    Too many API calls in default weather module after update
    14 Posts 6 Posters 6.0k Views 6 Watching
      Perilax
      Hello together,
      Since the April update, I have an issue where the default weather module sends too many requests to the OpenWeathermap API. I reach the free limit of 1,000 requests after just a few hours.
      Here’s an extract from my config.js:
                              module: "weather",
                                      apiVersion: "3.0",
                                      weatherEndpoint: "/onecall",
                                      lat: "XXXXXX",
                                      lon: "XXXXXX",
                                      showSun: true,
                                      type: "current",
                                      appendLocationNameToHeader: false,
                                      apiKey: "XXXXXXX",
                                      updateInterval: 10*60*1000, // Update every 10 minutes
                              module: "weather",
                              header: "Wetter Vorschau",
                                      type: "forecast",
                                      apiVersion: "3.0",
                                      lat: "XXXXXX",
                                      lon: "XXXXX",
                                      apiKey: "XXXXX",
                                      fade: false,
                                      roundTemp: true,
                                      ignoreToday: true,
      Has anyone a solution to solve this problem ?
      S S 2 Replies Last reply
        sdetweil @Megawaldi
        @Megawaldi it is fixed in the develop branch for next release
        You can get the develop branch,
        Currently we only release 4 times a year January ,April, July, October
        See https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
          sdetweil @Perilax
          @Perilax @kristjanesperanto will have to answer, there was a big rewrite of the data collector side of weather.
            stephanvdplas @Perilax
            @Perilax
            I think you need these parameters:
            			updateInterval: 60 * 60 * 1000,
            			retryDelay: 60 * 60 * 1000,          // retry only once per hour
            P 1 Reply Last reply
              Perilax @stephanvdplas
              @stephanvdplas
              Is „retryDelay“ really working ? I can‘t find it in the documentation.
              I have two modules where I request the API every 10 minutes. So it should be around 300 requests per day.
              By far less than 1000.
              KristjanESPERANTOK 1 Reply Last reply
              • KristjanESPERANTOK
                KristjanESPERANTO Module Developer @Perilax
                Sam is right, that was caused by the big rewrite (which resolved other issues, particularly a fundamental architectural one).
                A fix is already in the develop branch: https://github.com/MagicMirrorOrg/MagicMirror/pull/4092
                Are you familiar enough with Git to test the develop branch?
                evroomE P 3 Replies Last reply
                • evroomE
                  evroom @KristjanESPERANTO
                  @perilax
                  Or just a quick work-around as the default for updateInterval for openweathermap is 10 minutes anyway.
                  Try to comment out those 2 lines with //.
                  @kristjanesperanto
                  Quick response; quick fix 👍
                  MagicMirror version: 2.37.0
                    Perilax @KristjanESPERANTO
                    @KristjanESPERANTO
                    I’ll test the develop branch tomorrow.
                    Thanks for the quick reply.
                    @evroom I added updateInterval to my config.js only after the problem occurred, because I thought it might be causing the issue.
                      sdetweil @Perilax
                      @Perilax see this link for how to get the develop branch
                      https://forum.magicmirror.builders/post/86422
                        @KristjanESPERANTO
                        The develop branch is working. API requests are back to normal.
                        Can I make this change manually on the master branch for now, or do I need to let the develop branch run until the next update ?
                        Thanks again for the quick help.
                        Also to @sdetweil
                          sdetweil @Perilax
                          @Perilax i would let the develop branch run. We are discussing a point release to pick up a few fixes.
                          If you use my upgrade script when next version is ready, it will switch you back to master
                            Perilax @sdetweil
                            I can´t use your update script, because I installed my MM with the proxmox helper script.
                              sdetweil @Perilax
                              @Perilax I’d still wait, and switch to master before next git pull, after July 1
                              M 1 Reply Last reply
                                Megawaldi @sdetweil
                                @sdetweil is this problem already fixed in the Release Version? I ask because i dont know about updateing or waiting for a fix
                                  sdetweil @Megawaldi
