    Is adding Home Assistant the right way to go?
    25 Posts 3 Posters 7.2k Views 3 Watching
      sdetweil @British_Kiwi
      @British_Kiwi can you look at the output of npm start to see if an error is reported
        British_Kiwi @sdetweil
        @sdetweil not sure if I am doing this right. I thought I had made notes about how to check logs etc, but after some googling I have this (which I don’t think you were after):
        admin@raspberrypihome:~/MagicMirror $ npm run config:check
        > magicmirror@2.33.0 config:check
        > node js/check_config.js
        [2025-10-10 07:21:14.145] [INFO]  Checking config file /home/admin/MagicMirror/config/config.js ...
        [2025-10-10 07:21:14.197] [INFO]  Your configuration file doesn't contain syntax errors :)
        [2025-10-10 07:21:14.198] [INFO]  Checking modules structure configuration ...
        [2025-10-10 07:21:14.258] [ERROR] This module configuration contains errors:
        undefinedmust be object
        Not too sure which module this is referring too.
        Here are the pm2 logs. I’ve removed yesterdays stuff. All I have done this morning is pm2 restart 0 --updated-env (as it keeps saying something about environment variables which I haven’t seen prior to a few days ago.
        admin@raspberrypihome:~/MagicMirror $ pm2 logs
        /home/admin/.pm2/pm2.log last 15 lines:
        PM2        | 2025-10-10T07:15:02: PM2 log: Stopping app:MagicMirror id:0
        PM2        | 2025-10-10T07:15:03: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2        | 2025-10-10T07:15:03: PM2 log: pid=617000 msg=process killed
        PM2        | 2025-10-10T07:15:03: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2025-10-10T07:15:03: PM2 log: App [MagicMirror:0] online
        /home/admin/.pm2/logs/MagicMirror-error.log last 15 lines:
        0|MagicMir | [2025-10-10 07:15:04.251] [ERROR] This module configuration contains errors:
        0|MagicMir | undefinedmust be object
        0|MagicMir | [2025-10-10 07:15:04.252] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read properties of undefined (reading 'module')
        /home/admin/.pm2/logs/MagicMirror-out.log last 15 lines:
        0|MagicMir | - VERSIONS: electron: 38.1.2; used node: 22.19.0; installed node: 22.18.0; npm: 10.9.3; pm2: 6.0.13
        0|MagicMir | - ENV:      XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
        0|MagicMir |             WAYLAND_DISPLAY:  wayland-0; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
        0|MagicMir | - RAM:      total: 8059.20 MB; free: 6557.28 MB; used: 1501.92 MB
        It does it look like there is an issue with a module, but I can’t work out which module. Any ideas on how to work it out?
        At the moment I have commented out calendarext3, home assistant display, but I do have iframe showing on one of the pages.
          @British_Kiwi if you start a private chat with me, you can paste your config and I will look at it. I agree on the ‘this’ module is unclear!..
          sent you a message
            @British_Kiwi said in Is adding Home Assistant the right way to go?:
            accidental extra comma between modules (commented out module, but the trailing comma was on a sep line)
                 module:"foo",
                 .    <--- that guy
                  module:"bar",
            this is a bug,
            opened issue
            https://github.com/MagicMirrorOrg/MagicMirror/issues/3910
            as a separate way to avoid this, you can add
               disable:true,
            after the module: line
            to disable a module without having to comment it out
            disabled: false,
            makes it active again
              @sdetweil that’s a much cleaner way to disable a module. I will use that. Thanks again for your help.
