    MMM-MotionEye - surveillance video stream on your mirror!
    70 Posts 15 Posters 103.2k Views 15 Watching
    • lolobyteL
      lolobyte @Cato
      @Cato
      Thank you for your answer.
      I just tried MotionEyeOS before i went to Motion.
      In my eyes it wasn’t configurable with my desired functionality.
      I just hoped there is a possibility to implement foreign streams.
      CatoC 1 Reply Last reply
      • CatoC
        Cato Module Developer @lolobyte
        @lolobyte As long as the software can provide a “motion jpeg”-stream, it can be supported.
        Basically, you can test it your selv by making a local .html-file with <img src="xxxxx" />
        • E
          emos
          For some reason i just get a “broken” picture icon, and if i try to open http://MotionEyeIP/motioneye/1 the site just says:
          {"error": "not found"}
          I have disable the password for the ‘Surveillance Username’ so no login is required.
          I know the cam is available and motioneyos is working as normal. If i open http://192.168.1.200:8080/picture/1/current/ in my browser i can see the last snapshot, but not doing me any good…
          Any suggestion?
          	module: 'MMM-MotionEye',
          	position: 'bottom_right',
          		url: "http://192.168.1.200:8080/motioneye/1",
          		debug: false
          S CatoC 2 Replies Last reply
            shashank @emos
            @emos hi, try changing the port (8080) in MM or camera , both MM and camera with 8080 will not work
            • CatoC
              Cato Module Developer @emos
              @emos The URL you are using in your config seems to be the “web hook”-URL that you have to configure inside MotionEye if you want to automatically show video stream when motion is detected.
              The URL should be configured like this (from documentation): Video Streaming URL. You find it in Motion Eye in the Video Streaming Section under Usefull URLs by by clicking the Streaming URL link. It should look something like this: http://motioneye:8081 (probably an IP instead of hostname).
              • E
                emos
                reinstalled motioneye on my other r.pi and now im able to view a stream from http://MotionEyeOS:8081, but only from cam 1.
                With http://MotionEyeOS:8081/motioneye/2 i still just get cam 1. Get the feeling im not understanding something.
                			position: 'lower_third',
                				url: "http://192.168.1.200:8081/motioneye/2",
                				autoHide: false,
                				debug: false
                D 1 Reply Last reply
                • SnilleS
                  Snille Module Developer
                  Hi @emos I’m also using different cameras from the same MotionEye install.
                  I have my cameras set on different ports like this.
                  http://MotionEyeOS:8082
                  http://MotionEyeOS:8083
                  I think that the default way…
                  Then you have the motiontrigger url like this in MotionEyeOS/Camera (for example):
                  http://MagicMirror:8080/motioneye/1
                  http://MagicMirror:8080/motioneye/2
                  http://MagicMirror:8080/motioneye/3
                  That’s it. :)
                  E 1 Reply Last reply
                  Reply Quote -1
                  • E
                    emos @Snille
                    @Snille
                    My second camera is a remote camera, not a local one on my LAN.
                    Also http://MagicMirror:8080/motioneye/1 and http://MagicMirror:8080/motioneye/2 is the same livestream. changing from motioneye/1 to motioneye/2 does nothing.
                    SnilleS 1 Reply Last reply
                    • SnilleS
                      Snille Module Developer @emos
                      @emos you need to add it in to MotionEyeOS. So it knows about it. I have 3 cameras in the same way. You can add any “network-camera”.
                      rtsp://yourcam:port/whatever-format in the “add” dialog in MotionEyeOS. :)
                      • E
                        emos @Snille
                        @Snille
                        Camera is added to MotionEye
                        Under MotionEyeOS Settings>Video Device>Camera ID the ID is 1 and 2 :/
                        • SnilleS
                          @emos Here is one of mine: 0_1486731274088_Cam01.png
                          • E
                            emos @Snille
                            Only thing thats not identical is under video streaming > Useful URLs.
                            As you can see that under cam ID 2 (left one) is that streaming URL are missing… don’t know if this is a deal breaker or how to change it… :/
                            • SnilleS
                              @emos Hmm… I wounder if it is because you use an http link? Can you try to change it to an rtsp link?
                              • E
                                emos
                                can i use rtsp for another MotionEye cam? Does it even have rtsp? :o
                                • SnilleS
                                  @emos Nah, you only need to use rtsp for the “network” cameras. The right one you have looks like a “locally” connected camera?
                                  • E
                                    emos
                                    the right one is local, correct
                                    • W
                                      Woody
                                      Hi Cato, thanks for this Module, I installed it and it works like a charm. One thing I like to ask you is the positioning of the module. I tried to arrange the module appearence pixel-precise with the help of the custom.ccs but was not successful. I added this to the custom.css and deleted the position definition in the config.js. Any idea what went wrong here :question: :question: :question:
                                      .MMM-MotionEye {
                                       left : 700px;
                                       top: 1500px;
                                      • CatoC
                                        I’m really not sure since I’m not very deep into CSS. I would have to test it this weekend. By schedule is pretty tight…
                                        I assume you have a very large screen since you’re putting Motion-Eye 1500 pixels down on it?!? :smiley:
                                        • W
                                          Woody
                                          Of cause, I’ve a more or less large screen but this is only one of some other positions I tried without success to prevent overlapping with other modules.
                                          Would be great if you could help with this of cause spezific problem.
                                          Thx in advance…
                                            Binog
                                            Hey there. My problem is, that I do not get an image one the screen, when using autohide.
                                            It works without using autohide.
                                            Is it true, that it appears - using autohide - if a motion is recognized?
                                            So motioneye is recognizing correctly, but obviously it does not parse the info to the module.
                                            this is my config:
                                            	   position: 'middle_center',
                                            	        url: "http://motioneye:8081",
                                            	        autoHide: true,
                                            	        autoHideDelay:"10000",
                                            	        debug: true,
                                            	        animationSpeed: "2000",
                                            	        width: "300",
                                            Can someone please post a screenshot of the motioneye-config (as seen above) how the settings should be set?
                                            Thank You very much !!
                                            • 2 / 4
