    MMM-PIR-Sensor restart problem
    26 Posts 5 Posters 21.6k Views 4 Watching
    • T Offline
      trividar
      @MichMich Thanks a lot for your help…that was simple;o)!
      Now my MagicMirror won’t start on the monitor;o(
      I just get a back screen an i couldn’t do anything, my monitor is still working but just black screen and nothing else. Also I can’t quit the MagicMirror with ctrl+w. I can just get access with shh… an If I try to stop magic mirror with pm2 stop mm it stops but the screen is still black. If I use over ssh my laptop and start with npm start the MagicMirror works well. If i disconnect the PIR sensor (hardware) then everything works well.
      I got this error if i start pm2 logs mm…
      You know what I do wrong? (Sorry for all this noob questions)
      MichMichM 1 Reply Last reply Reply Quote 0
      • MichMichM Offline
        MichMich @trividar
        EADDRINUSE:::8080 means there is already an app running on port 8080. Probably the app itself which you already started once. If you can’t figure out how to quit it, simply restart your Pi. This should solve it.
        • T Offline
          trividar
          @MichMich Thanks for your fast replay. I restart my Pi several times, but I have always the same problem. My MagicMirror starts normal and after 2 seconds the screen goes black.
          • MichMichM Offline
            MichMich @trividar
            With the same error?
            • T Offline
              trividar
              Yes with the same error…
              • T Offline
                trividar
                Now i have disconnect the cables from pir sensor and restart my pi. After reboot my pi my Magicmirror start automaticlly normal and after 2 seconds they got again black. That crazy thing is, I press ctrl+w and the blackscreen goes away and the the Magicmirror works “under” the blackscreen well…
                  paviro @trividar
                  @trividar try changing the port in the config.js from 8080 to 8888 and reboot.
                  – The Doctor
                  • T Offline
                    trividar
                    @paviro I have now the same error just with 8888.
                    • MichMichM Offline
                      MichMich
                      How do you start your Mirror?
                      • T Offline
                        trividar
                        with autostart (from wiki).
                        • MichMichM Offline
                          MichMich
                          It somehow probably starts multiple instances. Disable the auto start and try to get it working manually first.
                          • T Offline
                            trividar
                            how can I do that?
                            • MichMichM Offline
                              MichMich @trividar
                              @trividar pm2 stop mm
                              check if it’s running pm2 list
                              No instances should be running at that point. then start the MM using npm start from your MagicMirror folder from a terminal running on your PI (so not via SSH)
                                paviro
                                Moved this part of the topic into a new thread since it has nothing to do with the module.
                                – The Doctor
                                • T Offline
                                  trividar
                                  If i stop with pm2 stop mm and start my MM with npm start from terminal everything works fine, but without the PIR sensor. If i connect the sensor to my pi i get the blackscreen.
                                  • MichMichM Offline
                                    MichMich @paviro
                                    @paviro See the replay in the other topic. It seems it has something to do with the module.
                                      paviro
                                      Strange no idea what could case that. Will check back…
                                      – The Doctor
                                      • T Offline
                                        trividar
                                        Thank you both for your help!
                                        How can I disable completely the MM autostart?
                                        • T Offline
                                          trividar
                                          and just to be 100% sure if its so right? 0_1465119368006_22c286dc-79a4-4cdc-a708-a9a20a6325ed.jpg
                                            paviro
                                            Looks fine. The thing that I don’t understand is how connection this could lead to a seconds start of a MM instance…
                                            – The Doctor
