    MMM-Pinfo Not showing information
    Scheduled Pinned Locked Moved Solved System
    9 Posts 3 Posters 652 Views 2 Watching
    • plainbrokeP
      plainbroke
      installed update using Sams update script.
      MMM-Pinfo Not showing any information.
      Did get pull and npm install
      That did nothing.
      IDEAS???
        sdetweil @plainbroke
        @plainbroke I’m guessing the library the module uses is now down level from what MagicMirror is using
        I see you opened an issue., I don’t see any trouble logging in the module.
        Does anything show up in the pm2 logs?
        • plainbrokeP
          plainbroke @sdetweil
          Only issue showing in log is MMM-Globe not able to refresh after about 3 hours.
          I will disable it and see if that helps.
          • plainbrokeP
            plainbroke @plainbroke
            Do I need to be worried about this when using the update script.?
            force: line 1193: 0: Permission denied
            I forgot to ask last time.
              @plainbroke I dont know, can you send me the ~/MagicMirror/installers/upgrade.log
              Or open an issue in the repo and attach it there
              • plainbrokeP
                In route to email.
                  @plainbroke got em
                  • KristjanESPERANTOK
                    @plainbroke The module got an update which shout fix the issue :)
                    plainbrokeP 1 Reply Last reply Reply Quote 1
                    • plainbrokeP
                      plainbroke @KristjanESPERANTO
                      @KristjanESPERANTO
                      Thanks just did git pull and npm install both say up to date now.
                      It works now.
                      Thank you.
                      • plainbrokeP plainbroke marked this topic as a question on
                      • plainbrokeP plainbroke has marked this topic as solved on
