MMM-Pinfo Not showing information
installed update using Sams update script.
MMM-Pinfo Not showing any information.
Did get pull and npm install
That did nothing.
IDEAS??? -
@plainbroke I’m guessing the library the module uses is now down level from what MagicMirror is using
I see you opened an issue., I don’t see any trouble logging in the module.
Does anything show up in the pm2 logs?
Only issue showing in log is MMM-Globe not able to refresh after about 3 hours.
I will disable it and see if that helps. -
Do I need to be worried about this when using the update script.?force: line 1193: 0: Permission deniedI forgot to ask last time.
@plainbroke I dont know, can you send me the ~/MagicMirror/installers/upgrade.log
Or open an issue in the repo and attach it there
In route to email. -
@plainbroke got em
@plainbroke The module got an update which shout fix the issue :)
@KristjanESPERANTO
Thanks just did git pull and npm install both say up to date now.
It works now.
Thank you. -
P plainbroke marked this topic as a question on
P plainbroke has marked this topic as solved on
