    How to hide Splash screen on boot or edit Splash screen on boot?
    12 Posts 7 Posters 13.0k Views 6 Watching
    • lolobyteL Offline
      lolobyte
      Hi, if you have installed the jessie plex version, you have to start
      sudo raspi-config
      At point 3 Boot Options it is possiblr to general disable or enable the splash screen on boot.
      If you have an normal jessie without plex the use a custom splash screen
      sudo apt-get install fbi
      Copy your custom splash image to /etc/ and name it splash.png.
      Next, create an init.d script called “asplashscreen” in “/etc/init.d/”.
      Create now this script with
      sudo nano /etc/init.d/asplashscreen
      #! /bin/sh
      ### BEGIN INIT INFO
      # Provides:          asplashscreen
      # Required-Start:
      # Required-Stop:
      # Should-Start:
      # Default-Start:     S
      # Default-Stop:
      # Short-Description: Show custom splashscreen
      # Description:       Show custom splashscreen
      ### END INIT INFO
      do_start () {
          /usr/bin/fbi -T 1 -noverbose -a /etc/splash.png
          exit 0
      case "$1" in
        start|"")
          do_start
        restart|reload|force-reload)
          echo "Error: argument '$1' not supported" >&2
          exit 3
        stop)
          # No-op
        status)
          exit 0
          echo "Usage: asplashscreen [start|stop]" >&2
          exit 3
      esac
      Then make that script executable and install it for init:
      sudo chmod a+x /etc/init.d/asplashscreen
      sudo insserv /etc/init.d/asplashscreen
      Reboot and watch your custom splash screen:
      sudo reboot
      If you want to hide most of the Boot text then follow this step:
      sudo nano /boot/cmdline.txt
      may look something like this:
      tty3: starts with console 3 to hide the boot messages!
      dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty3 loglevel=3 logo.nologo root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      good luck
      Mod-Edit: Please use markdown, otherwise this becomes totally unreadable.
      N 1 Reply Last reply Reply Quote 1
      • N Offline
        nobita @lolobyte
        @lolobyte Thanks your help,I will try later
        • lolobyteL Offline
          lolobyte
          Sorry, don’ know who has written this…
          Probably a Moderator.
          What please is “markdown” and how to use it?
          • brobergB Offline
            broberg Project Sponsor @lolobyte
            @lolobyte
            Here is a documentation of markdown :
            http://commonmark.org/help/
            • schlachtkreuzer6S Offline
              schlachtkreuzer6
              The the easiest way to change the splash screen is changing the picture ;) https://pi280.wordpress.com/2016/10/17/about-that-pixel-splash-screen/
              • N Offline
                nobita @schlachtkreuzer6
                @schlachtkreuzer6 I mean Splash screen on boot like this0_1486022813410_S__4210701.jpg
                yawnsY schlachtkreuzer6S 2 Replies Last reply Reply Quote 2
                • yawnsY Offline
                  yawns Moderator @nobita
                  @nobita
                  I did not check, so this is all theory.
                  The splashscreen is using plymouth, so you should be able to change it the “common way”:
                  http://www.bodhilinux.com/w/changing-plymouth-bootsplash/
                    schlachtkreuzer6 @nobita
                    @nobita yeah just change that image to another image (in the standard plymoth directory) and you are fine. i did that like this, before MM v2.1 with the splash screen was released, because that wohle plymouth stuff did not work for me. and there just few comandlines and worked perfectly!
                      bachoo786 @schlachtkreuzer6
                      @schlachtkreuzer6 how do you change the image? In which folder is the image?
                        sdetweil @bachoo786
                        @bachoo786 >In which folder is the image?
                        /usr/share/plymouth/themes
                        this shows the list of available
                         plymouth-set-default-theme --list
                        this resets to default
                        plymouth-set-default-theme --reset
                        see the installer code (and the install.log, as install changed the splash screen image)
