Compliments text cycler without the randomizer
14 Posts 4 Posters 7.9k Views 4 Watching
    cnelso24
    I am trying to have a text cycler just like the compliments module but no randomization so I can customize the order.
    C 1 Reply Last reply Jan 29, 2017, 9:53 PM Reply Quote 0
      cowboysdude Module Developer @cnelso24
      @cnelso24 You’ll have to tear the compliments module apart and use parts from it to construct what you want. NO sense in re-inventing the wheel :)
      • W Offline
        washichi
        I’m new to JavaScript, so please correct me here if needed!
        I gave it a go and deleted the randomness, didn’t try it out cause my RPI sin’t running, but this should work:
        https://gist.github.com/washichi/74a1b08025aa166c8c296a245b06a517
        C 1 Reply Last reply Jan 29, 2017, 11:42 PM Reply Quote 0
          cnelso24 @washichi
          @washichi
          it does not work. I tried loading your code into the compliments.js file and none of my modules loaded after that. Thank you for trying though. I am also very new, that’s why I am asking for help
          W 1 Reply Last reply Jan 30, 2017, 12:29 PM Reply Quote 0
            Easy way is if you don’t want random then enter just 1 entry under each time… ;) That way you don’t have to do anything to change it… it’ll just show what you want all the time …
            The compliments module isn’t random. It rotates through whatever is in the module according to the time of day…
            So if you want it say something different then change it :)
            C 1 Reply Last reply Jan 30, 2017, 12:06 AM Reply Quote 0
              cnelso24 @cowboysdude
              @cowboysdude
              hmm… good point but then it will only display 1 string at a time, am I correct? What I am trying to do is display 6-8 strings all the time in a specific order.
                @cnelso24 Do a search on here… someone was asking or trying to make this work with a separate json file that they wanted to create… maybe you can do it that way.
                Try this forum… near the bottom:
                https://forum.magicmirror.builders/topic/1460/personalize-compliments/6
                yawns was talking about something that could possibly work!
                • W Offline
                  washichi @cnelso24
                  @cnelso24 Okay, so what you want is more something like hello world, but 6 times.
                  I’ll get my PI back tomorrow, I will setup magicmirror and play around with the modules.
                  I’m planning on making my own module, so this is a good exercise :p
                  I’ll let you know If I got it working
                  • Y Offline
                    yawns Moderator
                    I just put this together, based on the original compliments module. I am not sure if this should be added to the default module by PullRequest, which is why I created a standalone repository first.
                    [card:yawnsde/MMM-Compliments]
                    C 1 Reply Last reply Jan 30, 2017, 5:39 PM Reply Quote 3
                      cnelso24 @yawns
                      @yawns
                      Thank you! I’ll check it out when I get home
                      Y 1 Reply Last reply Feb 1, 2017, 12:02 PM Reply Quote 0
