todoist - Your todoist tasks on your mirror
    76 Posts 37 Posters 119.8k Views 39 Watching
    • yawnsY
      yawns Moderator
      This is what the readme on github says:
      Array of 1 ProjectId you want to display.
      Possible values: array
      Default value: [ 166564794 ]
      Example: [166564794]
      Getting the Todoist ProjectID:
      1) Go to Todoist (Log in if you aren't)
      2) Click on a Project in the left menu
      3) Your browser URL will change to something like
      "https://todoist.com/app?lang=en&v=818#project%2F166564897"
      Everything after %2F is the Project ID. In this case "166564897"
      • cowboysdudeC
        That’s what I thought but when I put the list on the mirror… it’s blank :*(
        Here’s what mine looks like [everything but the list number I changed ;)]
        https://en.todoist.com/app?lang=en&v=820#project%2F111531720
        so I used [ 111531720 ]
        The list is blank on the mirror…
        Here’s my config:
        module: 'MMM-Todoist', position: 'bottom_bar', // This can be any of the regions. Best results in left or right regions. header: 'Work List', // This is optional config: { // See 'Configuration options' for more information. accessToken: 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx', maximumEntries: 3, interval: 30, lists: [ 111531720 ], fade: true
          JoeSpencer
          Same issue, any progress?
          • cowboysdudeC
            cowboysdude Module Developer @JoeSpencer
            @JoeSpencer said in MMM-Todoist - Your todoist tasks on your mirror:
            None for me… I gave up on it and moved on… never got an answer to the issues I had. NO big deal… People get busy… I don’t get upset I just find a different way :)
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @cowboysdude
              @cowboysdude @JoeSpencer did you guys create an issue on github? the author is offline since over a month on this forum here, maybe you can reach him better on github
              • cowboysdudeC
                cowboysdude Module Developer @strawberry 3.141
                @strawberry-3.141 could have I guess but at the time I was onto others things…
                So when I get home I’ll do that! Enjoying the sun here: https://www.google.com/maps/place/Galveston,+TX/@29.2187539,-95.2067404,10z/data=!3m1!4b1!4m5!3m4!1s0x863f59c8c4059259:0xe58b03c9b9eaecc1!8m2!3d29.3013479!4d-94.7976958
                J 1 Reply Last reply
                  JoeSpencer @cowboysdude
                  @cowboysdude @strawberry-3-141 I switched to the Wunderlist module that this was based on and encountered the same issue, but I fixed it by generating a new token from the API.
                  Maybe that would work for Todoist as well.
                  • cowboysdudeC
                    @JoeSpencer Yes I did that with a weather module and that fixed that also… sometimes those things just happen :)
                      shutterclick
                      I had the same problem, I don’t know if you’ve solved it yet but for me it turned out to be some simple mistakes.
                      I thought I had followed the instructions to the letter, but actually at first I hadn’t cloned the module into the modules folder, just into the mirror folder. After cursing my own stupidity for that I carried on a while but still couldn’t get it working.
                      I tried the tip for generating a new access token but that wasn’t it. I then realised that when I cloned the module (into the correct folder!) I missed the small but vital step of navigating into the new folder before carrying out npm install.
                      I don’t know if any of you have made mistakes as daft as mine, but I finally got it working so thought I’d let you know.
                      Hope it helps someone!
                      tidus5T 1 Reply Last reply
                      • tidus5T
                        tidus5 @shutterclick
                        Yop,
                        I’m looking to add the reminder and priority level (with an icon) Has anyone did something like that with this module ?
                        in the fetcher i found where to add the var
                        	 for (var i = 0; i < JSON.parse(body).items.length; i++) {
                        		 if (JSON.parse(body).items[i].project_id == listID) {
                        			 items.push(JSON.parse(body).items[i].content);
                        			 items.push(JSON.parse(body).items[i].priority);
                        			 items.push(JSON.parse(body).items[i].due_date_utc);
                        but i dont know how to use the answer
                        • tidus5T
                          tidus5
                          Yop,
                          i did it :-)
                          H D 2 Replies Last reply
                          Reply Quote 3
                          • O
                            onetwankyfive
                            Thanks for this module. Dropped Wunderlist in favor of this via Alexa integration.
                            https://blog.todoist.com/2016/10/13/todoist-alexa-integration/
                            • H
                              hhaiii @tidus5
                              @tidus5 This looks awesome - how did you implement? I just got my basic Todoist module running today
                                dinkybluebug245
                                Im having some issues with this module. When I add items to my todoist - it appears in the module, but when I mark them as completed , or they are deleted - the items dont come off the module - unless I add a new item onto the list. At that point, they disappear, and the new item gets added.
                                Very odd.
                                Ive raised it as an issue here: https://github.com/cbrooker/MMM-Todoist/issues/3
                                Any ideas why this might be?
                                  shashank @dinkybluebug245
                                  @dinkybluebug245 hi i added this module , when i add a item with Alexa voice , it gets added to inbox i could not able to get lists: [ 1234567890 ] number from the url
                                  0_1485081729902_upload-88d37e27-8aef-4d99-b321-07b2922e3c9d
                                  O 1 Reply Last reply
                                  • O
                                    onetwankyfive @shashank
                                    @shashank click inbox instead of today
                                      dakipro
                                      I wanted to try to fix this module, but I have found that using the .ical export from todoist works great with official calendar module, so…
                                        psm9
                                        Hi, all,
                                        Does anybody know how to sort this list? It adds new items at the bottom, so if there is no more room on the mirror, I can’t see them. I can’t figure out how to sort them on Todoist’s site easier, except alphabetically. I am using the “Alexa Shopping List” list in Todoist
                                          svonbentzel @psm9
                                          @psm9 said in MMM-Todoist - Your todoist tasks on your mirror:
                                          Hi, all,
                                          Hy, please can you post your working config for the Todoist module?
                                          My Module is starting but the Todos are blank ;-)
                                          Thank you
                                            svonbentzel
                                            i have figured out why the list is blank:
                                            in MMM-Todoist.js is the default
                                            Module.register("MMM-Todoist", {
                                             defaults: {
                                            	maximumEntries: 10,
                                            	lists: ["inbox"],
                                            	interval: 60,
                                            	fade: true,
                                            	fadePoint: 0.25
                                            maybe a result of the fork from Wunderlist.
                                            you can see that with pm2 logs
                                            0|mm       | Create new todo fetcher for list: inbox - Interval: 60000
                                            the added value in the config.js doesn’t accept.
                                            so I write the correct list in MMM-Todoist.js
                                             defaults: {
                                            	maximumEntries: 10,
                                            	lists: ["198511455"],
                                            	interval: 60,
                                            	fade: true,
                                            	fadePoint: 0.25
                                            save and restart MM with pm2 restart mm
                                            then look at pm2 logs
                                            |mm       | Create new todo fetcher for list: 198511455 - Interval: 60000
                                            tadaaaa ;-) the correct fetcher ^^
                                            but why the config.js variable not in use — I don’t know ;-)
                                            yawnsY 1 Reply Last reply
                                            • 1 / 4
