    MMM-KitchenTimer - Touch-friendly countdown timer
    timertouchkitchen
    33 Posts 3 Posters 1.9k Views 3 Watching
      bwente @Niggich
      @Niggich
      Yes. Since you use Home Assistant, MagicMirror can publish an MQTT message when the timer starts, and HA can start a matching Alexa timer on the Echo paired with the Wall Clock.
      The catch is they are separate timers, not truly synced. Starting and canceling can be synced, but pausing the MagicMirror timer will not pause Alexa.
      NiggichN 1 Reply Last reply Reply Quote 0
      • NiggichN
        Niggich @bwente
        @bwente
        Ok, I try to configure MMM-MQTTbridge to connect the mirror to my HA. I think the connection from Mirror to HA is working but I don’t know how to configure the module to Send Notifications to my HA. Sorry…
          bwente @Niggich
          @Niggich On the HA side you would listen for the timer topic.
          alias: Start Echo timer from MagicMirror
          triggers:
            - trigger: mqtt
              topic: magicmirror/kitchen-timer/started
          actions:
            - action: media_player.play_media
              target:
                entity_id: media_player.kitchen_echo
              data:
                media_content_type: custom
                media_content_id: >-
                  set a timer for
                  {{ trigger.payload_json.remainingSeconds | int }}
                  seconds
          • NiggichN
            Niggich @bwente
            @bwente Ok, thank you. So I don’t need to configure something at the MMM-MQTTbridge just in HA?
            edit: I try the whole afternoon, but I don’t know how to do. I also try it with MMM-HomeAssistant.
              bwente @Niggich
              @Niggich
              Something like this for your MMM-MQTTbridge config on your mirror.
                module: "MMM-MQTTbridge",
                disabled: false,
                  mqttServer: "mqtt://USERNAME:PASSWORD@192.168.1.10:1883",
                  stringifyPayload: true,
                  mqttConfig: {
                    // This example only sends MagicMirror events to MQTT.
                    listenMqtt: false,
                    interval: 300000,
                  notiConfig: {
                    listenNoti: true,
                    ignoreNotiId: ["CLOCK_MINUTE", "CLOCK_SECOND", "NEWS_FEED"],
                    ignoreNotiSender: ["system"],
                    qos: 0,
              then edit
              ~/MagicMirror/modules/MMM-MQTTbridge/dict/notiDictionary.js
              var notiHook = [
                  notiId: "KITCHEN_TIMER_STARTED",
                  notiPayload: [
                      notiMqttCmd: ["Kitchen timer started"],
              var notiMqttCommands = [
                  commandId: "Kitchen timer started",
                  mqttTopic: "magicmirror/kitchen-timer/started",
                  retain: false,
                  qos: 0,
              module.exports = { notiHook, notiMqttCommands };
              after restarting your mirror you should be able to listen for the topic: magicmirror/kitchen-timer/started in Home Assistant developer tools.
              • NiggichN
                Niggich @bwente
                @bwente Wow, you’re great. My Echo know I want to start a Timer but it’s asking for how long.
                  bwente @Niggich
                  Great, now that you’ve confirmed MQTT is working, the next step is to add the Home Assistant automation.
                  alias: MagicMirror kitchen timer started
                  triggers:
                    - trigger: mqtt
                  actions:
                      target:
                      data:
                          set a timer for
                          seconds
                  I think that will work. I don’t know if it needs to be escaped or not.
                  • NiggichN
                    Niggich @bwente
                    @bwente I add the automation already and change it again but the echo still asking “for how log should be the timer”… I also try to fix it with ChatGPT but this was not working.
                      bwente @Niggich
                      @Niggich looks like trigger.payload_json.remainingSeconds is empty or double quoted. Can you view just the payload and see?
                      • NiggichN
                        Niggich @bwente
                        @bwente I’m sorry but where I found trigger.payload_json.remainingSeconds?
                          sdetweil @Niggich
                          @Niggich in an HA. Automation are variable to help you do want you want
                          One of those is
                          trigger. - what started the automation
                          If you go into HA , settings, automations, pick any one,
                          Look at the traces (3 dot menu). You can see the variables and values for each step of the automation
                          NiggichN 1 Reply Last reply Reply Quote 1
                          • NiggichN
                            Niggich @sdetweil
                            @sdetweil Thank you. I don’t know if I’m right but this is the variable from the traces.
                            this:
                              entity_id: automation.timer
                              state: 'on'
                              attributes:
                                last_triggered: '2026-08-13T11:33:26.793052+00:00'
                                mode: single
                                current: 0
                                friendly_name: MagicMirror kitchen timer started
                              last_changed: '2026-08-14T20:14:37.860754+00:00'
                              last_reported: '2026-08-14T20:14:37.860754+00:00'
                              last_updated: '2026-08-14T20:14:37.860754+00:00'
                              context:
                                parent_id: null
                                user_id: null
                            trigger:
                              idx: '0'
                              alias: null
                              platform: mqtt
                              payload: >-
                                {"status":"running","remainingSeconds":60,"endsAt":1786738603487,"durationSeconds":60,"elapsedRatio":0}
                              qos: 0
                              description: mqtt topic magicmirror/kitchen-timer/started
                              payload_json:
                                status: running
                                remainingSeconds: 60
                                endsAt: 1786738603487
                                durationSeconds: 60
                                elapsedRatio: 0
                              sdetweil @Niggich
                              @Niggich so
                              trigger.payload.remainingSeconds
                              • NiggichN
                                Niggich @sdetweil
                                @sdetweil No, it is not working.
                                  sdetweil @Niggich
                                  @Niggich sorry, this is case sensitive and I had lower case s, see my edit
                                  • NiggichN
                                    Niggich @sdetweil
                                    @sdetweil No, it’s not working. This is the automation
                                    triggers:
                                      - trigger: mqtt
                                    actions:
                                        target:
                                          entity_id: media_player.echo_show_kuche
                                        data:
                                          media:
                                              set a timer for {{ trigger.payload.remainingSeconds | int }}
                                              seconds
                                            metadata: {}
                                      sdetweil @Niggich
                                      @Niggich if you examine the traces , what error is reported?
                                      • NiggichN
                                        Niggich @sdetweil
                                        @sdetweil sagte:
                                        This Error is shown: “Error rendering data template: UndefinedError: ‘str object’ has no attribute ‘remainingSeconds’”
                                        When I change the trigger back to trigger.payload_json.remainingSeconds is no Error reported an the Echo asks for how long should be the timer.
                                        The traces-Log says this.
                                        params:
                                          domain: media_player
                                          service: play_media
                                          service_data:
                                            entity_id:
                                              - media_player.echo_show_kuche
                                            media_content_id: set a timer for 60 seconds
                                          target:
                                            entity_id:
                                        running_script: false
                                          sdetweil @Niggich
                                          @Niggich ok. Good info
                                          I need to test this myself, but won’t be able to til tomorrow sometime. I also need to use my echo device which is currently not used
                                          • NiggichN
                                            Niggich @sdetweil
                                            @sdetweil Ok, don’t worry. I’m happy you help me. Thank you!
                                            EDIT:
                                            I made a copy of the automation and put a custom number of seconds to trigger. The Echo still asks for how long. The I changed from seconds to minutes an the timer starts.
                                            EDIT2: When I change the trigger to German language like this starte einen {{ trigger.payload_json.remainingSeconds | int }} sekunden timer the Timer starts. The only thing is that the Echo almost 4 seconds need to start the timer.
