    [MMM-Remote-Control] Cannot GET /remote.html
    13 Posts 4 Posters 3.8k Views 4 Watching
      mvrlogins
      On a new installation
      var config =
        address: '0.0.0.0',
        ipWhitelist: [
          '127.0.0.1',
          '::ffff:127.0.0.1',
          '::1',
          '10.0.1.1/24'
            module: 'MMM-Remote-Control',
              secureEndpoints: false
      The entire section is copied from another instance of MM where Remote-Control is working fine.
      On this new install I get
      Help!
        sdetweil @mvrlogins
        @mvrlogins set
        ipWhitelist=[],
        '127.0.0.1',
        '::ffff:127.0.0.1',
        '::1',
        '10.0.1.1/24'
        the 1st 3 mean ONLY the same machine as MM is running on
        and then also ONLY from address 10.0.1.1
          mvrlogins @sdetweil
          Interesting
          I’ve had that on an instance of MM I’ve been running for 5-6 years with Remote -Control and it’s always worked fine.
          I’ve been able to access the display and remote from anywhere on the network.
          So I just copied it over to the new one
            mvrlogins @sdetweil
            I’ve now changed it to
            var config =
              address: '0.0.0.0',
              ipWhitelist: [],
            Same problem with Canot GET /remote.html
            http://10.0.1.87:8080/ works fine and I see the MM display
            http://10.0.1.87:8080/remote.html leads to the error
              mvrlogins @mvrlogins
              I removed the Remote-Control installation using
              rm -r -f  MMM-Remote-Control/
              Installed it using the instructions on the github repository
              cd ~/MagicMirror/modules
              git clone https://github.com/Jopyth/MMM-Remote-Control
              cd MMM-Remote-Control
              npm ci --omit=dev
              I now get the following - which doesn’t seem fatal at first glance -
              npm warn ERESOLVE overriding peer dependency
              npm warn While resolving: react-inspector@6.0.2
              npm warn Found: react@19.1.1
              npm warn node_modules/swagger-ui/node_modules/react
              npm warn   react@">=16.8.0 <20" from swagger-ui@5.29.0
              npm warn     swagger-ui@"^5.29.0" from the root project
              npm warn   2 more (react-dom, react-immutable-pure-component)
              npm warn
              npm warn Could not resolve dependency:
              npm warn peer react@"^16.8.4 || ^17.0.0 || ^18.0.0" from react-inspector@6.0.2
              npm warn node_modules/swagger-ui/node_modules/react-inspector
              npm warn   react-inspector@"^6.0.1" from swagger-ui@5.29.0
              npm warn
              npm warn Conflicting peer dependency: react@18.3.1
              npm warn node_modules/react
                sdetweil @mvrlogins
                @mvrlogins do
                npm install
                Instead of
                npm ci
                Will ONLY do exactly watch matches package-lock.json which is rarely correct
                  mvrlogins @sdetweil
                  Redid the install using
                  npm install
                  No errors during install
                  Same problem
                    Below from the pm2 log
                    0|MagicMir | [2025-09-21 16:44:59.284] [ERROR] Error when loading MMM-Remote-Control: require() of ES Module /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/uuid/dist-node/index.js from /home/pi/MagicMirror/modules/MMM-Remote-Control/API/api.js not supported.
                    0|MagicMir | Instead change the require of index.js in /home/pi/MagicMirror/modules/MMM-Remote-Control/API/api.js to a dynamic import() which is available in all CommonJS modules.
                    See https://stackoverflow.com/questions/70541068/instead-change-the-require-of-index-js-to-a-dynamic-import-which-is-available
                    S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                      sdetweil @mvrlogins
                      @mvrlogins yes, someone will have to update the module or downgrade the dependency in package.json
                      • KristjanESPERANTOK Offline
                        KristjanESPERANTO Module Developer @mvrlogins
                        @mvrlogins said in [MMM-Remote-Control] Cannot GET /remote.html:
                        To make it clear here as well: “require() of ES Module ... not supported” shows that you are using a very old (unsupported) Node version. Like I said in the GitHub issue, you have to update Node.
                        I recommend using NVM to update Node (like recommended on the Node website).
                        K 1 Reply Last reply Reply Quote 1
