    MMM-MyTado
    30 Posts 4 Posters 7.3k Views 4 Watching
      MyMirror @htilburgs
      @htilburgs
      fonts-Symbola installed and rebootet:
      And some inspections:
        JoeFranz @MyMirror
        @MyMirror
        I didn’t have any colors either.
        Then I installed the “Noto Color Emoji” font.
        After that, I added the following to custom.css:
        /* Do NOT use Symbola */
        .MMM-MyTado {
        font-family: “Noto Color Emoji”, sans-serif !important;
        Now the colors are there :-)
          MyMirror @JoeFranz
          @JoeFranz
          Yes !! - This “Noto Color Emoji” font works!
          Now i’ve colors and pictures.
          The steps:
          sudo apt update
          sudo apt install fonts-noto-color-emoji
          fc-cache -fv
          • change font in css
            and reboot your mirror
          Thanks for your help and one more time: Thanks for the module
          htilburgsH 1 Reply Last reply Reply Quote 0
          • htilburgsH
            htilburgs @MyMirror
            @MyMirror
            Your welcome.
            Have much fun in using this module
            @joefranz
            Thanks for the help with the fonts.
            (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
              JoeFranz @htilburgs
              @htilburgs
              I’ve made the view a bit more compact. The word “Status” was stretching everything too much. Now I only see the status icon. Looks better, I think… :-)
              /* Nur die STATUS-Überschrift ausblenden */
              .MMM-MyTado th:last-child {
              display: none !important;
              htilburgsH 2 Replies Last reply Reply Quote 0
              • htilburgsH
                htilburgs @JoeFranz
                @JoeFranz
                I will take a look at it when I’m at home. Currently at work.
                  MyMirror @htilburgs
                  @htilburgs
                  @joefranz
                  That looks good.
                  I also saw this in the README (OpenWindow):
                  I often see this message in my app, but how can I activate it here too?
                    JoeFranz @MyMirror
                    @MyMirror
                    Perhaps this is due to the time period of updating the data. Unfortunately, the values are only updated every 30 minutes. If the window is opened and closed again during this period, then of course it will not be displayed. Just a guess…😉
                    • htilburgsH
                      htilburgs @JoeFranz
                      @JoeFranz @mymirror
                      That is correct. Due to the limit of 100 polls a day (thanks to Tado), you will probably not see this often.
                      When you have the “contract” with Tado, you can put the polling lower (mine is at 300000 / 5 min, still trying how far I can go) and I have seen it once, when I let my door open for a few minutes).
                      • htilburgsH
                        htilburgs @JoeFranz
                        @JoeFranz
                        I see what you did, but there are more ways to do this:
                        showColumnHeaders: false
                        Then no headers are shown and you have a compact view
                        or you leave the statusColumnName: "" (empty) so no name is shown.
                        With the CSS change, it becomes definitive, and that is not what should happen.
                        • htilburgsH
                          htilburgs
                          Just updated to v1.0.3 - Add debug option, to prevent to many loggings in the logfiles.
                          In config.js simple add debug: false, (or true for showing console log messages). Default it is false, because loggings were growing to fast.
                          Update:
                          cd ~/MagicMirror/modules/MMM-MyTado
                          git pull
                          npm install
                            MyMirror @htilburgs
                            @htilburgs
                            Two more questions:
                            Is it possible to provide the humidity and the exact open window as well?
                            In the app both are visible:
                            Open window:
                            Humidity:
                            BR
                            • htilburgsH
                              htilburgs @MyMirror
                              @MyMirror
                              The humidity is already shown -> The humidity (💦)
                              The open window is already shown -> Open Window (🪟)
                              It will be shown in the status column when it appears in that zone.
                                MyMirror @htilburgs
                                @htilburgs
                                You’re completly right …
