    Simple Music Player Module
    musicaudioplayer
    41 Posts 19 Posters 56.7k Views 21 Watching
      1m2 @yawns
      @yawns
      Dude, thanks a Mill!
      So for this music one it would be
      cd to my MagicMirror/modules directory and execute the below as well.
      git clone https://github.com/masters1222/mm-music-player
      Wow, doesn’t get easier than that! LOL
      Thanks for the quick response man!
      *** Did an EDIT correction on the which directory to CD to since @cowboysdude was nice enough to point that out, given that I didn’t pay attention. I didn’t want anyone else to find this later and have the same mistake happen to them because of me. LOL
      • cowboysdudeC
        cowboysdude Module Developer @1m2
        @1m2 Don’t forget… it’s not the MagicMirror dir it’s the /MagicMirror/modules dir before you do a git clone or you’ll be putting it directly in the MM folder instead of the modules folder ;)
        1 1 Reply Last reply Reply Quote 0
          1m2 @cowboysdude
          @cowboysdude
          Funk it… I was already troubleshooting cause I had already did it! LOL!!!
          Now I have to look up how to remove them, I haven’t done linux in 10 years.
          That’s what happens when you get too excited and don’t pay attention. DOH.
          Thanks!
          • cowboysdudeC
            @1m2 said in Simple Music Player Module:
            @cowboysdude
            Thanks!
            Just open up a folder and delete it :)
            OR from terminal window:
            sudo rm -rf folderName
            • T
              theusu5k
              i really like this module,it can’t be done a web version,to control the music player from a web page?
              cowboysdudeC 1 2 Replies Last reply Reply Quote 0
              • cowboysdudeC
                cowboysdude Module Developer @theusu5k
                @theusu5k That gets a lot more difficult…
                You have to find an api that allows it…
                  broberg Project Sponsor @cowboysdude
                  @cowboysdude well, he should be able to send http get to the syslog module and then let the syslog send a notification to the player module.
                  But, well, it’s a long way around 😀
                    1m2 @theusu5k
                    @theusu5k Yeah, Google Music would be a bomb widget on here.
                    • L
                      lucallmon
                      Is there a way to link the music directory to a thumb drive instead of having it in the modules folder on the SD card?
                        broberg Project Sponsor @lucallmon
                        @lucallmon either you change the directory in the players .js file or you link the music folder to the thumbdrive
                          dbaler
                          If you have a nas / networked storage and want to use music files from there, how would you do that?
                            broberg Project Sponsor @dbaler
                            @dbaler My higly noobish answer is Samba, and mount a network folder.
                              dbaler @broberg
                              @broberg Just change the directory in which JS file?
                                @dbaler If you are not using the default Music folder you could actually mount your network folder directly in that folder. No need to alter anything in the js files
                                Here is a easy to follow tutorial on how you mount a smb share in linux :
                                https://www.howtogeek.com/176471/how-to-share-files-between-windows-and-linux/
                                  Preve @cowboysdude
                                  @cowboysdude Is that “show list” already available?
                                  • aro28A
                                    aro28
                                    Hi Eof,
                                    Do you know why mm-music-player module is not loading even i added below code to config file? I downloaded and copied mm-music-player folder to MM’s Modules folder. Do i need to do something else?
                                    module: ‘mm-music-player’,
                                    position: ‘bottom_left’,
                                    startingVolume: 20,
                                    fadeDuriation: 2000
                                    Thank you!
                                      DrCastor
                                      Hi aro28,
                                      I had the same problem, so I decided to take a look at why this module couldn’t be loaded.
                                      The issues is in the Node_Helper.js given, which is mistaken. The structure is wrong. It looks like a quick adaptation of a ctrl+C/ctrl+V made from index.js, found in the node_helper folder (MM core folders).
                                      I’m actually tweeking it a bit. I’ll give you news when i get it worked nicely.
                                      (In fact, it seems i can now load it, but since my speaker are broke, i cant be sure it reads files… I’ll change them tomorrow)
                                      aro28A 1 Reply Last reply Reply Quote 0
                                      • aro28A
                                        aro28 @DrCastor
                                        @DrCastor
                                        Great! Thank you for reply. I hope you will succeed.
                                          DrCastor
                                          Ok, found bad speakers, but at least, they allow me to test it. It works :). I’m a real noob, so some useless things may still be there. But at least, it will do the trick
                                          Go to the node_helper.js file, and change it this way:
                                          var Class = require("../../js/class.js");
                                          var express = require("express");
                                          var path = require("path");
                                          	init: function() {
                                          		console.log("Initializing mm-music-player module helper ...");
                                          	start: function() {
                                          		this.expressApp.get('/music', function (req, res) {
                                          			var fs = require('fs');
                                          			var path = require('path');
                                          			var files = [];
                                          			fs.readdir('modules/mm-music-player/music', (err, data) => {
                                          				for(i = 0; i < data.length; i++){
                                          					if(path.extname(data[i]) == ".mp3"){
                                          						files.push(data[i]);
                                          				res.send(files);
                                          	/* setExpressApp(app)
                                          	 * Sets the express app object for this module.
                                          	 * This allows you to host files from the created webserver.
                                          	 * argument app Express app - The Express app object.
                                          	setExpressApp: function(app) {
                                          		this.expressApp = app;
                                          		var publicPath = this.path + "/public";
                                          		app.use("/" + this.name, express.static(publicPath));
                                          If luck is by your side, it will work ;)
                                          • aro28A
                                            aro28 @DrCastor
                                            @DrCastor said in Simple Music Player Module:
                                            Could you please send a full code of “node_helper.js” file?
                                            Thanks in advance,
                                            • 2 / 3
