    MMM-PIR-Sensor restart problem
    26 Posts 5 Posters 22.6k Views 4 Watching
    • T Offline
      trividar
      @MichMich Thanks for your fast replay. I restart my Pi several times, but I have always the same problem. My MagicMirror starts normal and after 2 seconds the screen goes black.
      MichMichM 1 Reply Last reply Reply Quote 0
      • MichMichM Offline
        MichMich @trividar
        With the same error?
        • T Offline
          trividar
          Yes with the same error…
          • T Offline
            trividar
            Now i have disconnect the cables from pir sensor and restart my pi. After reboot my pi my Magicmirror start automaticlly normal and after 2 seconds they got again black. That crazy thing is, I press ctrl+w and the blackscreen goes away and the the Magicmirror works “under” the blackscreen well…
              paviro @trividar
              @trividar try changing the port in the config.js from 8080 to 8888 and reboot.
              – The Doctor
              • T Offline
                trividar
                @paviro I have now the same error just with 8888.
                • MichMichM Offline
                  MichMich
                  How do you start your Mirror?
                  • T Offline
                    trividar
                    with autostart (from wiki).
                    • MichMichM Offline
                      MichMich
                      It somehow probably starts multiple instances. Disable the auto start and try to get it working manually first.
                      • T Offline
                        trividar
                        how can I do that?
                        • MichMichM Offline
                          MichMich @trividar
                          @trividar pm2 stop mm
                          check if it’s running pm2 list
                          No instances should be running at that point. then start the MM using npm start from your MagicMirror folder from a terminal running on your PI (so not via SSH)
                            paviro
                            Moved this part of the topic into a new thread since it has nothing to do with the module.
                            – The Doctor
                            • T Offline
                              trividar
                              If i stop with pm2 stop mm and start my MM with npm start from terminal everything works fine, but without the PIR sensor. If i connect the sensor to my pi i get the blackscreen.
                              • MichMichM Offline
                                MichMich @paviro
                                @paviro See the replay in the other topic. It seems it has something to do with the module.
                                  paviro
                                  Strange no idea what could case that. Will check back…
                                  – The Doctor
                                  • T Offline
                                    trividar
                                    Thank you both for your help!
                                    How can I disable completely the MM autostart?
                                    • T Offline
                                      trividar
                                      and just to be 100% sure if its so right? 0_1465119368006_22c286dc-79a4-4cdc-a708-a9a20a6325ed.jpg
                                        paviro
                                        Looks fine. The thing that I don’t understand is how connection this could lead to a seconds start of a MM instance…
                                        – The Doctor
                                        • T Offline
                                          trividar
                                          did someone find any solution for my problem? i tried to delete the PIR-Modul and reinstall… but I have the same problem;o( THX
                                          • T Offline
                                            trividar
                                            So i tried to fix my problem with the PIR sensor. Now I have an other problem. Do someone knew what i do wrong? Now the PIR shut down HDMI if they detect a motion and I don’t have a chance to turn on just with a reboot of the pi.
                                            youtube
                                            Sorry for the bad quality!
