    MMM-PIR-Sensor restart problem
    26 Posts 5 Posters 21.0k Views 4 Watching
    • MichMichM Offline
      MichMich @trividar
      With the same error?
      • T Offline
        trividar
        Yes with the same error…
        • T Offline
          trividar
          Now i have disconnect the cables from pir sensor and restart my pi. After reboot my pi my Magicmirror start automaticlly normal and after 2 seconds they got again black. That crazy thing is, I press ctrl+w and the blackscreen goes away and the the Magicmirror works “under” the blackscreen well…
          paviroP 1 Reply Last reply Reply Quote 0
          • paviroP Offline
            paviro @trividar
            @trividar try changing the port in the config.js from 8080 to 8888 and reboot.
            – The Doctor
            • T Offline
              trividar
              @paviro I have now the same error just with 8888.
              • MichMichM Offline
                MichMich
                How do you start your Mirror?
                • T Offline
                  trividar
                  with autostart (from wiki).
                  • MichMichM Offline
                    MichMich
                    It somehow probably starts multiple instances. Disable the auto start and try to get it working manually first.
                    • T Offline
                      trividar
                      how can I do that?
                      MichMichM 1 Reply Last reply Reply Quote 0
                      • MichMichM Offline
                        MichMich @trividar
                        @trividar pm2 stop mm
                        check if it’s running pm2 list
                        No instances should be running at that point. then start the MM using npm start from your MagicMirror folder from a terminal running on your PI (so not via SSH)
