    MMM-NOAA3 - Revived
    15 Posts 3 Posters 4.3k Views 3 Watching
    • mumblebajM Offline
      mumblebaj Module Developer
      Hi all,
      I have been using MMM-NOAA3 by @cowboysdude for a few years now. I like the display of it and did not want to go for a different module to replace it. Recently it stopped working and has for a while been throwing lots of errors.
      I have forked the module and have started updating it and trying to bring it back to life. I have managed to update a few things.
      • Removed request and replaced with internal fetch
      • Updated MMM-NOAA3.js to cater for the new response structures.
      Supported Providers:
      • weatherbit
      • piratesky
      • accuweather
      • openweather
      • msn
      I have not had a chance yet to look at the other providers and am not sure if anybody would like them included. Honestly I do not want to create accounts for all of them just to update the provider list but can if I have to. However, I do believe that darksky has been taken over by Apple and it may not work so, I may be removing that from the list of providers.
      However, I am happy to say that the module now works fine for weatherbit and openweather and no longer is throwing any errors.
      I will be pushing a PR to @cowboysdude when I am done making all the changes with the other providers.
      For now, if anybody is interested in using it for either openweather or weatherbit you can use my fork for now.
      Can be found below:
      MMM-NOAA3
        sdetweil @mumblebaj
        @mumblebaj piratesky has a clone of the old darksky api
        mumblebajM 2 Replies Last reply Reply Quote 0
          @sdetweil Awesome. Will have a look at it. Thanks Sam
            sdetweil @mumblebaj
            @mumblebaj it’s supposed to be change the host part of the url
              @sdetweil Successfully replaced Darksky with Piratesky.
              htilburgsH 1 Reply Last reply Reply Quote 1
              • htilburgsH Offline
                htilburgs @mumblebaj
                @mumblebaj
                I like what you did!
                Keep up the good work!!
                Added an issue for the dutch translations.
                (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                  mumblebaj Module Developer @htilburgs
                  @htilburgs Hi, thanks for the complement. I have updated accordingly. Thanks for that.
                  htilburgsH 1 Reply Last reply Reply Quote 0
                    @mumblebaj
                    After updating and reload, I. got Undefined / NaN
                    What can this be?
                      htilburgs @htilburgs
                      Uncaught (in promise) TypeError: Cannot read properties of undefined (reading ‘icon’)
                      at Class.processWeather (MMM-NOAA3.js:210:20)
                      at Class.socketNotificationReceived (MMM-NOAA3.js:173:18)
                      at module.js:240:9
                      at Socket. (socketclient.js:32:4)
                      at Emitter.emit (index.js:136:20)
                      at Socket.emitEvent (socket.js:553:20)
                      at Socket.onevent (socket.js:540:18)
                      at MMSocket.socket.onevent (socketclient.js:26:11)
                      at Socket.onpacket (socket.js:508:22)
                        The problem is with Weatherbit.
                        When I try Piratesky, everythings works fine…
                          @htilburgs I will have a look at weatherbit. They may have changed icons.
                          Just a little busy today but when I get a moment I will definitely have a look.
                          I also require your lat and lon so I can get the data/icons for your region/area
                            @mumblebaj
                            userlat: “51.479256”,
                            userlon: “5.657010”,
                              @htilburgs Good morning. I have just tested weatherbit using you lat and lon and not seeing any errors.
                                @mumblebaj
                                I see It.
                                I don’t what was wrong, you sas the messages for MM in console. Thanks for looking into It, maybe It was a one the thing.
                                  @htilburgs Thanks for confirming. I double checked the icons available from weatherbit and compared to the list and they are all covered. Hopefully it was just a once off thing. 🙏
