    MMM-NOAA3 - Revived
    15 Posts 3 Posters 5.0k Views 3 Watching
    • htilburgsH Offline
      htilburgs @mumblebaj
      @mumblebaj
      I like what you did!
      Keep up the good work!!
      Added an issue for the dutch translations.
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      • mumblebajM Offline
        mumblebaj Module Developer @htilburgs
        @htilburgs Hi, thanks for the complement. I have updated accordingly. Thanks for that.
        htilburgsH 1 Reply Last reply Reply Quote 0
          @mumblebaj
          After updating and reload, I. got Undefined / NaN
          What can this be?
            htilburgs @htilburgs
            Uncaught (in promise) TypeError: Cannot read properties of undefined (reading ‘icon’)
            at Class.processWeather (MMM-NOAA3.js:210:20)
            at Class.socketNotificationReceived (MMM-NOAA3.js:173:18)
            at module.js:240:9
            at Socket. (socketclient.js:32:4)
            at Emitter.emit (index.js:136:20)
            at Socket.emitEvent (socket.js:553:20)
            at Socket.onevent (socket.js:540:18)
            at MMSocket.socket.onevent (socketclient.js:26:11)
            at Socket.onpacket (socket.js:508:22)
              The problem is with Weatherbit.
              When I try Piratesky, everythings works fine…
                @htilburgs I will have a look at weatherbit. They may have changed icons.
                Just a little busy today but when I get a moment I will definitely have a look.
                I also require your lat and lon so I can get the data/icons for your region/area
                  @mumblebaj
                  userlat: “51.479256”,
                  userlon: “5.657010”,
                    @htilburgs Good morning. I have just tested weatherbit using you lat and lon and not seeing any errors.
                      @mumblebaj
                      I see It.
                      I don’t what was wrong, you sas the messages for MM in console. Thanks for looking into It, maybe It was a one the thing.
                        @htilburgs Thanks for confirming. I double checked the icons available from weatherbit and compared to the list and they are all covered. Hopefully it was just a once off thing. 🙏
