    [MMM-Buttons] An unhandled error occurred inside electron-rebuild
    3 Posts 3 Posters 4.0k Views
    • F Offline
      FlorianRD
      Anyone now why?
      > electron-rebuild -e ../../node_modules/electron
      Unable to find electron-prebuilt's version number, either install it or specify an explicit version
      Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
          at _callee$ (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/electron-rebuild/lib/cli.js:74:17)
          at tryCatch (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
          at Generator.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
          at Generator.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
          at Generator.tryCatcher (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/bluebird/js/release/util.js:16:23)
          at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/bluebird/js/release/generators.js:97:49)
          at /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/bluebird/js/release/generators.js:201:15
          at Object. (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/electron-rebuild/lib/cli.js:197:4)
          at Module._compile (module.js:571:32)
          at Object.Module._extensions..js (module.js:580:10)
          at Module.load (module.js:488:32)
          at tryModuleLoad (module.js:447:12)
          at Function.Module._load (module.js:439:3)
          at Module.runMain (module.js:605:10)
          at run (bootstrap_node.js:420:7)
          at startup (bootstrap_node.js:139:9)
      brobergB J 2 Replies Last reply Reply Quote 1
      • brobergB Offline
        broberg Project Sponsor @FlorianRD
        @FlorianRD
        Did you run npm install in the MMM-Buttons folder?
          Jopyth Moderator @FlorianRD
          @FlorianRD You need to be on Magic Mirror versions 2.1.0 or higher (i.e. develop branch).
          Edit: What MagicMirror version are you on? 2.1.0? When you navigate from the MMM-Buttons folder to ../../node_modules you should end up in a folder with an electron folder. If there is only a electron-prebuilt folder, it should be possible to fix the issues by upgrading MagicMirror to 2.1.0.
