    MMM-NOAA3 - Revived
    15 Posts 3 Posters 3.9k Views 3 Watching
      sdetweil @mumblebaj
      @mumblebaj it’s supposed to be change the host part of the url
      • mumblebajM Offline
        @sdetweil Successfully replaced Darksky with Piratesky.
        htilburgsH 1 Reply Last reply Reply Quote 1
        • htilburgsH Offline
          htilburgs @mumblebaj
          @mumblebaj
          I like what you did!
          Keep up the good work!!
          Added an issue for the dutch translations.
          (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
            mumblebaj Module Developer @htilburgs
            @htilburgs Hi, thanks for the complement. I have updated accordingly. Thanks for that.
            htilburgsH 1 Reply Last reply Reply Quote 0
              @mumblebaj
              After updating and reload, I. got Undefined / NaN
              What can this be?
                htilburgs @htilburgs
                Uncaught (in promise) TypeError: Cannot read properties of undefined (reading ‘icon’)
                at Class.processWeather (MMM-NOAA3.js:210:20)
                at Class.socketNotificationReceived (MMM-NOAA3.js:173:18)
                at module.js:240:9
                at Socket. (socketclient.js:32:4)
                at Emitter.emit (index.js:136:20)
                at Socket.emitEvent (socket.js:553:20)
                at Socket.onevent (socket.js:540:18)
                at MMSocket.socket.onevent (socketclient.js:26:11)
                at Socket.onpacket (socket.js:508:22)
                  The problem is with Weatherbit.
                  When I try Piratesky, everythings works fine…
                    @htilburgs I will have a look at weatherbit. They may have changed icons.
                    Just a little busy today but when I get a moment I will definitely have a look.
                    I also require your lat and lon so I can get the data/icons for your region/area
                      @mumblebaj
                      userlat: “51.479256”,
                      userlon: “5.657010”,
                        @htilburgs Good morning. I have just tested weatherbit using you lat and lon and not seeing any errors.
