    MMM-MotionEye - surveillance video stream on your mirror!
    70 Posts 15 Posters 103.2k Views 15 Watching
      shashank @emos
      @emos hi, try changing the port (8080) in MM or camera , both MM and camera with 8080 will not work
      • CatoC
        Cato Module Developer @emos
        @emos The URL you are using in your config seems to be the “web hook”-URL that you have to configure inside MotionEye if you want to automatically show video stream when motion is detected.
        The URL should be configured like this (from documentation): Video Streaming URL. You find it in Motion Eye in the Video Streaming Section under Usefull URLs by by clicking the Streaming URL link. It should look something like this: http://motioneye:8081 (probably an IP instead of hostname).
        • E
          emos
          reinstalled motioneye on my other r.pi and now im able to view a stream from http://MotionEyeOS:8081, but only from cam 1.
          With http://MotionEyeOS:8081/motioneye/2 i still just get cam 1. Get the feeling im not understanding something.
          			module: 'MMM-MotionEye',
          			position: 'lower_third',
          				url: "http://192.168.1.200:8081/motioneye/2",
          				autoHide: false,
          				debug: false
          D 1 Reply Last reply
          • SnilleS
            Snille Module Developer
            Hi @emos I’m also using different cameras from the same MotionEye install.
            I have my cameras set on different ports like this.
            http://MotionEyeOS:8082
            http://MotionEyeOS:8083
            I think that the default way…
            Then you have the motiontrigger url like this in MotionEyeOS/Camera (for example):
            http://MagicMirror:8080/motioneye/1
            http://MagicMirror:8080/motioneye/2
            http://MagicMirror:8080/motioneye/3
            That’s it. :)
            E 1 Reply Last reply
            Reply Quote -1
            • E
              emos @Snille
              @Snille
              My second camera is a remote camera, not a local one on my LAN.
              Also http://MagicMirror:8080/motioneye/1 and http://MagicMirror:8080/motioneye/2 is the same livestream. changing from motioneye/1 to motioneye/2 does nothing.
              SnilleS 1 Reply Last reply
              • SnilleS
                Snille Module Developer @emos
                @emos you need to add it in to MotionEyeOS. So it knows about it. I have 3 cameras in the same way. You can add any “network-camera”.
                rtsp://yourcam:port/whatever-format in the “add” dialog in MotionEyeOS. :)
                • E
                  emos @Snille
                  @Snille
                  Camera is added to MotionEye
                  Under MotionEyeOS Settings>Video Device>Camera ID the ID is 1 and 2 :/
                  • SnilleS
                    @emos Here is one of mine: 0_1486731274088_Cam01.png
                    • E
                      emos @Snille
                      Only thing thats not identical is under video streaming > Useful URLs.
                      As you can see that under cam ID 2 (left one) is that streaming URL are missing… don’t know if this is a deal breaker or how to change it… :/
                      • SnilleS
                        @emos Hmm… I wounder if it is because you use an http link? Can you try to change it to an rtsp link?
                        • E
                          emos
                          can i use rtsp for another MotionEye cam? Does it even have rtsp? :o
                          • SnilleS
                            @emos Nah, you only need to use rtsp for the “network” cameras. The right one you have looks like a “locally” connected camera?
                            • E
                              emos
                              the right one is local, correct
                              • W
                                Woody
                                Hi Cato, thanks for this Module, I installed it and it works like a charm. One thing I like to ask you is the positioning of the module. I tried to arrange the module appearence pixel-precise with the help of the custom.ccs but was not successful. I added this to the custom.css and deleted the position definition in the config.js. Any idea what went wrong here :question: :question: :question:
                                .MMM-MotionEye {
                                 left : 700px;
                                 top: 1500px;
                                • CatoC
                                  I’m really not sure since I’m not very deep into CSS. I would have to test it this weekend. By schedule is pretty tight…
                                  I assume you have a very large screen since you’re putting Motion-Eye 1500 pixels down on it?!? :smiley:
                                  • W
                                    Woody
                                    Of cause, I’ve a more or less large screen but this is only one of some other positions I tried without success to prevent overlapping with other modules.
                                    Would be great if you could help with this of cause spezific problem.
                                    Thx in advance…
                                      Binog
                                      Hey there. My problem is, that I do not get an image one the screen, when using autohide.
                                      It works without using autohide.
                                      Is it true, that it appears - using autohide - if a motion is recognized?
                                      So motioneye is recognizing correctly, but obviously it does not parse the info to the module.
                                      this is my config:
                                      	   position: 'middle_center',
                                      	        url: "http://motioneye:8081",
                                      	        autoHide: true,
                                      	        autoHideDelay:"10000",
                                      	        debug: true,
                                      	        animationSpeed: "2000",
                                      	        width: "300",
                                      Can someone please post a screenshot of the motioneye-config (as seen above) how the settings should be set?
                                      Thank You very much !!
                                        A Former User
                                        Hi all,
                                        Just started my adventure with the MagicMirror, running into some problems with streaming 2 ipcams into MM.
                                        I installed Motioneye in the Rpi and also in the MM module.
                                        Both ipcams are visable when i log into Motioneye (in my case: 192.168.1.105:8765) but only a small icon appears in the MagicMirror.
                                        My config is:
                                        {                       module: 'MMM-MotionEye',
                                        			position: 'bottom_right',
                                        			url: "http://192.168.1.105:8765/motioneye/1",
                                        			debug: true,
                                        I have tried all above mentioned ideas but to no succes.
                                        The cams are installed in Motioneye with:
                                        http://192.168.1.102:88/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=XXX&pwd=XXX
                                        RTSP give me an error.
                                        Hope someone can help me out…
                                          Binog
                                          I have that more often than I can believe. That normally means motioneye crashed,. or something. there is no connection between MM and Motioneye.
                                          I do the login ins my http://IP:8081 an see if it is running,. normally then MM reloads the full image.
                                          Give it a try!
                                          BTW is there a way to let motioneye run through pm2 ?
                                            Binog
                                            Change Your port in the config.js from 8765 to 8081
                                            ? 1 Reply Last reply
                                            • 2 / 4
