    MMM-MyTado
    30 Posts 4 Posters 7.3k Views 4 Watching
    • htilburgsH
      htilburgs
      MMM-MyTado
      This a Magic Mirror² module for your TADO Thermostat.
      The module is based on the idea from WouterEekhout, but his module is not maintained anymore.
      I like the idea and built a version with a modern look and feel.
      The module displays the following information:
      • The Home name (🏠)
      • The Zone names (Configurable names)
      • A symbol (🔥) to show if the heater is currently active.
      • The current temperature and the target temperature
      • The humidity (💦)
      • The hot water temperature (🩸)
      • Frost Protection (❄️)
      • Open Window (🪟)
      SCR-20260226-ukba
      Installation
      Clone this repository in your modules folder, and install dependencies:
      cd ~/MagicMirror/modules
      git clone https://github.com/htilburgs/MMM-MyTado.git
      cd MMM-MyTado
      npm install
      Update
      When you need to update this module:
      cd ~/MagicMirror/modules/MMM-MyTado
      git pull
      npm install
      Config
      Go to the MagicMirror/config directory and edit the config.js file.
      Add the module to your modules array in your config.js.
        module: "MMM-MyTado",
        header: "TADO Thermostaat",
        disabled: false,
      	// Settings
      	updateInterval: 1800000,             // 30 min - because of limitation free account
              showZones: [],                       // [] = all zones, otherwise use zonename ["zone 1","zone 2"]
      	showHomeName: true,					 // Show Home Name as defined within the Tado environment
              showColumnHeaders: true,             // true = show Columns Headers, false = Hide Columns Headers
      	useColors: false,					 // Show colors for the Temperature column
      	showLastUpdate: true,				 // Show last update
      	debug: false,						 // Show debug information in logging
      	// Custom Names
              zoneColumnName: "ZONE",				 // Custom Zone Column Name - default = ZONE
              tempColumnName: "TEMP (°C)",		 // Custom Temperature Column Name - default = TEMP (°C)
              humidityColumnName: "",              // empty for no title (default)
              statusColumnName: "STATUS",			 // Custom Status Column Name - default = STATUS
      	lastUpdateName: "Last update"		 // Custom Last update name - default = Last update
      Authentication
      The first time you run the module, you will need to authenticate with the Tado API.
      No username or password is stored in MMM-MyTado, everything works with OAuth Authentication.
      The module will log a URL that you need to visit in your browser to complete the authentication process.
      Check the logs for a message like this:
      MMM-MyTado: Device authentication required.
      Open this URL to authenticate:
      https://login.tado.com/oauth2/device?user_code=XXXXXX
      Visit the URL in your browser and follow the instructions to authenticate the module with your Tado account.
      Configuration Options
      Option Description
      updateInterval REQUIRED - The interval the information is updated (in milliseconds)
      Default: 1800000
      This value cannot be lower than 1800000 without a monthly subscription.
      Otherwise users get a Tado block.
      More info at https://help.tado.com/en/articles/12165739-limitation-for-rest-api-usage
      showZones TADO uses Zones. When you use [] all zones will be shown (default)
      You can also choose which zones you like to see, just fill in the zones ["Zone 1","Zone 2", etc]
      showHomeName Show the Home name as defined in the Tapo environment
      Default: true
      showColumnHeaders Show the Column Headers
      Default: true
      useColors Use Colors for the Temperature Column
      Default: false
      debug Show debug information in logs
      Default false
      zoneColumnName Custom Zone Column Name - default: ZONE
      tempColumnName Custom Temperature Column Name - default: TEMP (°C)
      humidityColumnName Custom Humidity Column Name - default: Empty (Column Name is not shown)
      statusColumnName Custom Status Column Name - default: STATUS
      Versions
      v1.0.0 - Initial release
      v1.0.1 - Add Last update option
      v1.0.2 - Allignment Home name and Status icons always on the right (CSS)
      v1.0.3 - Add debug option, to prevent to many loggings in the logfiles
      Credits
      This module is inspired by the MMM-Tado module from WouterEekhout
      Using the NPM package node-tado-client
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        mishu28nmv @htilburgs
        @htilburgs
        Thank you. It is working. Had the latest MMM-Tado, but this better with the colors :)
        htilburgsH 1 Reply Last reply Reply Quote 0
        • htilburgsH
          htilburgs @mishu28nmv
          @mishu28nmv
          You’re welcome!
            MyMirror
            Very good!
            The old version did not work any longer, probably due to API issues.
            It’s a bit tricky because the code has to be entered with the link in the browser when MM is running.
            The image of the house on the left of ‘Home’ is missing for me.
            What could be the reason for this?
            Is it possible to insert a line: Last update on: <date/time>?
            Thank you for the module!
