    MMM-PIR-Sensor restart problem
    26 Posts 5 Posters 22.6k Views 4 Watching
      paviro @trividar
      @trividar try changing the port in the config.js from 8080 to 8888 and reboot.
      – The Doctor
      • T Offline
        trividar
        @paviro I have now the same error just with 8888.
        • MichMichM Offline
          MichMich
          How do you start your Mirror?
          • T Offline
            trividar
            with autostart (from wiki).
            • MichMichM Offline
              MichMich
              It somehow probably starts multiple instances. Disable the auto start and try to get it working manually first.
              • T Offline
                trividar
                how can I do that?
                MichMichM 1 Reply Last reply Reply Quote 0
                • MichMichM Offline
                  MichMich @trividar
                  @trividar pm2 stop mm
                  check if it’s running pm2 list
                  No instances should be running at that point. then start the MM using npm start from your MagicMirror folder from a terminal running on your PI (so not via SSH)
                    paviro
                    Moved this part of the topic into a new thread since it has nothing to do with the module.
                    – The Doctor
                    • T Offline
                      trividar
                      If i stop with pm2 stop mm and start my MM with npm start from terminal everything works fine, but without the PIR sensor. If i connect the sensor to my pi i get the blackscreen.
                      • MichMichM Offline
                        MichMich @paviro
                        @paviro See the replay in the other topic. It seems it has something to do with the module.
                          paviro
                          Strange no idea what could case that. Will check back…
                          – The Doctor
                          • T Offline
                            trividar
                            Thank you both for your help!
                            How can I disable completely the MM autostart?
                            • T Offline
                              trividar
                              and just to be 100% sure if its so right? 0_1465119368006_22c286dc-79a4-4cdc-a708-a9a20a6325ed.jpg
                                paviro
                                Looks fine. The thing that I don’t understand is how connection this could lead to a seconds start of a MM instance…
                                – The Doctor
                                • T Offline
                                  trividar
                                  did someone find any solution for my problem? i tried to delete the PIR-Modul and reinstall… but I have the same problem;o( THX
                                  • T Offline
                                    trividar
                                    So i tried to fix my problem with the PIR sensor. Now I have an other problem. Do someone knew what i do wrong? Now the PIR shut down HDMI if they detect a motion and I don’t have a chance to turn on just with a reboot of the pi.
                                    youtube
                                    Sorry for the bad quality!
                                      Bangee Module Developer
                                      I’ve reinstalled mm2 on a new SD Card and copied all my modules up en it.
                                      Now I’ve got this error message with MMM-PIR-Module:
                                      mm-0 App threw an error during load
                                      mm-0 Error: Module version mismatch. Expected 49, got 48.
                                      mm-0     at Error (native)
                                      mm-0     at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:167:20)
                                      mm-0     at Object.Module._extensions..node (module.js:568:18)
                                      mm-0     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:167:20)
                                      mm-0     at Module.load (module.js:458:32)
                                      mm-0     at tryModuleLoad (module.js:417:12)
                                      mm-0     at Function.Module._load (module.js:409:3)
                                      mm-0     at Module.require (module.js:468:17)
                                      mm-0     at require (internal/module.js:20:19)
                                      mm-0     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi/lib/exports.js:1:97)
                                      mm-0 Whoops! There was an uncaught exception...
                                      mm-0 MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      mm-0 If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      mm-0 Launching application.
                                      Any ideas?
                                        Chiggo
                                        Not sure, but isn’t there a wiring mismatch in the picture of your post?
                                        Think you mixed up brown and orange.
                                        Orange (VCC), coming from PIR-Sensor, should go to PIN2 and brown (GND), coming from PIR, should go to PIN6.
                                        To your last post:
                                        I would prefer to add the modules from github, not copy.
                                        Are the libraries and drivers for wiring-pi already installed?
                                          WiringPi should be installed. I’ve tested this using this command: gipo readall
                                          The module is now installed using git. not copied.
                                          I’ve tried to rebuild… and also to rebulid electron.
                                          npm install --save-dev electron-rebuild
                                            paviro
                                            Module mismatch should be resolved now :)
                                            – The Doctor
