[MMM-Buttons] Not recognizing button presses
23 Posts 3 Posters 17.0k Views 2 Watching
    Mar
    module is great but doesnt seem to be recognizing my clicks. its not sending out a notification, i only have buttons installed for testing so not sure if its that?
    • I Offline
      istepgueu
      For testing in terminal :
      1- Create a button.py file with this :
      import RPi.GPIO as GPIO
      import time
      GPIO.setmode(GPIO.BCM)
      GPIO.setup(24, GPIO.IN, pull_up_down=GPIO.PUD_UP)
      GPIO.setup(25, GPIO.IN, pull_up_down=GPIO.PUD_UP)
      tries = 0
      while (tries < 200):
          if GPIO.input(25):
              print("Open")
          else:
              print ("Close")
          time.sleep(0.5)
          tries = tries + 1
      #GPIO.cleanup()           # clean up GPIO on normal exit
      2 - Execute with “python button.py”
      3 - Test your button.
      M J 3 Replies Last reply Feb 5, 2017, 6:17 PM Reply Quote 1
        Mar @istepgueu
        @istepgueu thanks, ive done this and its working properly and registers all my clicks.
          Mar @istepgueu
          @istepgueu im assuming the following would just send out a test broadcast that the pm2 logs can see? It sees the notifications from all the other modules i.e CALENDA_EVENTS etc… when they happen.
                              module: 'MMM-Buttons',
                                  buttons: [
                                          pin: 5,
                                          shortPress: {
                                              notification: "TEST_ACTION",
                                              payload: {action: "ACTIONON"}
                                          longPress: undefined
            Jopyth Moderator @istepgueu
            @istepgueu Can I add the snippet and instructions to the readme?
            I 1 Reply Last reply Feb 5, 2017, 7:37 PM Reply Quote 0
            • I Offline
              istepgueu @Jopyth
              @Jopyth Yes of course !
              M 1 Reply Last reply Feb 5, 2017, 7:38 PM Reply Quote 1
                Mar @istepgueu
                @istepgueu So my button registers properly but its not sending out a notification at all. There are no errors and my mirror loads correctly. I’m using the pin5:test code above.
                I 1 Reply Last reply Feb 5, 2017, 7:43 PM Reply Quote 0
                • I Offline
                  istepgueu @Mar
                  @Mar you can you test with this code and capture log from firebug
                                  pin: 5,
                                  longPress: {
                                      title: "Power off",
                                      message: "Keep pressed for 3 seconds to shut down",
                                      imageFA: "power-off",
                                      notification: "REMOTE_ACTION",
                                      payload: {action: "SHUTDOWN"}
                                  shortPress: undefined
                  M 1 Reply Last reply Feb 5, 2017, 7:48 PM Reply Quote 0
                    Mar @istepgueu
                    @istepgueu Alright now this is weird. I have my MM running via HDMI, and also opened it up in a Chrome tab on my laptop. When i press the buttong the inspector shows the log of the button and I get a popup on Chrome. But nothing is happening on the screen connected to the actual pi?
                    I 1 Reply Last reply Feb 5, 2017, 7:49 PM Reply Quote 0
                    • I Offline
                      istepgueu @Mar
                      @Mar I suppose you have try
                      pm2 restart mm
                      M 1 Reply Last reply Feb 5, 2017, 7:53 PM Reply Quote 0
                      1 / 3
