    not able to profileswitch/schedule LocalTransport module
    19 Posts 3 Posters 13.0k Views 2 Watching
      dfuerst @tosti007
      @tosti007 thanks in advance
        Jopyth Moderator @dfuerst
        @dfuerst @tosti007 Ok, turns out I made a mistake with my notifications. It is now working with all modules I want it to work. Maybe I can check Localtransport tomorrow.
        • tosti007T Offline
          tosti007 Module Developer
          @dfuerst Unfortunately I did not have as much time this weekend as I hoped it would have. However @Jopyth came up with a fix that should solve this. (Thank you @Jopyth) Pull the new changes and your problem should be solved :D
          Edit: I gave it a quick test and it seems to be working fine!
          If there is anything don't hesitate to contact me!
          ProfileSwitcher, TouchNotifications
            dfuerst
            did a “git pull”, now it isn’t working anymore at all. (no action after button longpress)
            do i have to do something special after a git pull?
              dfuerst
              because the new version didn’t work anymore i reinstalled VERSION 2 from your REPO:
              now its working again , of course not hiding the localtransport module.
              any ideas why this version starts upon button press and the 8hours old one not?
              tosti007T 1 Reply Last reply Reply Quote 0
              • tosti007T Offline
                tosti007 Module Developer @dfuerst
                @dfuerst hmm, ouch. First of all sorry for the inconvenience. If you have the most up-to-date version set useLockStrings to false does it work like the original version 2?
                  dfuerst @tosti007
                  @tosti007 it did nothing.
                    dfuerst
                    i mean, the newest version did nothing.
                    after copying the code of the previous version into the .js file it worked again, of course not hiding localtransport.
                    many thanks for your effort
                    • tosti007T Offline
                      @dfuerst that’s unfortunate. There is another problem currently going on, since I used code that isn’t supported on all browsers. My first thought now is that it might be related. I will fix this soon and hope that this was the issue. What browser are you using?
                        dfuerst @tosti007
                        @tosti007 i use a RPi3 with standard Raspbian.
                        i always test via “pm2 start mm”
