    not able to profileswitch/schedule LocalTransport module
    19 Posts 3 Posters 12.7k Views 2 Watching
      Jopyth Moderator @dfuerst
      @dfuerst @tosti007 Ok, turns out I made a mistake with my notifications. It is now working with all modules I want it to work. Maybe I can check Localtransport tomorrow.
      • tosti007T Offline
        tosti007 Module Developer
        @dfuerst Unfortunately I did not have as much time this weekend as I hoped it would have. However @Jopyth came up with a fix that should solve this. (Thank you @Jopyth) Pull the new changes and your problem should be solved :D
        Edit: I gave it a quick test and it seems to be working fine!
        If there is anything don't hesitate to contact me!
        ProfileSwitcher, TouchNotifications
          dfuerst
          did a “git pull”, now it isn’t working anymore at all. (no action after button longpress)
          do i have to do something special after a git pull?
            dfuerst
            because the new version didn’t work anymore i reinstalled VERSION 2 from your REPO:
            now its working again , of course not hiding the localtransport module.
            any ideas why this version starts upon button press and the 8hours old one not?
            tosti007T 1 Reply Last reply Reply Quote 0
            • tosti007T Offline
              tosti007 Module Developer @dfuerst
              @dfuerst hmm, ouch. First of all sorry for the inconvenience. If you have the most up-to-date version set useLockStrings to false does it work like the original version 2?
                dfuerst @tosti007
                @tosti007 it did nothing.
                  dfuerst
                  i mean, the newest version did nothing.
                  after copying the code of the previous version into the .js file it worked again, of course not hiding localtransport.
                  many thanks for your effort
                  • tosti007T Offline
                    @dfuerst that’s unfortunate. There is another problem currently going on, since I used code that isn’t supported on all browsers. My first thought now is that it might be related. I will fix this soon and hope that this was the issue. What browser are you using?
                      dfuerst @tosti007
                      @tosti007 i use a RPi3 with standard Raspbian.
                      i always test via “pm2 start mm”
                      • tosti007T Offline
                        @dfuerst I fixed that backwards compatibility, but this does unfortunatly not solve the problem (tested it). I did found the reason why it doesn’t work, however I do not have a quickfix for this. I will look at it in the following days after doing some research.
