    MMM-MyTado
    30 Posts 4 Posters 7.8k Views 4 Watching
    • htilburgsH
      htilburgs @htilburgs
      @mymirror
      I looked into the code and tested it, but there is nothing that can explain why the house is not showing.
      🏠 is an emoji, that is in the code.
      So what you can check is if you see it in the code at your installation
      ~/MagicMirror/modules/MMM-MyTado/MMM-MyTado.js
      it should be on line 50
      homeTitle.textContent = `🏠 ${home.name}`;
      I will look for your request " Last update on: <date/time>?"
      This is a good addition, I let you know.
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      M 1 Reply Last reply
        MyMirror @htilburgs
        @htilburgs
        Line 50 is like yours … but no image on my screen.
        I’ve the module on the left side, is it possible to place the “Status” to the right?
          MyMirror @MyMirror
          Hmm - other images are also not visible
          htilburgsH 1 Reply Last reply
          • htilburgsH
            htilburgs @MyMirror
            @MyMirror
            I will take a look into it. That doesn’t seems right.
            Do they show if you place the module on the right?
            I updated the current version for the Last update option.
            Please do a git pull
            In the config.js you have to add to options:
            showLastUpdate: true // Show last update
            lastUpdateName: "Last update" // Custom Last update name - default = Last update
            I will take a look into the emoji problem and come back to you
            • htilburgsH
              I just quickly tested some things, but my icons are always shown. When I load the module on the left, then the house name goes to the left also. I will fix this in the next release.
              On which version MagicMirror are you?
              Which browser do you use?
              Can you put the MMM-MyTado part of the config.js?
                MyMirror @htilburgs
                @htilburgs
                Ok, let’s start with the MM Version: 2.34.0
                Browser?: I use the default Chronium Browser: V 144.0.7559.109
                MMM-MyTado:
                //              https://forum.magicmirror.builders/topic/20128/mmm-mytado
                                        module: "MMM-MyTado",
                                        header: "TADO",
                                        disabled: false,
                                                updateInterval: 1800000,             // 30 min - because of limitation free account
                                                showZones: [],                       // [] = all zones, otherwise use zonename ["zone 1","zone 2"]
                                                showHomeName: true,                  // Show Home Name as defined within the Tado environment
                                                showColumnHeaders: true,             // true = show Columns Headers, false = Hide Columns Headers
                                                useColors: true,  //false,           // Show colors for the Temperature column
                                                zoneColumnName: "ZONE",              // Custom Zone Column Name - default = ZONE
                                                showLastUpdate: true,                // Show last update
                                                lastUpdateName: "Last update",       // Custom Last update name - default = Last update
                                                tempColumnName: "TEMP (°C)",         // Custom Temperature Column Name - default = TEMP (°C)
                                                humidityColumnName: "",              // empty for no title (default)
                                                statusColumnName: "STATUS"           // Custom Status Column Name - default = STATUS
                Tado on the left side:
                Tado on the right side:
                  MyMirror @MyMirror
                  And: All with OS Trixie
                  • htilburgsH
                    htilburgs @MyMirror
                    @MyMirror
                    I don’t see anything strange.
                    Have you looked with the developer tools?
                    Open browser, go to your MagicMirror site (http://IP:8080)
                    Right click on the icon before JW and select “inspect”
                    Now you can see the elements and styles.
                    Do you see something like this?
                    <div class="tado-home">🏠 JW</div>
                    If not, what do you see?
                    For the align I found how to fix this.
                    This is just an CSS issue and will be fixed.
                      MyMirror @htilburgs
                      @htilburgs
                      Crazy …
                      See this:Tado8a.png
                      Left on the real MM: no pictures
                      Right over IP:8080: all needed images
                      • htilburgsH
                        htilburgs @MyMirror
                        @MyMirror
                        This is a font issue on the Raspberry Pi.
                        Can you try sudo apt install fonts-symbola reboot your PI and look again?
                        This issues with the alignement of the Home Name and the Status icons is fixed also. Just published an update.
                          MyMirror @htilburgs
                          @htilburgs
                          fonts-Symbola installed and rebootet:
                          And some inspections:
                          J 1 Reply Last reply
                            JoeFranz @MyMirror
                            @MyMirror
                            I didn’t have any colors either.
                            Then I installed the “Noto Color Emoji” font.
                            After that, I added the following to custom.css:
                            /* Do NOT use Symbola */
                            .MMM-MyTado {
                            font-family: “Noto Color Emoji”, sans-serif !important;
                            Now the colors are there :-)
                              MyMirror @JoeFranz
                              @JoeFranz
                              Yes !! - This “Noto Color Emoji” font works!
                              Now i’ve colors and pictures.
                              The steps:
                              sudo apt update
                              sudo apt install fonts-noto-color-emoji
                              fc-cache -fv
                              • change font in css
                                and reboot your mirror
                              Thanks for your help and one more time: Thanks for the module
                              • htilburgsH
                                htilburgs @MyMirror
                                @MyMirror
                                Your welcome.
                                Have much fun in using this module
                                @joefranz
                                Thanks for the help with the fonts.
                                  JoeFranz @htilburgs
                                  @htilburgs
                                  I’ve made the view a bit more compact. The word “Status” was stretching everything too much. Now I only see the status icon. Looks better, I think… :-)
                                  /* Nur die STATUS-Überschrift ausblenden */
                                  .MMM-MyTado th:last-child {
                                  display: none !important;
                                  htilburgsH 2 Replies Last reply
                                  • htilburgsH
                                    htilburgs @JoeFranz
                                    @JoeFranz
                                    I will take a look at it when I’m at home. Currently at work.
                                      MyMirror @htilburgs
                                      @htilburgs
                                      @joefranz
                                      That looks good.
                                      I also saw this in the README (OpenWindow):
                                      I often see this message in my app, but how can I activate it here too?
                                        JoeFranz @MyMirror
                                        @MyMirror
                                        Perhaps this is due to the time period of updating the data. Unfortunately, the values are only updated every 30 minutes. If the window is opened and closed again during this period, then of course it will not be displayed. Just a guess…😉
                                        • htilburgsH
                                          htilburgs @JoeFranz
                                          @JoeFranz @mymirror
                                          That is correct. Due to the limit of 100 polls a day (thanks to Tado), you will probably not see this often.
                                          When you have the “contract” with Tado, you can put the polling lower (mine is at 300000 / 5 min, still trying how far I can go) and I have seen it once, when I let my door open for a few minutes).
                                          • htilburgsH
                                            htilburgs @JoeFranz
                                            @JoeFranz
                                            I see what you did, but there are more ways to do this:
                                            showColumnHeaders: false
                                            Then no headers are shown and you have a compact view
                                            or you leave the statusColumnName: "" (empty) so no name is shown.
                                            With the CSS change, it becomes definitive, and that is not what should happen.