            • htilburgsH
              htilburgs @MyMirror
              @MyMirror
              I know it is not easy with the link, but that is what it is.
              When everything works ok then you only have to do it once.
              There is an automatic “refresh” mechanism built in.
              I will take a look at the image of the house.
              M htilburgsH 2 Replies Last reply Reply Quote 0
                MyMirror @htilburgs
                @htilburgs
                Yes, i know. it only needs to be done once.
                • htilburgsH
                  htilburgs @htilburgs
                  @mymirror
                  I looked into the code and tested it, but there is nothing that can explain why the house is not showing.
                  🏠 is an emoji, that is in the code.
                  So what you can check is if you see it in the code at your installation
                  ~/MagicMirror/modules/MMM-MyTado/MMM-MyTado.js
                  it should be on line 50
                  homeTitle.textContent = `🏠 ${home.name}`;
                  I will look for your request " Last update on: <date/time>?"
                  This is a good addition, I let you know.
                    MyMirror @htilburgs
                    @htilburgs
                    Line 50 is like yours … but no image on my screen.
                    I’ve the module on the left side, is it possible to place the “Status” to the right?
                      MyMirror @MyMirror
                      Hmm - other images are also not visible
                      • htilburgsH
                        htilburgs @MyMirror
                        @MyMirror
                        I will take a look into it. That doesn’t seems right.
                        Do they show if you place the module on the right?
                        I updated the current version for the Last update option.
                        Please do a git pull
                        In the config.js you have to add to options:
                        showLastUpdate: true // Show last update
                        I will take a look into the emoji problem and come back to you
                        • htilburgsH
                          I just quickly tested some things, but my icons are always shown. When I load the module on the left, then the house name goes to the left also. I will fix this in the next release.
                          On which version MagicMirror are you?
                          Which browser do you use?
                          Can you put the MMM-MyTado part of the config.js?
                            MyMirror @htilburgs
                            @htilburgs
                            Ok, let’s start with the MM Version: 2.34.0
                            Browser?: I use the default Chronium Browser: V 144.0.7559.109
                            MMM-MyTado:
                            //              https://forum.magicmirror.builders/topic/20128/mmm-mytado
                                                    header: "TADO",
                                                    disabled: false,
                                                            useColors: true,  //false,           // Show colors for the Temperature column
                                                            lastUpdateName: "Last update",       // Custom Last update name - default = Last update
                                                            statusColumnName: "STATUS"           // Custom Status Column Name - default = STATUS
                            Tado on the left side:
                            Tado on the right side:
                              MyMirror @MyMirror
                              And: All with OS Trixie
                              • htilburgsH
                                htilburgs @MyMirror
                                @MyMirror
                                I don’t see anything strange.
                                Have you looked with the developer tools?
                                Open browser, go to your MagicMirror site (http://IP:8080)
                                Right click on the icon before JW and select “inspect”
                                Now you can see the elements and styles.
                                Do you see something like this?
                                <div class="tado-home">🏠 JW</div>
                                If not, what do you see?
                                For the align I found how to fix this.
                                This is just an CSS issue and will be fixed.
                                  MyMirror @htilburgs
                                  @htilburgs
                                  Crazy …
                                  See this:Tado8a.png
                                  Left on the real MM: no pictures
                                  Right over IP:8080: all needed images
                                  • htilburgsH
                                    htilburgs @MyMirror
                                    @MyMirror
                                    This is a font issue on the Raspberry Pi.
                                    Can you try sudo apt install fonts-symbola reboot your PI and look again?
                                    This issues with the alignement of the Home Name and the Status icons is fixed also. Just published an update.
                                      MyMirror @htilburgs
                                      @htilburgs
                                      fonts-Symbola installed and rebootet:
                                      And some inspections:
                                        JoeFranz @MyMirror
                                        @MyMirror
                                        I didn’t have any colors either.
                                        Then I installed the “Noto Color Emoji” font.
                                        After that, I added the following to custom.css:
                                        /* Do NOT use Symbola */
                                        .MMM-MyTado {
                                        font-family: “Noto Color Emoji”, sans-serif !important;
                                        Now the colors are there :-)
                                          MyMirror @JoeFranz
                                          @JoeFranz
                                          Yes !! - This “Noto Color Emoji” font works!
                                          Now i’ve colors and pictures.
                                          The steps:
                                          sudo apt update
                                          sudo apt install fonts-noto-color-emoji
                                          fc-cache -fv
                                          • change font in css
                                            and reboot your mirror
                                          Thanks for your help and one more time: Thanks for the module
                                          • htilburgsH
                                            htilburgs @MyMirror
                                            @MyMirror
                                            Your welcome.
                                            Have much fun in using this module
                                            @joefranz
                                            Thanks for the help with the fonts.
