    MMM-KitchenTimer - Touch-friendly countdown timer
    timertouchkitchen
    33 Posts 3 Posters 1.7k Views 3 Watching
    • NiggichN
      Niggich @bwente
      Hey @bwente I have an Idea, but I don’t know if this is possible. I have the Screen with touch in my kitchen and also an Alexa and the old Echo Wall Clock. Maybe it’s possible to start the the Alexa Timer when I hit the Timer on my Touchscreen because I don’t have speakers at my Touchscreen.
        bwente @Niggich
        @Niggich it’s a good idea, but unfortunately it can’t directly start a normal Alexa timer.
        One option is to pair your Screen with the Echo over Bluetooth. That would give you the alarm sound through the Echo, but it wouldn’t activate the timer indicator on the Echo Wall Clock.
        Another possibility may be installing alexa-remote on the Mirror or use HA. The module could notify it when a timer starts, and it could then ask the Echo to set the corresponding timer. That should also activate the Wall Clock. maybe?
        NiggichN 1 Reply Last reply Reply Quote 0
        • NiggichN
          Niggich @bwente
          @bwente Thank you for your answer. HA it’s a good idea, but how I tell HA I start the Timer on the mirror? I also have an iobroker. Maybe this helps…
            bwente @Niggich
            @Niggich
            Yes. Since you use Home Assistant, MagicMirror can publish an MQTT message when the timer starts, and HA can start a matching Alexa timer on the Echo paired with the Wall Clock.
            The catch is they are separate timers, not truly synced. Starting and canceling can be synced, but pausing the MagicMirror timer will not pause Alexa.
            • NiggichN
              Niggich @bwente
              @bwente
              Ok, I try to configure MMM-MQTTbridge to connect the mirror to my HA. I think the connection from Mirror to HA is working but I don’t know how to configure the module to Send Notifications to my HA. Sorry…
                bwente @Niggich
                @Niggich On the HA side you would listen for the timer topic.
                alias: Start Echo timer from MagicMirror
                triggers:
                  - trigger: mqtt
                    topic: magicmirror/kitchen-timer/started
                actions:
                  - action: media_player.play_media
                    target:
                      entity_id: media_player.kitchen_echo
                    data:
                      media_content_type: custom
                      media_content_id: >-
                        set a timer for
                        {{ trigger.payload_json.remainingSeconds | int }}
                        seconds
                • NiggichN
                  Niggich @bwente
                  @bwente Ok, thank you. So I don’t need to configure something at the MMM-MQTTbridge just in HA?
                  edit: I try the whole afternoon, but I don’t know how to do. I also try it with MMM-HomeAssistant.
                    bwente @Niggich
                    @Niggich
                    Something like this for your MMM-MQTTbridge config on your mirror.
                      module: "MMM-MQTTbridge",
                      disabled: false,
                        mqttServer: "mqtt://USERNAME:PASSWORD@192.168.1.10:1883",
                        stringifyPayload: true,
                        mqttConfig: {
                          // This example only sends MagicMirror events to MQTT.
                          listenMqtt: false,
                          interval: 300000,
                        notiConfig: {
                          listenNoti: true,
                          ignoreNotiId: ["CLOCK_MINUTE", "CLOCK_SECOND", "NEWS_FEED"],
                          ignoreNotiSender: ["system"],
                          qos: 0,
                    then edit
                    ~/MagicMirror/modules/MMM-MQTTbridge/dict/notiDictionary.js
                    var notiHook = [
                        notiId: "KITCHEN_TIMER_STARTED",
                        notiPayload: [
                            notiMqttCmd: ["Kitchen timer started"],
                    var notiMqttCommands = [
                        commandId: "Kitchen timer started",
                        mqttTopic: "magicmirror/kitchen-timer/started",
                        retain: false,
                        qos: 0,
                    module.exports = { notiHook, notiMqttCommands };
                    after restarting your mirror you should be able to listen for the topic: magicmirror/kitchen-timer/started in Home Assistant developer tools.
                    • NiggichN
                      Niggich @bwente
                      @bwente Wow, you’re great. My Echo know I want to start a Timer but it’s asking for how long.
                        bwente @Niggich
                        Great, now that you’ve confirmed MQTT is working, the next step is to add the Home Assistant automation.
                        alias: MagicMirror kitchen timer started
                        triggers:
                          - trigger: mqtt
                        actions:
                            target:
                            data:
                                set a timer for
                                seconds
                        I think that will work. I don’t know if it needs to be escaped or not.
                        • NiggichN
                          Niggich @bwente
                          @bwente I add the automation already and change it again but the echo still asking “for how log should be the timer”… I also try to fix it with ChatGPT but this was not working.
                            bwente @Niggich
                            @Niggich looks like trigger.payload_json.remainingSeconds is empty or double quoted. Can you view just the payload and see?
                            • NiggichN
                              Niggich @bwente
                              @bwente I’m sorry but where I found trigger.payload_json.remainingSeconds?
                                sdetweil @Niggich
                                @Niggich in an HA. Automation are variable to help you do want you want
                                One of those is
                                trigger. - what started the automation
                                If you go into HA , settings, automations, pick any one,
                                Look at the traces (3 dot menu). You can see the variables and values for each step of the automation
                                NiggichN 1 Reply Last reply Reply Quote 1
                                • NiggichN
                                  Niggich @sdetweil
                                  @sdetweil Thank you. I don’t know if I’m right but this is the variable from the traces.
                                  this:
                                    entity_id: automation.timer
                                    state: 'on'
                                    attributes:
                                      last_triggered: '2026-08-13T11:33:26.793052+00:00'
                                      mode: single
                                      current: 0
                                      friendly_name: MagicMirror kitchen timer started
                                    last_changed: '2026-08-14T20:14:37.860754+00:00'
                                    last_reported: '2026-08-14T20:14:37.860754+00:00'
                                    last_updated: '2026-08-14T20:14:37.860754+00:00'
                                    context:
                                      parent_id: null
                                      user_id: null
                                  trigger:
                                    idx: '0'
                                    alias: null
                                    platform: mqtt
                                    payload: >-
                                      {"status":"running","remainingSeconds":60,"endsAt":1786738603487,"durationSeconds":60,"elapsedRatio":0}
                                    qos: 0
                                    description: mqtt topic magicmirror/kitchen-timer/started
                                    payload_json:
                                      status: running
                                      remainingSeconds: 60
                                      endsAt: 1786738603487
                                      durationSeconds: 60
                                      elapsedRatio: 0
                                    sdetweil @Niggich
                                    @Niggich so
                                    trigger.payload.remainingSeconds
                                    • NiggichN
                                      Niggich @sdetweil
                                      @sdetweil No, it is not working.
                                        sdetweil @Niggich
                                        @Niggich sorry, this is case sensitive and I had lower case s, see my edit
                                        • NiggichN
                                          Niggich @sdetweil
                                          @sdetweil No, it’s not working. This is the automation
                                          triggers:
                                            - trigger: mqtt
                                          actions:
                                              target:
                                                entity_id: media_player.echo_show_kuche
                                              data:
                                                media:
                                                    set a timer for {{ trigger.payload.remainingSeconds | int }}
                                                    seconds
                                                  metadata: {}
                                            sdetweil @Niggich
                                            @Niggich if you examine the traces , what error is reported?
