    White screen after MMM-Remote-Control update
    9 Posts 6 Posters 6.0k Views 6 Watching
    • T Offline
      toonazd @strawberry 3.141
      pi@raspberrypi:~/MagicMirror $ node serveronly
      Starting MagicMirror: v2.1.0
      Loading config …
      Loading module helpers …
      No helper found for module: calendar_monthly.
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘body-parser’
      Whoops! There was an uncaught exception…
      { Error: Cannot find module ‘body-parser’
      at Function.Module._resolveFilename (module.js:469:15)
      at Function.Module._load (module.js:417:25)
      at Module.require (module.js:497:17)
      at require (internal/module.js:20:19)
      at Object. (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:15:20)
      at Module._compile (module.js:570:32)
      at Object.Module._extensions…js (module.js:579:10)
      at Module.load (module.js:487:32)
      at tryModuleLoad (module.js:446:12)
      at Function.Module._load (module.js:438:3) code: ‘MODULE_NOT_FOUND’ }
      pi@raspberrypi:~/MagicMirror $ git pull
        roramirez Core Contributors
        Is missing body-parser lib required by MMM-Remote-Control
        Go the module directory and run npm install
        cd /home/pi/MagicMirror/modules/MMM-Remote-Control/
        npm install
        E T 2 Replies Last reply Reply Quote 2
        • E Offline
          elmerito25 @roramirez
          @roramirez Experience the same issue and was fixed by following your instructions! Thanks a bunch!
          • T Offline
            toonazd @roramirez
            Thanks, all good now
            • Hein-JanH Offline
              Hein-Jan
              @roramirez.
              Thanks, you have hit the nail on the head. I did run the git pull command, I have run the reinstall (the script did not work so I ran the manual method, but I did not run the npm install.
              Sorry, I am new at this.
              I did search the forum but could not find a solution.
              So, thank for pointing out my mistake and helping me rectify it.
              @ others: thanks for sharing your problems and logs so the problem could be solved.
              Case closed from my perspective.
                Jopyth Moderator @Hein-Jan
                @Hein-Jan Sorry about this, forgot to mention, that the new version introduces dependencies which must be installed.
                @roramirez answer should work for anyone having the same problem (thanks!).
