    White screen after MMM-Remote-Control update
    9 Posts 6 Posters 5.9k Views 6 Watching
      roramirez Core Contributors
      Is missing body-parser lib required by MMM-Remote-Control
      Go the module directory and run npm install
      cd /home/pi/MagicMirror/modules/MMM-Remote-Control/
      npm install
      E T 2 Replies Last reply Reply Quote 2
      • E Offline
        elmerito25 @roramirez
        @roramirez Experience the same issue and was fixed by following your instructions! Thanks a bunch!
        • T Offline
          toonazd @roramirez
          Thanks, all good now
          • Hein-JanH Offline
            Hein-Jan
            @roramirez.
            Thanks, you have hit the nail on the head. I did run the git pull command, I have run the reinstall (the script did not work so I ran the manual method, but I did not run the npm install.
            Sorry, I am new at this.
            I did search the forum but could not find a solution.
            So, thank for pointing out my mistake and helping me rectify it.
            @ others: thanks for sharing your problems and logs so the problem could be solved.
            Case closed from my perspective.
              Jopyth Moderator @Hein-Jan
              @Hein-Jan Sorry about this, forgot to mention, that the new version introduces dependencies which must be installed.
              @roramirez answer should work for anyone having the same problem (thanks!).
