    MMM-KitchenTimer - Touch-friendly countdown timer
    timertouchkitchen
    11 Posts 2 Posters 484 Views 2 Watching
      bwente
      Description:
      A newly refreshed fork of MMM-KitchenTimer, a responsive, touch-friendly countdown timer for MagicMirror².
      It provides a large countdown display, configurable quick-duration presets, and accessible controls for touch, mouse, and keyboard. Tap the time display to pause or resume the countdown, and use the Reset or Dismiss control to cancel the timer or silence its alarm.
      The module supports compact and full-screen layouts, optional alarm and button sounds, and reliable wall-clock timing. Active timers continue running and can finish while the module is hidden by page-management modules such as MMM-pages.
      MMM-KitchenTimer also provides incoming and outgoing MagicMirror notifications. Other modules can start, add time to, pause, resume, reset, or dismiss the timer. Semantic state notifications make it possible to integrate voice assistants, smart lights, MQTT bridges, physical controls, notification centers, and other automations without embedding hardware-specific behavior in the timer.
      This is a maintained fork of the module originally created by Tom Short, published with his permission. The original MIT attribution and existing configuration compatibility have been preserved.
      Screenshots:
      Download:
      https://github.com/bwente/MMM-KitchenTimer
      Installation:
      cd ~/MagicMirror/modules
      git clone https://github.com/bwente/MMM-KitchenTimer.git
      Version 1.2.0
      • Added a configurable alarmVolume option
      • Alarm volume accepts values from 0 to 1 and remains independent of button feedback volume
      • Invalid alarm-volume values fall back safely to full volume
      • Improved outgoing notification semantics for smart-home integrations
      • Starting a timer from a preset now emits KITCHEN_TIMER_STARTED
      • Adding time to a running or paused timer continues to emit KITCHEN_TIMER_UPDATED
      • Makes it easier for MQTT, Home Assistant, Alexa, and other integrations to distinguish new timers from
      Version 1.1.0
      • Added Bulgarian, Danish, German, English, Spanish, French, Hungarian, Dutch, Russian, and Thai translations
      • Follow MagicMirror’s global language setting automatically
      • Added localized controls, status messages, and accessibility labels
      • Preserve keyboard and touchscreen focus while the timer display updates
      • Added stable control identifiers for external integrations
      • Expanded automated test coverage
      Version 1.0.1
      • Keep active timers and completion events running while hidden
      • Improve compatibility with page-management modules such as MMM-pages
      Version 1.0.0
      • Modernized the original module as a maintained MagicMirror² module
      • Added large, touch-friendly controls
      • Added configurable quick-duration presets
      • Added tap-to-pause and resume behavior
      • Added compact and full-screen layouts
      • Added incoming timer-control notifications
      • Added outgoing semantic state and progress notifications
      • Preserved the original configuration options and MIT attribution
      NiggichN 2 Replies Last reply Reply Quote 2
      • NiggichN Offline
        Niggich @bwente
        @bwente Nice module. How can I change the size of the module. I try something at CSS but nothing works. I want to use the module at bottom_right. THX
          bwente @Niggich
          @Niggich Thanks! For bottom_right, try enabling the module’s built-in compact layout:
            module: "MMM-KitchenTimer",
            position: "bottom_right",
              compact: true,
          NiggichN 1 Reply Last reply Reply Quote 1
          • NiggichN Offline
            Niggich @bwente
            @bwente That’s it. Thank you. Is there a way to change the language to german?
              bwente @Niggich
              @Niggich Update the module and it will use you language setting in your overall config.
              NiggichN 1 Reply Last reply Reply Quote 2
              • NiggichN Offline
                Niggich @bwente
                @bwente thank you. I did already and it works.
                • NiggichN Offline
                  Niggich @bwente
                  Hey @bwente I have an Idea, but I don’t know if this is possible. I have the Screen with touch in my kitchen and also an Alexa and the old Echo Wall Clock. Maybe it’s possible to start the the Alexa Timer when I hit the Timer on my Touchscreen because I don’t have speakers at my Touchscreen.
                    bwente @Niggich
                    @Niggich it’s a good idea, but unfortunately it can’t directly start a normal Alexa timer.
                    One option is to pair your Screen with the Echo over Bluetooth. That would give you the alarm sound through the Echo, but it wouldn’t activate the timer indicator on the Echo Wall Clock.
                    Another possibility may be installing alexa-remote on the Mirror or use HA. The module could notify it when a timer starts, and it could then ask the Echo to set the corresponding timer. That should also activate the Wall Clock. maybe?
                    NiggichN 1 Reply Last reply Reply Quote 0
                    • NiggichN Offline
                      Niggich @bwente
                      @bwente Thank you for your answer. HA it’s a good idea, but how I tell HA I start the Timer on the mirror? I also have an iobroker. Maybe this helps…
                        bwente @Niggich
                        @Niggich
                        Yes. Since you use Home Assistant, MagicMirror can publish an MQTT message when the timer starts, and HA can start a matching Alexa timer on the Echo paired with the Wall Clock.
                        The catch is they are separate timers, not truly synced. Starting and canceling can be synced, but pausing the MagicMirror timer will not pause Alexa.
                        • NiggichN Offline
                          Niggich @bwente
                          @bwente
                          Ok, I try to configure MMM-MQTTbridge to connect the mirror to my HA. I think the connection from Mirror to HA is working but I don’t know how to configure the module to Send Notifications to my HA. Sorry…
