    MMM-PIR-Sensor restart problem
    26 Posts 5 Posters 19.3k Views 4 Watching
    • T Offline
      trividar
      @MichMich Thanks a lot for your help…that was simple;o)!
      Now my MagicMirror won’t start on the monitor;o(
      I just get a back screen an i couldn’t do anything, my monitor is still working but just black screen and nothing else. Also I can’t quit the MagicMirror with ctrl+w. I can just get access with shh… an If I try to stop magic mirror with pm2 stop mm it stops but the screen is still black. If I use over ssh my laptop and start with npm start the MagicMirror works well. If i disconnect the PIR sensor (hardware) then everything works well.
      I got this error if i start pm2 logs mm…
      You know what I do wrong? (Sorry for all this noob questions)
      MichMichM 1 Reply Last reply Reply Quote 0
      • MichMichM Offline
        MichMich Admin @trividar
        EADDRINUSE:::8080 means there is already an app running on port 8080. Probably the app itself which you already started once. If you can’t figure out how to quit it, simply restart your Pi. This should solve it.
        • T Offline
          trividar
          @MichMich Thanks for your fast replay. I restart my Pi several times, but I have always the same problem. My MagicMirror starts normal and after 2 seconds the screen goes black.
          • MichMichM Offline
            With the same error?
            • T Offline
              trividar
              Yes with the same error…
              • T Offline
                trividar
                Now i have disconnect the cables from pir sensor and restart my pi. After reboot my pi my Magicmirror start automaticlly normal and after 2 seconds they got again black. That crazy thing is, I press ctrl+w and the blackscreen goes away and the the Magicmirror works “under” the blackscreen well…
                paviroP 1 Reply Last reply Reply Quote 0
                • paviroP Offline
                  paviro Admin @trividar
                  @trividar try changing the port in the config.js from 8080 to 8888 and reboot.
                  – The Doctor
                  • T Offline
                    trividar
                    @paviro I have now the same error just with 8888.
                    • MichMichM Offline
                      MichMich Admin
                      How do you start your Mirror?
                      • T Offline
                        trividar
                        with autostart (from wiki).
