    MMM-MyTado
    30 Posts 4 Posters 7.8k Views 4 Watching
      MyMirror @htilburgs
      @htilburgs
      Crazy …
      See this:Tado8a.png
      Left on the real MM: no pictures
      Right over IP:8080: all needed images
      htilburgsH 1 Reply Last reply
      • htilburgsH
        htilburgs @MyMirror
        @MyMirror
        This is a font issue on the Raspberry Pi.
        Can you try sudo apt install fonts-symbola reboot your PI and look again?
        This issues with the alignement of the Home Name and the Status icons is fixed also. Just published an update.
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        M 1 Reply Last reply
          MyMirror @htilburgs
          @htilburgs
          fonts-Symbola installed and rebootet:
          And some inspections:
          J 1 Reply Last reply
            JoeFranz @MyMirror
            @MyMirror
            I didn’t have any colors either.
            Then I installed the “Noto Color Emoji” font.
            After that, I added the following to custom.css:
            /* Do NOT use Symbola */
            .MMM-MyTado {
            font-family: “Noto Color Emoji”, sans-serif !important;
            Now the colors are there :-)
              MyMirror @JoeFranz
              @JoeFranz
              Yes !! - This “Noto Color Emoji” font works!
              Now i’ve colors and pictures.
              The steps:
              sudo apt update
              sudo apt install fonts-noto-color-emoji
              fc-cache -fv
              • change font in css
                and reboot your mirror
              Thanks for your help and one more time: Thanks for the module
              • htilburgsH
                htilburgs @MyMirror
                @MyMirror
                Your welcome.
                Have much fun in using this module
                @joefranz
                Thanks for the help with the fonts.
                  JoeFranz @htilburgs
                  @htilburgs
                  I’ve made the view a bit more compact. The word “Status” was stretching everything too much. Now I only see the status icon. Looks better, I think… :-)
                  /* Nur die STATUS-Überschrift ausblenden */
                  .MMM-MyTado th:last-child {
                  display: none !important;
                  htilburgsH 2 Replies Last reply
                  • htilburgsH
                    htilburgs @JoeFranz
                    @JoeFranz
                    I will take a look at it when I’m at home. Currently at work.
                      MyMirror @htilburgs
                      @htilburgs
                      @joefranz
                      That looks good.
                      I also saw this in the README (OpenWindow):
                      I often see this message in my app, but how can I activate it here too?
                        JoeFranz @MyMirror
                        @MyMirror
                        Perhaps this is due to the time period of updating the data. Unfortunately, the values are only updated every 30 minutes. If the window is opened and closed again during this period, then of course it will not be displayed. Just a guess…😉
                        • htilburgsH
                          htilburgs @JoeFranz
                          @JoeFranz @mymirror
                          That is correct. Due to the limit of 100 polls a day (thanks to Tado), you will probably not see this often.
                          When you have the “contract” with Tado, you can put the polling lower (mine is at 300000 / 5 min, still trying how far I can go) and I have seen it once, when I let my door open for a few minutes).
                          • htilburgsH
                            htilburgs @JoeFranz
                            @JoeFranz
                            I see what you did, but there are more ways to do this:
                            showColumnHeaders: false
                            Then no headers are shown and you have a compact view
                            or you leave the statusColumnName: "" (empty) so no name is shown.
                            With the CSS change, it becomes definitive, and that is not what should happen.
                            • htilburgsH
                              htilburgs
                              Just updated to v1.0.3 - Add debug option, to prevent to many loggings in the logfiles.
                              In config.js simple add debug: false, (or true for showing console log messages). Default it is false, because loggings were growing to fast.
                              Update:
                              cd ~/MagicMirror/modules/MMM-MyTado
                              git pull
                              npm install
                                MyMirror @htilburgs
                                @htilburgs
                                Two more questions:
                                Is it possible to provide the humidity and the exact open window as well?
                                In the app both are visible:
                                Open window:
                                Humidity:
                                BR
                                • htilburgsH
                                  htilburgs @MyMirror
                                  @MyMirror
                                  The humidity is already shown -> The humidity (💦)
                                  The open window is already shown -> Open Window (🪟)
                                  It will be shown in the status column when it appears in that zone.
                                    MyMirror @htilburgs
                                    @htilburgs
                                    You’re completly right …
