    Weatherforecast Wunderground module question
    17 Posts 7 Posters 15.1k Views 5 Watching
      RedNax Module Developer
      For me it’s the availability of local weatherstations (@ a location close to me). OpenWeatherMap’s closest match to my location is > 10km away.
      Also there’s an extreme amount of data available. Language settings which will provide texts (as in the pic above) in your local language…
      Also (i understand) it’s used a lot in domotica systems.
      Plus i thought it’d be fun to try :D
      • MichMichM
        MichMich
        Interesting. Don’t know how much time you want to spent on building it, but is would be awesome if you can change the current weather modules in a way a user can configure the weather source. So make it configurable.
        If you’re able to make a good stable solution for it (and built it in a way we can add other feeds as well), we could update the core modules.
        • K
          KirAsh4 Moderator
          I’m actually working on my own WUnderground module as well. I like them also for finding a closest station, but also because for some dumb reason, OpenWeatherMap is often REALLY wrong when it comes to the current conditions. The forecast is fairly accurate, but many times it would say it’s 20-30 degrees cooler than it actually is in the current conditions. It’s the same thing when I look on their web site too, so I know it’s not the module messing up. It’s whatever they are using for data collecting, it’s horribly wrong.
            desq
            I´m also a heavy user of wunderground and appreciate such a Modul.
            (So I could use, indirectly, the weather station of my neighbor.
              mattlugar @desq
              I’m modifying for wunderground now too. I’m finding openweathermap horribly wrong sometimes (today they say showers here and every other forecast system says sun).
                mattlugar
                I’ve modified the existing weatherforecast module to utilize weather underground… I’m utilizing the weather underground default icons for now. Not sure if it is something of interest for me to modularize or not?
                alt text
                  pugsly
                  yes, very interested. Please if it wouldn’t be too much trouble, a module would be great, including the colors.
                    mattlugar
                    I just finished getting it all coded up. The colors are simply css modifications (I can post how I did that in the README). About to grab some dinner then I’ll finish documentation and figure out how to set it up on GitHub.
                      mattlugar @pugsly
                      Posted!!! Let me know what you think.
                      link text
                      • cowboysdudeC
                        This is awesome. I’ve installed added the info to the modules directory, adjusted the config.js and defaultmodules.js but it just sits and says “Loading…” and never loads.
                        I have api key and my info is loaded as NY/Elmira and I’ve also tried NY/Pine_City
                        Did I miss something here?
                        OH by the way this module is truly awesome!! Great job! Thank you
                        • cowboysdudeC
                          cowboysdude Module Developer @cowboysdude
                          @cowboysdude said in Weatherforecast Wunderground module question:
                          UPDATE I found the issue… wrong api key… It’s working GREAT now!!!
                          • K
                            KirAsh4 Moderator
                            There shouldn’t be any reason to edit 'defaultmodules.js', that’s only specific to the default modules that MM comes with. Any modules that you install does not go in the default folder, but simply in MagicMirror/modules/<module_name> …
                            • cowboysdudeC
                              cowboysdude Module Developer @KirAsh4
                              @KirAsh4 Ok got it!! Thank you!!! :)
