    Too many API calls in default weather module after update
    14 Posts 6 Posters 5.7k Views 6 Watching
      sdetweil @Perilax
      @Perilax @kristjanesperanto will have to answer, there was a big rewrite of the data collector side of weather.
        stephanvdplas @Perilax
        @Perilax
        I think you need these parameters:
        			updateInterval: 60 * 60 * 1000,
        			retryDelay: 60 * 60 * 1000,          // retry only once per hour
          Perilax @stephanvdplas
          @stephanvdplas
          Is „retryDelay“ really working ? I can‘t find it in the documentation.
          I have two modules where I request the API every 10 minutes. So it should be around 300 requests per day.
          By far less than 1000.
          • KristjanESPERANTOK Offline
            KristjanESPERANTO Module Developer @Perilax
            Sam is right, that was caused by the big rewrite (which resolved other issues, particularly a fundamental architectural one).
            A fix is already in the develop branch: https://github.com/MagicMirrorOrg/MagicMirror/pull/4092
            Are you familiar enough with Git to test the develop branch?
            evroomE P 3 Replies Last reply Reply Quote 0
            • evroomE Offline
              evroom @KristjanESPERANTO
              @perilax
              Or just a quick work-around as the default for updateInterval for openweathermap is 10 minutes anyway.
              Try to comment out those 2 lines with //.
              @kristjanesperanto
              Quick response; quick fix 👍
              MagicMirror version: 2.37.0
                Perilax @KristjanESPERANTO
                @KristjanESPERANTO
                I’ll test the develop branch tomorrow.
                Thanks for the quick reply.
                @evroom I added updateInterval to my config.js only after the problem occurred, because I thought it might be causing the issue.
                  sdetweil @Perilax
                  @Perilax see this link for how to get the develop branch
                  https://forum.magicmirror.builders/post/86422
                    @KristjanESPERANTO
                    The develop branch is working. API requests are back to normal.
                    Can I make this change manually on the master branch for now, or do I need to let the develop branch run until the next update ?
                    Thanks again for the quick help.
                    Also to @sdetweil
                      sdetweil @Perilax
                      @Perilax i would let the develop branch run. We are discussing a point release to pick up a few fixes.
                      If you use my upgrade script when next version is ready, it will switch you back to master
                        Perilax @sdetweil
                        I can´t use your update script, because I installed my MM with the proxmox helper script.
                          sdetweil @Perilax
                          @Perilax I’d still wait, and switch to master before next git pull, after July 1
                            Megawaldi @sdetweil
                            @sdetweil is this problem already fixed in the Release Version? I ask because i dont know about updateing or waiting for a fix
                              sdetweil @Megawaldi
                              @Megawaldi it is fixed in the develop branch for next release
                              You can get the develop branch,
                              Currently we only release 4 times a year January ,April, July, October
                              See https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
