    [MMM-Remote-Control] Cannot GET /remote.html
    17 Posts 5 Posters 7.4k Views 5 Watching
      mvrlogins @sdetweil
      Interesting
      I’ve had that on an instance of MM I’ve been running for 5-6 years with Remote -Control and it’s always worked fine.
      I’ve been able to access the display and remote from anywhere on the network.
      So I just copied it over to the new one
        mvrlogins @sdetweil
        I’ve now changed it to
        var config =
          address: '0.0.0.0',
          ipWhitelist: [],
              module: 'MMM-Remote-Control',
                secureEndpoints: false
        Same problem with Canot GET /remote.html
        http://10.0.1.87:8080/ works fine and I see the MM display
        http://10.0.1.87:8080/remote.html leads to the error
          mvrlogins @mvrlogins
          I removed the Remote-Control installation using
          rm -r -f  MMM-Remote-Control/
          Installed it using the instructions on the github repository
          cd ~/MagicMirror/modules
          git clone https://github.com/Jopyth/MMM-Remote-Control
          cd MMM-Remote-Control
          npm ci --omit=dev
          I now get the following - which doesn’t seem fatal at first glance -
          npm warn ERESOLVE overriding peer dependency
          npm warn While resolving: react-inspector@6.0.2
          npm warn Found: react@19.1.1
          npm warn node_modules/swagger-ui/node_modules/react
          npm warn   react@">=16.8.0 <20" from swagger-ui@5.29.0
          npm warn     swagger-ui@"^5.29.0" from the root project
          npm warn   2 more (react-dom, react-immutable-pure-component)
          npm warn
          npm warn Could not resolve dependency:
          npm warn peer react@"^16.8.4 || ^17.0.0 || ^18.0.0" from react-inspector@6.0.2
          npm warn node_modules/swagger-ui/node_modules/react-inspector
          npm warn   react-inspector@"^6.0.1" from swagger-ui@5.29.0
          npm warn
          npm warn Conflicting peer dependency: react@18.3.1
          npm warn node_modules/react
            sdetweil @mvrlogins
            @mvrlogins do
            npm install
            Instead of
            npm ci
            Will ONLY do exactly watch matches package-lock.json which is rarely correct
              mvrlogins @sdetweil
              Redid the install using
              npm install
              No errors during install
              Same problem
                Below from the pm2 log
                0|MagicMir | [2025-09-21 16:44:59.284] [ERROR] Error when loading MMM-Remote-Control: require() of ES Module /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/uuid/dist-node/index.js from /home/pi/MagicMirror/modules/MMM-Remote-Control/API/api.js not supported.
                0|MagicMir | Instead change the require of index.js in /home/pi/MagicMirror/modules/MMM-Remote-Control/API/api.js to a dynamic import() which is available in all CommonJS modules.
                See https://stackoverflow.com/questions/70541068/instead-change-the-require-of-index-js-to-a-dynamic-import-which-is-available
                S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                  sdetweil @mvrlogins
                  @mvrlogins yes, someone will have to update the module or downgrade the dependency in package.json
                  • KristjanESPERANTOK Offline
                    KristjanESPERANTO Module Developer @mvrlogins
                    @mvrlogins said in [MMM-Remote-Control] Cannot GET /remote.html:
                    To make it clear here as well: “require() of ES Module ... not supported” shows that you are using a very old (unsupported) Node version. Like I said in the GitHub issue, you have to update Node.
                    I recommend using NVM to update Node (like recommended on the Node website).
                    K 1 Reply Last reply Reply Quote 1
                    • K Offline
                      kasperb @KristjanESPERANTO
                      @KristjanESPERANTO said in [MMM-Remote-Control] Cannot GET /remote.html:
                      the Node website
                      Experiencing the same issue… Created a clean install of MM over the weekend and am getting the same error. NVM is updated. :-(
                        sdetweil @kasperb
                        @kasperb in config.js
                        address:”0.0.0.0”,
                        ipWhitelist:[],
                        • K Offline
                          kasperb @sdetweil
                          @sdetweil Yup, that’s what I have - sample of config here:
                          let config = {
                          	address: "0.0.0.0",	// Address to listen on, can be:
                          	port: 8080,
                          	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                          	ipWhitelist: [],	// Set [] to allow all IP addresses
                          • Y Offline
                            Ypsimm @kasperb
                            @kasperb
                            In case you’re still interested…
                            After fighting with this for I don’t know how long, for poops and giggles I changed the permissions on my modules/MMM-Remote-Control folder to full r/w for all users…
                            Now I can access the remote control.
                            YMMV, change permissions at your own risk, etc.
                              sdetweil @Ypsimm
                              @Ypsimm interesting. Git clone should set the permissions that way.
                              Did you install the module some other way than git?
                              • Y Offline
                                Ypsimm @sdetweil
                                @sdetweil Originally? Quite possibly something other than git, but it’s been such a long time since I first installed that I couldn’t tell you for sure.
                                Most recently, yes, git clone was one of the methods I tried after completely removing the module and attempting reinstalls. Not sure if the module install doesn’t do it like the full application clone would or what, but it’s been running just dandy since the manual change. I’m curious to see if anything changes after the next update or three.
                                  sdetweil @Ypsimm
                                  @Ypsimm ok, please make sure NOT to use sudo with any MagicMirror commands
