    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 415.7k Views 51 Watching
      PointPubMedia
      I’m stilling seeing mm instead of cm when we are having snow… normal ?
        RedNax Module Developer @PointPubMedia
        @PointPubMedia Not really… typo in the code. Fixed now… (hopefully)
          PointPubMedia
          Working now ;)
          • O Offline
            ostfilinchen @anatius
            @RedNax:
            @anatius said in Weatherunderground - currently - hourly - daily - configurable:
            @wjdw87
            this.forecastText = this.forecastText.replace(/(.*\d+)(C)(.*)/gi, "$1°C$3");
            around line 937 in MMM-WunderGround.js should do the trick
            do you have change this also?
              RedNax Module Developer @ostfilinchen
              @ostfilinchen Now i have, and thanks to @anatius for this!
                Renfield
                @RedNax
                Thanks for the great module!
                I’ve fairly heavily modified it to my own preferences and soI don’t want to roll to the latest versions. I’m getting alerts that there’s a new version available and would like to not have those alerts displayed as I don’t wish to update and lose my changes. Is there a way to not have the version update alerts but still get the weather-related alerts? I’m not familiar enough with the MM infrastructure to figure this one out.
                Thanks again for the great work!
                Ren
                • L Offline
                  lolobyte
                  Hello developer @RedNax
                  Your module update is nice but please don’t waste so many place with the new layout.
                  Please shrink the space between the lines.
                    RedNax Module Developer @lolobyte
                    @lolobyte I’m sorry to hear you’re not happy with the layout. Could you be a bit more precide on the nature of your issue? Are the icons too large, too much information… A screenshot with arrows would be nice.
                    Thanks!
                    O L 3 Replies Last reply Reply Quote 0
                    • O Offline
                      ostfilinchen @RedNax
                      @RedNax the space between the lines in the forecasttable is too big an the Currentweather icon is also to big. My Set was 30% size of the Currentweather icon. With this size it looks good
                      • L Offline
                        lolobyte @RedNax
                        @RedNax
                        here a sample of the module from my Browser.
                        It looks on the real mirror same.
                        • O Offline
                          @RedNax can you please make the color Icons smaller? The Currentweather icon is too big with 100% size. With this icon size, the Module Uses too many space on the mirror.
                          A other way, is to make it scalable by custom.css.
                          What Do you think about this?
                            @ostfilinchen Better now?
                            O L 2 Replies Last reply Reply Quote 1
                            • O Offline
                              @RedNax yeah. Now it’s perfect. Great job!
                              • L Offline
                                lolobyte @RedNax
                                @RedNax
                                good morning. What’s happened?.
                                What did you change?
                                • O Offline
                                  ostfilinchen @lolobyte
                                  @lolobyte He changed the size of the color icon. So the Module now looks good on the mirror. If the size isn’t good for your mirror, you can change it in your custom.css
                                  • L Offline
                                    lolobyte @ostfilinchen
                                    @ostfilinchen
                                    hi, it’s a new version?
                                    May i do a git pull?
                                    • O Offline
                                      @lolobyte yes. Just Do it. I’m happy now
                                      • L Offline
                                        @ostfilinchen Niiiiice!
                                        @RedNax : Thank you. Good job. It looks now very good again.
                                          PointPubMedia
                                          I think I found a little bug… using coloricon: true, the main icon is in color, but not the small ones… and the first 3 row got no icons…
                                          • cowboysdudeC Offline
                                            cowboysdude Module Developer @PointPubMedia
                                            @PointPubMedia said in Weatherunderground - currently - hourly - daily - configurable:
                                            Oddly enough I’m here for the same reason LOL I was trying to figure out …
                                            The main ‘icon’ is an actual img… the smaller ones are actual icons… so when you updated you got the actual images… the icons are standard and have to be ‘colorized’… soo…
                                            Add this to your custom.css file and enjoy :)
                                            .wi-sunrise {
                                            color: #ffd700;
                                            .wi-sunset {
                                            color: #ffa500;
                                            .wi-day-sunny {
                                            color: #ffff00;
                                            .wi-night-showers {
                                            color: #55acee;
                                            .wi-degrees {
                                            color: #415;
                                            .wi-rain {
                                            color: #55acee;
                                            .wi-showers {
                                            color: #55acee;
                                            .wi-night-showers {
                                            color: #55acee;
                                            .wi-night-alt-cloudy-windy {
                                            color: #aaa;
                                            .wi-night-cloudy {
                                            color: #aaa;
                                            .wi-cloudy {
                                            color: #aaa;
                                            .wi-day-cloudy {
                                            color: #aaa;
                                            .wi-cloudy {
                                            color: #aaa;
                                            .wi-cloudy-windy {
                                            color: #aaa;
                                            .wi-showers {
                                            color: #55acee;
                                            .wi-thunderstorm {
                                            color: #ff00ff;
                                            .wi-snow {
                                            color: #fff;
                                            .wi-fog {
                                            color: #999;
                                            .wi-night-clear {
                                            color: #fff;
                                            .wi-night-rain {
                                            color: #55acee;
                                            .wi-night-thunderstorm {
                                            color: #ff00ff;
                                            .wi-night-snow {
                                            color: #fff;
                                            .wi-sunrise {
                                            color: #ffd700;
                                            .wi-sunset {
                                            color: #ffa500;
                                            .wi-day-sunny {
                                            color: #ffff00;
                                            .wi-night-showers {
                                            color: #55acee;
                                            .wi-degrees {
                                            color: #415;
                                            .wi-rain {
                                            color: #55acee;
                                            .wi-showers {
                                            color: #55acee;
                                            .wi-night-showers {
                                            color: #55acee;
                                            color: #aaa;
                                            .wi-night-cloudy {
                                            color: #aaa;
                                            .wi-cloudy {
                                            color: #aaa;
                                            .wi-day-cloudy {
                                            color: #aaa;
                                            .wi-cloudy {
                                            color: #aaa;
                                            .wi-cloudy-windy {
                                            color: #aaa;
                                            .wi-showers {
                                            color: #55acee;
                                            .wi-thunderstorm {
                                            color: #ff00ff;
                                            .wi-snow {
                                            color: #fff;
                                            .wi-fog {
                                            color: #999;
                                            .wi-night-clear {
                                            color: #fff;
                                            .wi-night-rain {
                                            color: #55acee;
                                            color: #ff00ff;
                                            .wi-night-snow {
                                            color: #fff;
                                            • 10
                                            • 4 / 10
