    MMM-MyTado
    30 Posts 4 Posters 7.3k Views 4 Watching
      MyMirror @JoeFranz
      @JoeFranz
      Yes !! - This “Noto Color Emoji” font works!
      Now i’ve colors and pictures.
      The steps:
      sudo apt update
      sudo apt install fonts-noto-color-emoji
      fc-cache -fv
      • change font in css
        and reboot your mirror
      Thanks for your help and one more time: Thanks for the module
      htilburgsH 1 Reply Last reply Reply Quote 0
      • htilburgsH
        htilburgs @MyMirror
        @MyMirror
        Your welcome.
        Have much fun in using this module
        @joefranz
        Thanks for the help with the fonts.
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          JoeFranz @htilburgs
          @htilburgs
          I’ve made the view a bit more compact. The word “Status” was stretching everything too much. Now I only see the status icon. Looks better, I think… :-)
          /* Nur die STATUS-Überschrift ausblenden */
          .MMM-MyTado th:last-child {
          display: none !important;
          htilburgsH 2 Replies Last reply Reply Quote 0
          • htilburgsH
            htilburgs @JoeFranz
            @JoeFranz
            I will take a look at it when I’m at home. Currently at work.
              MyMirror @htilburgs
              @htilburgs
              @joefranz
              That looks good.
              I also saw this in the README (OpenWindow):
              I often see this message in my app, but how can I activate it here too?
                JoeFranz @MyMirror
                @MyMirror
                Perhaps this is due to the time period of updating the data. Unfortunately, the values are only updated every 30 minutes. If the window is opened and closed again during this period, then of course it will not be displayed. Just a guess…😉
                • htilburgsH
                  htilburgs @JoeFranz
                  @JoeFranz @mymirror
                  That is correct. Due to the limit of 100 polls a day (thanks to Tado), you will probably not see this often.
                  When you have the “contract” with Tado, you can put the polling lower (mine is at 300000 / 5 min, still trying how far I can go) and I have seen it once, when I let my door open for a few minutes).
                  • htilburgsH
                    htilburgs @JoeFranz
                    @JoeFranz
                    I see what you did, but there are more ways to do this:
                    showColumnHeaders: false
                    Then no headers are shown and you have a compact view
                    or you leave the statusColumnName: "" (empty) so no name is shown.
                    With the CSS change, it becomes definitive, and that is not what should happen.
                    • htilburgsH
                      htilburgs
                      Just updated to v1.0.3 - Add debug option, to prevent to many loggings in the logfiles.
                      In config.js simple add debug: false, (or true for showing console log messages). Default it is false, because loggings were growing to fast.
                      Update:
                      cd ~/MagicMirror/modules/MMM-MyTado
                      git pull
                      npm install
                        MyMirror @htilburgs
                        @htilburgs
                        Two more questions:
                        Is it possible to provide the humidity and the exact open window as well?
                        In the app both are visible:
                        Open window:
                        Humidity:
                        BR
                        • htilburgsH
                          htilburgs @MyMirror
                          @MyMirror
                          The humidity is already shown -> The humidity (💦)
                          The open window is already shown -> Open Window (🪟)
                          It will be shown in the status column when it appears in that zone.
                            MyMirror @htilburgs
                            @htilburgs
                            You’re completly right …
